Center Window
Big dave
City/Region: Vancouver
Vessel Name: Raven Dancer
Photos: Raven Dancer
PostPosted: Sun Sep 06, 2009 7:31 pm    Post subject: Center Window Reply with quote
Anyone have an idea where I could pick up a knob for the center opening window. The knob the lets you lock the window open. Mine is safely stored in the drink !
Thank you.
Dave.
Raven Dancer.
Dreamer
Photos: Dreamer
PostPosted: Sun Sep 06, 2009 7:39 pm    Post subject: Reply with quote
Dave, It's available at the Diamond Sea Glaze site:
http://www.diamondseaglaze.com/upload/products/other/106_Adjuster_Parts.pdf
Dreamer- Sold 25 Feb. 2013
ccflyer
City/Region: Bradenton, FL
Vessel Name: Retriever
Photos: ccflyer
PostPosted: Mon Sep 07, 2009 9:22 am    Post subject: Reply with quote
I was able to use a part available at West Marine on my center window.
Go to their web site and search on "Seafit Premium Hatch Adjuster"
It's $27.99.
There is a very fine line between "hobby" and "mental illness".
C-batical
City/Region: Pinckney
Vessel Name: C-Batical
Photos: C-Batical
PostPosted: Mon Sep 07, 2009 7:07 pm    Post subject: Reply with quote
Big Dave.
Let me know if it the same as that installed in the 2004 22 Cruiser. If it is, I will send you one. I will have to look for it but I think I have the whole arm mechanism.
Best regards,
Rollie/C-Batical
Pinckney, MI
Snider
City/Region: Charleston
State or Province: SC
Vessel Name: Kestrel Dawn
Photos: Kestrel Dawn
PostPosted: Fri Jun 15, 2018 9:01 pm    Post subject: Update Reply with quote
I'm just going to update this old thread. I have a 2002 22 Cruiser with the adjuster for the center window that has the wing nut on it. I've been trying for a few weeks to find a suitable solution or replacement as my wing nut would just jump the threads and not tighten enough to hold the window up. As a temporizing measure I wrapped a few turns of electrical tape around the bezel and that gave it enough bite to hold the window half open while running pretty hard. I ordered a replacement from the Advantec store but they sent the wrong size. They sent the 10" when I ordered the 7". What I found though is that the knob from the new adjuster fit perfectly onto the threads where the wing nut screwed on. It was a $30 part basically for the knob. The mounting holes for the 10" adjuster where a little wider than the holes in the welded tab on my window. If the 7" version is the same it also wouldn't work. I was going to call them and check to see if the 7" version's mounting holes where identically spaced as the 10", but then found that I could just rob the knob. Here's a link to the part, I wonder if you might be able to just order the knob for a cheaper price? (Edit: on their website it looks like you can just order the knob)
http://www.advantecstore.com/adjusters/sea-dog/swivel/Swivel_Adjusters_Custom_to_DSG_Manual_11-13/16_14-3/16_SS304/Nylon_12107.html
Brandon
22ft Cruiser
Charleston SC
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Fri Jun 15, 2018 10:08 pm    Post subject: Center window Reply with quote
Yes I need to order 2of those for my front window cc23
Barry Rietz
City/Region: Sierra Vista
PostPosted: Fri Jun 15, 2018 10:35 pm    Post subject: Center Window Knob Reply with quote
Most well stocked "ACE Hardware" stores have an extensive section of fasteners. Above the nuts and bolts shelves are specialty items. The black knurled round knobs that you need with internal SAE threads are in those flat trays.
Barry Rietz
N9DXC
PostPosted: Fri Jun 15, 2018 11:15 pm    Post subject: Reply with quote
Same thing apparently happened to the PO of my boat. He replaced the missing knob with a wing nut. The wing nut thread was not quite the same, it worked ok, but you could not really get the lock tight and the strut would slip. I got a replacement knob from Diamond Sea Glaze. I also got a repair kit which contains all the locking mechanism parts for the window strut.
They are Sea Dog parts. Look on this page.
http://www.advantecstore.com/adjusters/sea-dog/miscellaneous/
Snider
PostPosted: Sat Jun 16, 2018 12:13 am    Post subject: Window Reply with quote
Just so there's no confusion.
This is what I had on my adjuster
Snider
PostPosted: Sat Jun 16, 2018 12:15 am    Post subject: Then this Reply with quote
Then I went to this by adding the knob hardware to the old adjuster rod.
WeekiTiki
City/Region: Weeki Wachee
Vessel Name: Just Cruisin'
Photos: WeekiTiki
PostPosted: Fri Jun 28, 2019 4:49 pm    Post subject: Reply with quote
That's what I need
A knob that actually works
Page generation time: 0.0426s (PHP: 71% - SQL: 29%) - SQL queries: 28 - GZIP disabled - Debug on
