Remove very old vinyl boat numbers
C-Val
City/Region: White Rock
C-Dory Year: 1988
Vessel Name: Seaduced
Photos: C-Val
PostPosted: Sun Jun 03, 2018 1:12 am    Post subject: Remove very old vinyl boat numbers Reply with quote
Hi Everyone
Just want to ask what your tricks are to remove very old vinyl boat registration numbers.
I have heard heat helps
David
Writing a sea story with my C-Dory !
1982 22' Classic Popeye
1981 22' Classic Bad Boy Brutus
1988 22' Angler
PostPosted: Sun Jun 03, 2018 2:40 am    Post subject: Reply with quote
For vinyl I've used a heat gun with a sharp single edge razor followed by "goof off" and then a wax. Watch the heat.
SENSEI
City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Sun Jun 03, 2018 3:31 am    Post subject: Reply with quote
on the new Sensei, I used a razor blade to get the 1995 graphics off then wiped it off to get the glue residue off with good ol 87 octane gasoline. it removed the film with ease
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
C-Val
C-Dory Year: 1988
Photos: C-Val
PostPosted: Sun Jun 03, 2018 1:25 pm    Post subject: Reply with quote
Thank you for your inputs
Heat gun it is - used with care!
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sun Jun 03, 2018 1:58 pm    Post subject: Reply with quote
They will always come off with heat (no matter how old they are), thats not the issue. The issue is the sun fade on the gelcoat.
On my new boat I can clearly still see the old graphics at different angles! I hate that.....
<><><> Jason <><><>
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Sun Jun 03, 2018 2:01 pm    Post subject: Reply with quote
Is that ethanol free gasoline? ....................only joking.
If you don't have a drop of gasoline or "Goo Gone" handy, good 'ol WD 40 does the same job.
Martin.
PostPosted: Sun Jun 03, 2018 3:20 pm    Post subject: Reply with quote
I just removed the pin stripe on the hull line. You could see the gelcoat had yellowed compared to the white under the stripe. I used some 3M Finesse compound and a polisher to remove the yellowing. Our boat is an '07 and is parked on the trailer outside. Will it work all the time? I doubt it. But worth a try.
PostPosted: Sun Jun 03, 2018 3:34 pm    Post subject: Reply with quote
so at the Fh gathering I picked up a set of original cdory decal complete with the original factory address. This is wonderful because my old ones are in really bad shape. These are not vinyl ( i think ). would heat be the best way to get them off?
PostPosted: Sun Jun 03, 2018 8:04 pm    Post subject: Reply with quote
I had to remove a 3M "Diamond Shield" on the front of my RV--and not damage the paint. These are far more tenacious than the vinyl we use on names and numbers etc. I found a combination of "ZEP" or any other good citrus spray, (Home Depot), and a plastic razor blade made the job as easy as possible. I just did the name and numbers on "Thataway"--and it was a 20 minute job. Someone had used steel razor blades in the past--and it showed. I never use them on a fiberglas or painted vehicle!. Heat might have made it a little faster (and I did use heat on the RV). Don't get it too hot, or you can damage the gel coat! Clean up with Goof Off, or WD 40 (one of the few things it is good for). As Local Boy, I compounded the area where both the numbers and name was. First I wanted fully clean and wax for the new graphics, plus I didn't want to compound over new vinyl--that is a great way to ruin the graphics!
Wear Nitrile gloves; Best I have found are Harbor Freight, 9 mil--really last and fit!
PostPosted: Sun Jun 03, 2018 8:21 pm    Post subject: Reply with quote
The problem I found is that even with the old lettering removed, you can still see what was there because the gelcoat fades/weathers differently when covered by the vinyl. Unless you are replacing identical lettering you are going to see what was there before.
I had a FG RIB once. Before I bought it they took the old lettering off the hull. However, for as long as I owned the boat, you could still pretty clearly make out the old name on the transom.
PostPosted: Sun Jun 03, 2018 9:35 pm    Post subject: Reply with quote
This is basically a problem for the boat owner--and the rest of the world are not so hyper critical, we don't go looking for old shadows...or ghosts. Generally I find that I see the old name, but no one else pays any attention to it.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Sun Jun 03, 2018 10:40 pm    Post subject: Reply with quote
You can buy a rubber wheel at auto body supply stores that you use on a drill. Works well on cars - never tried them on fiberglass. Keep it flat, keep it moving - don't hold in one place too long or with too much pressure.
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Mon Jun 04, 2018 9:46 am    Post subject: Reply with quote
When using chemicals to get rid of the adhesive, start with a small test area. I tried to use an industrial strength Goo gone to get rid of the crystalized adhesive on our Parker, and it discolored the hull. Luckily it was a small spot not noticeable but I switched to something a little less heavy duty, like orange gone or something like that.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Mon Mar 04, 2019 12:35 pm    Post subject: Reply with quote
The problem I am having is that the ghosted lettering from the old registration is "raised up." It is like the gelcoat underneath the old lettering hasn't "weathered." The gelcoat around where the old lettering was is slightly lower and the old lettering area is proud of the surrounding gelcoat.
I have read to use 600 grit sanding the old lettering down to the existing gelcoat level. Is this advisable?
Thanks everyone.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Mon Mar 04, 2019 1:17 pm    Post subject: Reply with quote
I use a hair dryer to peel away old stickers, then spray toilet bowl cleaner over the area. In a few minutes, it looks much better. By the next day, it looks brand new.
https://www.youtube.com/watch?v=AEGolbLmAYo
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
Page generation time: 0.0563s (PHP: 53% - SQL: 47%) - SQL queries: 32 - GZIP disabled - Debug on
