kennharriet
Joined: 22 Jan 2009 Posts: 510 City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
Posted: Thu Jun 21, 2018 1:26 am Post subject: |
When I get better service I’ll attach a photo of the chart I use for quick reference. 25’, 50’ and 75’ are always red, white and blue respectively.
At the 100’ series the painted rode is three feet long so 125’ is 12”Red, 12”Red, 12”Red. 150’ is 12”Red, 12”White, 12”Red. 175’ is Red, Blue, Red. A pic is worth a thousand words but we are in the Broken Group Islands with limited service. We are anchored in 50’ of water so for a minimum of 3:1, I tied off at Red, White, Red. Hope this helps. Ken |
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
Posted: Sun Jul 01, 2018 9:51 pm Post subject: |
Harvey. Here is the anchor rode scheme I use that you had asked about. So each 25' increment is red, white, blue. Note that each 100' increment has a black center to indicate 100', 200', etc. The hundreds of feet also is red, white, and blue. I only carry 300' total so the orange warns of the end of the rode. I also have a mark on the chain that warns me of the anchor just before it hits the roller. Ken
JOHN C
State or Province: OH
Vessel Name: Mighty Wench
Posted: Mon Jul 02, 2018 7:12 am Post subject: zip ties |
We tried the paint route - it didn't last - maybe the wrong paint?
What we found works and is very easy to maintain is zip ties - you can get a bag at Harbor Freight of mixed colors - ours were something like 8 to 12 inch long. Any system you want - we put three in a row in each increment (50 ft for us). They go through the windlass with no problem and are easy to replace on the fly, although ours lasted for months of daily use. _________________ 24' Rosborough RF-246
John and Susan |
Posted: Mon Jul 02, 2018 7:17 am Post subject: Re: zip ties |
JOHN C wrote: | We tried the paint route - it didn't last - maybe the wrong paint?
What we found works and is very easy to maintain is zip ties - you can get a bag at Harbor Freight of mixed colors - ours were something like 8 to 12 inch long. Any system you want - we put three in a row in each increment (50 ft for us). They go through the windlass with no problem and are easy to replace on the fly, although ours lasted for months of daily use. |
John- Did you weave / braid the nylon zip ties through a three strand nylon rope rode, or simply wrap them around the rode?
Thanks!
cmetzenberg
Joined: 04 Jan 2014 Posts: 367 City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
Posted: Mon Jul 02, 2018 9:47 am Post subject: |
How I do it; I spray painted the line red at 50', two red sections at 100', 3 red sections at 150', and so on. Works great. _________________ Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
Posted: Mon Jul 02, 2018 10:47 am Post subject: |
I tried zip ties, and while they worked, their ends can cut the hands if manually working with the rode. Colby |
Posted: Mon Jul 02, 2018 11:10 am Post subject: |
Ken, Thanks for the chart. I have used paint but it is mostly gone after 2 years heavy use. As to the lenghts, at 50 feet for the first marking I would be almost fully at the end of my line
My typical depth for anchoring is at 5 feet at low tide, and I would usually run out 70 feet of chain, prefering to not run onto the 200 feet of rode.
JOHN C
Posted: Tue Jul 03, 2018 10:57 am Post subject: zip ties |
We have 150 ft of chain and 150 ft of rope. We tried to anchor in water shallow enough so the rope never appeared and we were mostly successful doing that so our rope markers have only been used a couple of times (stayed in the locker). Yes the ties were through one part of the rope - if you just wrapped them around the OD I believe nasty things could happen and, even if I am wrong about that, I don't see how they would not move along the rope.
I confess, with the anchor windlass, we have not man-handled the rode at all so I have no experience with Colby's comment. |
Posted: Tue Jul 03, 2018 3:06 pm Post subject: Re: zip ties |
JOHN C wrote: | We have 150 ft of chain and 150 ft of rope. We tried to anchor in water shallow enough so the rope never appeared and we were mostly successful doing that so our rope markers have only been used a couple of times (stayed in the locker). Yes the ties were through one part of the rope - if you just wrapped them around the OD I believe nasty things could happen and, even if I am wrong about that, I don't see how they would not move along the rope.
Now that's my kind of anchoring!
1.Push button deployment and retrieval (no hands).
2. Big + long chain: 100' of 1/4" Grade 40 High Test =75lbs +the anchor weight.
3. No Contest Anchor: Fortress FX-16, good for up to 38 foot boat.
4. Digital anchor rode counter integrated into windlass on bow. Magnet on windlass gypsy trips coil which electrically registers on counter on helm display.
5. Positive anchor hook up: Depending on East/West or North/South rode play out can result in slowing up/retarding earth's rotation or change in tilt on its axis!
You Mileage May Vary.....
Swee Pea
Vessel Name: Swee Pea
Photos: Swee Pea
Posted: Mon Aug 13, 2018 4:10 pm Post subject: Marking Anchor Chain |
Been following this thread and another one to decide how I am going to mark my anchor chain. I bought my 22' Cruiser from Cutter Marine. They always supplied 150' (of chain) citing local needs and adding a little weight in the bow. I went to EBay and found a seller who sells round aluminum dog tags and engraves them. I bought 7 ($15) and had them engraved 20, 40, 60 ... and will attach them either with the supplied split rings or some Dynema line that I have. I intend to paint the first 10' red so I know that the anchor is near. Should work. I do not have a windlass.
Swee Pea |
letitride
Vessel Name: No Limits
Photos: Letitride
Posted: Mon Aug 13, 2018 7:42 pm Post subject: |
We use colored zip ties (like many others do) at each 25ft interval.
Use the large ones about 12in we place 3 to mark each 25ft interval don't clip them leave them full size. They pass thru the windlass easily and position each one so that they stick out at 120 deg to each other on the chain or rode as they pass thru the windlass one will be sticking up or two and you can see it easy at night with a flash light, they are cheap and replacing them is very easy |
Posted: Mon Aug 13, 2018 7:50 pm Post subject: |
John, I am going to bet that without a windlass, you will be able to see the anchor in the last 10 feet.
Quote: | "I intend to paint the first 10' red so I know that the anchor is near. Should work. I do not have a windlass." |
You may not need to paint all of the last 10 feet. On mine I have a 10 foot mark and a 5 foot mark. At 5 feet I know the anchor is just about to break the surface. ( I am sitting at the helm, not standing on the bow.) At 10 Feet, I am watching for the 5 foot mark, at that point I go to slow mode and if the chain looks messy or the anchor is when it shows It goes back into the water just past that 5 foot mark for a bit of a washing.
SleepyC |
Swee Pea
Photos: Swee Pea
Posted: Mon Aug 13, 2018 8:15 pm Post subject: Anchor Chain |
Harvey/SleepyC
Good point. Might just buy 6 feet of galvanized red or yellow coated chain and link it to my anchor and anchor chain. Should last longer than paint. Thanks for your perspective.
Swee Pea |
