Tomcat 255 owners - questions
Sundog
Vessel Name: SUNDOG
Photos: Sundog
PostPosted: Tue May 29, 2018 6:32 pm    Post subject: Reply with quote
Thanks super helfpful!!
I especially like this from "Gulfcoast John" Smile
You WILL find MANY other ways to blow money on her, so my advice is find some other way for now.
I just went out and got rid of about 3-5 gallons out of the starboard Transom and maybe 1 galling out of the port side.
Lot's to learn and I like the idea of continue to play with trim and load and getting to know the boat well before messing with other steps like different prop or OB positioning.
I spend well over a year of nights on my CD Cruiser and knew every inch of her and what she was capable of, this one is going to take some time.
Having gone from a cruiser, to a Grand Banks 36 - back to the Tomcat I have to say I am thrilled with this boat, it seems to be the best of compromises and better fits the goal of using the smallest boat we possibly can as a family.
Feels good to be back on a C-dory, like coming home and I am thankful for the community here to share with and learn from.
Cheers from the Sundog crew!
Joe
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Tue May 29, 2018 6:37 pm    Post subject: Reply with quote
Tom, you're right, but you're getting as picky as Bob, who critiqued my navigation plans simply becase they were off by a mere 250 miles!
Chastened,
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
BTDT
City/Region: Grand Lake Oklahoma
State or Province: OK
Photos: C-Lark
PostPosted: Thu May 31, 2018 9:31 am    Post subject: Reply with quote
Sundog wrote:
I just went out and got rid of about 3-5 gallons out of the starboard Transom Joe
I'm surpised your auto-bilge pump function didn't kick in? Perhaps it was not quite enough water volume to trip the switch/flapper?
Is your shower drain sump pump working properly? You have to run some shower water until enough volume switches on the small pump. (located under sink flooring access panel)
Have you also checked your swim platform acess panels for water?
John & Vicki Clark
C-Lark Wine Down
Tomcat 255
Sundog
Vessel Name: SUNDOG
Photos: Sundog
PostPosted: Thu May 31, 2018 9:38 pm    Post subject: Shower & Water Heat Pump - necessary? Reply with quote
Hi All,
So the pump that is in the plastic box with a float switch is not working on my boat. Before I work through what the issue is, I am really wondering if it is even necessary considering we don't use the shower at all. Also not a big deal to drain the water heater down into the bilge area.
Thoughts?
and thanks.
Joe
Sundog
Vessel Name: SUNDOG
Photos: Sundog
PostPosted: Thu May 31, 2018 9:39 pm    Post subject: Reply with quote
and BTDT - sorry but when I mentioned I got some water out of the boat it was from the swim platform.
gulfcoast john
C-Dory Year: 2010
Photos: CAT O' MINE
PostPosted: Sat Jun 02, 2018 9:24 pm    Post subject: Reply with quote
Joe,
We feel a water heater that runs on shorepower is useless without a generator. Who wouldn’t use the unlimited hot water at the marina’s shower instead? And the ‘gray’ sudsy shower water is pumped overboard by the sump pump, right to your marina dock mate. Gross. The rated 1750 watts on mine is right at the top of a Honda 2000 rated output, or that of a wall plug.
Simple 2-beer job to remove heater...disconnect all 110v/12v input, remove white, black, green wires and plug hose cold water inlet, hot water outlet, and overflow to shower sump with SS bolts screwed into the hose ends with SS clamps (so it’s easy to rep lace if next owner wants to). I put up a Lexan sheet at the back to keep things from hitting all that rigging that runs along the stbd side behind the heater, and stuffed the hoses down their rigging holes.
What I haven’t done yet, but is on The List, is to re-connect the water heating wiring and change out the 110v plug behind the helm seat with a GFI, (currently it’s daisy-chained to the port side 110v outlet and BOTH are on a 10 breaker) then connect the now-unused water heater 110v power to that. Re-label ‘water heater’ as ‘starboard 110v GFI’. Now we have TWO 110V outlets EACH with 10A capacity rather than 2 outlets sharing 10A.
This frees up an entire cabinet for storage of stuff you really don’t need on a boat, so I highly recommend it.
No need to remove the inop sump pump.
I T’ed a hose from the shower cold water input to the transom for a hose-off on the bracket for those 95 degree afternoons, but you don’t have nearly as many of those as we do.
I also plugged the raw water washdown intake with a rubber stopper and sealant as who wants to wash down with hot saltwater when you’ve been in it all day?
Best,
joechiro30
City/Region: Lynnwood
PostPosted: Sun Jun 03, 2018 1:23 am    Post subject: Trolling with the tomcat Reply with quote
I can put my two cents in for the trolling for salmon part. I can troll with one engine and depends on what species of salmon you are fishing for. No problem trolling for coho since they like a faster troll of 3-3.5 mph. Trolling for kings can be effective too however on some occasions when the tides are running fast it’s hard to hold a slower troll speed to keep my downrigger angle at the optimal angle of about 45 degrees to troll for kings. Trolling for pinks is tougher to get to that 1.5 mph speed however I accomplished it by putting one engine in reverse while having one going forward. Caught many fish on the TC. But get the extended booms need to be able to keep the lines away from the props while turning.
BTDT
Photos: C-Lark
PostPosted: Mon Jun 04, 2018 8:33 am    Post subject: Reply with quote
gulfcoast john wrote:
Joe,
Best,
Well said!
Sundog
Vessel Name: SUNDOG
Photos: Sundog
PostPosted: Tue Jun 05, 2018 7:39 pm    Post subject: Reply with quote
gulfcoast john thanks - Water Heater removal on the list
joechiro30 - thanks for the trolling tips
Had a great trip out this last weekend, loving the boat.
Met the Black Cat - nice folks:)
Will follow up with photos and the various mishaps Smile
Joe/Sundog
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Wed Jun 06, 2018 12:11 am    Post subject: Reply with quote
We use the water heater on almost every trip. With our Honda 2000i we can have a hot shower in 15 minutes. We have cruised SE Alaska where we were out for 60 days and showered in marinas maybe 3 times. We think it's one of the best features on the TomCat. Just one couples experience.
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Wed Jun 06, 2018 1:19 am    Post subject: Reply with quote
We use our water heater for every trip as well. We use the boat for scuba diving and a hot shower feels great after being in cold water for a couple of hours. After the hot water runs out we rinse our gear so we can just clean the boat when we get back in the marina.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
PostPosted: Wed Jun 06, 2018 2:35 pm    Post subject: Reply with quote
There are much smaller flow thru water heaters, some are a gallon and some slightly more. Some even use less than the 1500 or so watts. Being able to shower on the boat is a feature for us==and one of the reasons we moved back up to the 25. Not sure if we are going to put in a smaller water heater or not....but it is always a temptation to load up all of those storage areas!
Page generation time: 0.0392s (PHP: 74% - SQL: 26%) - SQL queries: 29 - GZIP disabled - Debug on
