clearance from prop to boat ramp
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Mon Nov 05, 2018 11:19 am    Post subject: Reply with quote
If you change tow vehicles or borrow a tow vehicle (like i did for seasonal in once and out once be aware: hitch height and bumper height can change things up in a hurry as to skeg clearances!
It's something in the water!
PostPosted: Mon Nov 05, 2018 12:41 pm    Post subject: Reply with quote
For several reasons: tire wear, braking, and safety. the boat should always be towed with trailer frame level and parallel to the road. This can be accomplished with either an adjustable height hitch or a series of drop and raise hitches. I have accumulated at least a dozen thru the years....The adjustable is a far better idea!
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Mon Nov 05, 2018 8:33 pm    Post subject: Reply with quote
Very good point from Dr. Bob and Minnie Swann. In an earlier post I mentioned witnessing a guy drag his lower unit all the way up the ramp (motor in down position) while pulling out of the marina launch. The problem was most likely that the ball hitch was too high on his tow vehicle or maybe he had not quite pulled the boat up all the way onto the trailer.
PostPosted: Tue Nov 06, 2018 3:11 am    Post subject: Reply with quote
Having the trailer frame level is especially important if you are pulling a tandem axle trailer. Towing a tandem axle that is not leveled will create extra wear due to weight differential increase on the axle on the lower end of the trailer.
Page generation time: 0.1157s (PHP: 90% - SQL: 10%) - SQL queries: 22 - GZIP disabled - Debug on
