Worry Box Question
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Jun 17, 2018 4:04 pm    Post subject: Worry Box Question Reply with quote
Does anyone have a good work aroundif you lose a fuel pickup while on a cruise? My only thoughts would involve using a hose (portable tank?) to pull the fuel out of the crippled tank.
Any other simple ideas?
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Jun 17, 2018 4:20 pm    Post subject: Re: Worry Box Question Reply with quote
Remove fitting in top of tank, take piece of fuel hose of appropriate size, slide into tank & hook the other end to your fuel/water separator. If fuel hose is too curly to stay near bottom of tank insert a piece of steel tubing of appropriate size
in end of hose to weight it down. All this should be kept next to the Iodine tablets for when the big one hits Wink
Wandering Sagebrush
PostPosted: Sun Jun 17, 2018 4:35 pm    Post subject: Reply with quote
I uses a filter instead of iodine Very Happy
I haven’t looked at access to the top, but last time I was in there it seemed tight on top. Guess I better get off my duff and check.
PostPosted: Sun Jun 17, 2018 4:37 pm    Post subject: Reply with quote
If it plugs you can disconnect the hose from the filter and blow thru it into the tank. That should dislodge the crud around the fuel strainer enough to get you home.
My tank has two outlets and I am only using one so I use that to keep the lid on my worry box, which is usually open for nine other worries anyway.
tsturm
Photos: JMR-TOO
PostPosted: Sun Jun 17, 2018 6:02 pm    Post subject: Reply with quote
Do Not Suck!! you will never get that taste out.
PostPosted: Sun Jun 17, 2018 6:13 pm    Post subject: Reply with quote
The 25's have access to the top of the fuel tank--I don't think there is any easy way to get to the top (and pick up tube) of the 22. I would just use the other tank.
One could pull the tank out, but that gets pretty complicated when underway.
I have had an air leak on a diesel boat in the pick up tube (actually at the elbow), and carried a spare pickup tube for the diesel tanks on our long distance cruising sailboats.
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Sun Jun 17, 2018 6:16 pm    Post subject: Reply with quote
Iodine...iodine? What’s this iodine business? Never heard anything about iodine. Never been the brightest bulb in the package, but, iodine??? Clue me in please! What’s that do?
Wandering Sagebrush
PostPosted: Sun Jun 17, 2018 6:55 pm    Post subject: Reply with quote
Vern, that’s to purify the water when the Cascadia subduction zone let’s go! I think he was putting one more worry in my worry box... Smile
Bob, worry part 2: that might be the really low tank, and the other tank is bad. I’m thinking my original idea of pumping via a squeeze bulb might be a last option.
tsturm
Photos: JMR-TOO
PostPosted: Sun Jun 17, 2018 9:20 pm    Post subject: Re: Worry Box Question Reply with quote
How Iodine Protects Against Radiation
A nuclear or radiological event such as the Fukushima disaster released large amounts of Iodine-131 into the air. In a radioactive event like this, the thyroid will quickly absorb the Iodine-131. This internal contamination damages the thyroid, leading to hypothyroidism (when the thyroid fails to produce adequate hormones) or worse.[2]
That’s because the thyroid cannot distinguish between normal iodine and radioactive iodine.[3] In a situation like this, nascent iodine may save your life.
Wink Wink Wink
Wandering Sagebrush
PostPosted: Sun Jun 17, 2018 10:11 pm    Post subject: Reply with quote
Since Iodine is a halide, it also helps kill parasites and other critters in water. Ive taken many a backpacking trip drinking water with halazone tablets and Fizzies to mask the flavor.
http://www.princeton.edu/~oa/manual/water.shtml
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon Jun 18, 2018 7:17 am    Post subject: fuel pickup Reply with quote
We had problems last Spring had to be towed in 2 times My new merc 2016 would not run more then a few minutes unless one was squeezing the fuel bulb . The only way to get it going was to release air out of the Shrader valve the fuel rail was full of air not gas ? So we changed out fuel pickups and put in 2 new water sep filters one at engine and the big 10 micron filter in boat and gave it new plugs and new fuel and that seems to fix the problem . my boat was built in 05 .So far we have replaced all the fuel lines ,new alum gas tanks new pickup and sending units and new filters every 6 months .
I'm not sure how the fuel pickups are mated to the plastic gas tanks but for alum tanks they are screwed in with 5 screws
If your boat is 10 years or older maybe a good time to look over your fuel system so there are no worries jim
Page generation time: 0.0342s (PHP: 68% - SQL: 32%) - SQL queries: 29 - GZIP disabled - Debug on
