110 VAC outlet on starboard side near stove
joc1212
City/Region: OAK HARBOR
Vessel Name: Last Time ll
PostPosted: Sat Oct 06, 2018 9:16 am    Post subject: 110 VAC outlet on starboard side near stove Reply with quote
Has anyone installed a 110VAC outlet (GFI) on the starboard side of a CD 25?
I'd like to have one near the stove for a coffee make...
Only ones we have are under the table next to the breaker panel.
Any suggestions??
Be safe wear a PFD have fun
25 ' CDMA Cruiser 200 Yamaha 15 Honda
All New Garmin Electronics package
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Oct 06, 2018 9:34 am    Post subject: Re: 110 VAC outlet on starboard side near stove Reply with quote
Any suggestions??
Mine has one between drivers seat & throttle. You can put one where ever you so desire (nickel neutral, black is gold & green ground)
PostPosted: Sat Oct 06, 2018 10:23 am    Post subject: Re: 110 VAC outlet on starboard side near stove Reply with quote
Any suggestions??
We don't know what year your boat is *the HIN you have in your profile is not a valid HIN). The fiber glass interior (Late 2007 on) can have an outlet installed on the back splash behind the stove. The earlier boats can have an outlet installed on the vertical panel aft of the throttle/shifter binnacle--the forward bulkhead of the galley counter, outboard. Mine (late 2007) has both.
If you have a refrigerator under the helm seat, you have 110 V AC to the outlet behind the refrigerator, and can use that same circuit. Be use and use marine wiring, coded properly (Black, hot; white, neutral; green, ground. Do not use solid wire such as "Romex" Be sure that any wiring is GFI protected.
If you don't have refrigeration and no 110 V wiring to the Starboard side, then you need to run #12 triplex marine wire under the steps and under the head--hopefully someone left a "fishing" line under the head floor. If not, it will take some time with a fishing steel or fiberglass tape to get a wire thru.
I am surprised that there is not an outlet on the bulkhead behind the throttle. Most of the 25's do--and a few owners have not discovered their presence.
PostPosted: Sat Oct 06, 2018 10:47 am    Post subject: Reply with quote
My 22 had the outlet on the vertical panel behind the throttle. Very inconvenient place for an outlet, IMO. I moved it to the front of the main cabinet the holds the sink, stove, etc.
PostPosted: Sat Oct 06, 2018 11:40 am    Post subject: Reply with quote
The 25 has a much larger area behind the throttle, and I have use this for a number of chargers which run off 110 V, although I have 6 USB chargers off the 12 volt system. Also this area is far less likely to have water spilled on it than other areas of the galley.
Page generation time: 0.1203s (PHP: 87% - SQL: 13%) - SQL queries: 23 - GZIP disabled - Debug on
