how to read the serial #
SENSEI
City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Fri Aug 24, 2018 4:24 pm    Post subject: how to read the serial # Reply with quote
howdy I know this has been talked about in the past but I am going to approach it again
DOR227160595
DOR = dory
22 = length 22 ft
716 = 716th boat built
05 = month built
95 = year built.
am I correct in my assessment
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
PostPosted: Fri Aug 24, 2018 5:18 pm    Post subject: Reply with quote
Roger, mine looks different than yours.
Starts with CDO and in the month spaces has G4.
Otherwise your description fits.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Fri Aug 24, 2018 5:53 pm    Post subject: Reply with quote
The list of manufacturer's identification codes can be found here: http://www.uscgboating.org/content/manufacturers-identification-result2.php
You can also see how hull identification numbers are played out here: http://boatsafe.com/nauticalknowhow/hin.htm
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Fri Aug 24, 2018 5:56 pm    Post subject: Reply with quote
'between Nov. 1 1972 and Aug 1 1984, was one scheme
Since Aug 1 1984 it is first 3 letters are the manufacture--there are at least 6 for C Dory's
The next 5 numbers are the serial number--in the C Dory line the first 2 are the size and the next 3 are the hull number built (some are the # that year or that manufacture). The next two digits are a letter A-L (Jan thru Dec, for the month when the hull was started the next number is the year hull was started, and the final two numbers are the year model.
For example my boat is: CDO (C Dory )25 (length) 625(625th 25 by Reynolds CDO) A7Hull started in January 2007 . 07 model year 07
Manufacturers:
MFN Marben Marine,
DOR was the original Toland [pre Reynolds] -
CDO Reynolds;
UWH was Fluid Marine after Reynolds.
CMC Trident marine after Fluid
NWM is Northwest Marine Industries [current owners]
Also included are: GXK, MFN, CCR, MEH Not sure how these really fit in--but one was the cape cruiser.
I will not confuse the issue with boats prior to Aug. 1 1984
In Roger's case, something is wrong with the "05" Could that be a "C" 5 meaning that your boat was started in March 1995?
Page generation time: 0.0954s (PHP: 86% - SQL: 14%) - SQL queries: 22 - GZIP disabled - Debug on
