What is this?
Brattytoo
PostPosted: Wed May 23, 2018 8:22 pm    Post subject: What is this? Reply with quote
Hello, I'm new to forum and new to C-dorys, although I want one badly. I was looking at this C-dory 22 for sale and I'm trying to figure out what is showing on the right hand side bow above the waterline. It looks like a plug or drain or ??? Can someone illuminate me? Thank you
http://www.yachtworld.com/boats/2006/C-Dory-22-Cruiser-3208320/Deale/MD/United-States?refSource=browse%20listing#.WwX-60gvzIU
Avidmagnum12
City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
PostPosted: Wed May 23, 2018 8:39 pm    Post subject: Reply with quote
Drain for anchor rode locker.
Tom and Joyce Schulke
Brattytoo
PostPosted: Wed May 23, 2018 10:36 pm    Post subject: Reply with quote
oh thank you, is that a common way to fix the anchor locker leak?
PostPosted: Wed May 23, 2018 10:42 pm    Post subject: Reply with quote
If any water gets in thru the deck pipe or a windlass, it should drain out thru the bottom of the anchor locker. Most are on the port side, but it makes no difference.
There is no "leak" unless some one forgot to seal off the area between the anchor locker and under bunk--and water can then be trapped there, if it does not drain out the bottom of the locker. Some boats have to have the floor of the anchor locker faired and sealed so the water can drain properly
Brattytoo
PostPosted: Wed May 23, 2018 10:54 pm    Post subject: Reply with quote
Great explanation! I wish I could have been the new owner of Thisaway, but sounds like she found a good home. Congrats on your new boat.
Page generation time: 0.0235s (PHP: 75% - SQL: 25%) - SQL queries: 22 - GZIP disabled - Debug on
