pluscount
Joined: 04 May 2018 Posts: 29 City/Region: Rathdrum (CDA)
State or Province: ID
Vessel Name: Draken
Photos: Draken
Posted: Sat May 05, 2018 1:51 pm Post subject: Noob C Dory question #3 – bow thrusters. |
Since I like to slow troll on large lakes, I’m intrigued with the new GPS autopilot bow thrusters (Min Kota Terrova for example.) A “back of the envelope” calculation says that 24v/80 lb. thrust might be ok for a 22 footer and 36v/112 lb. thrust might be ok for a 25 footer.
Advantages: Cheaper that a real autopilot. Saves gas. Quiet. Can go very slow or hold position.
Disadvantages: ?
I know there was another thread on this but I wonder if anyone has a new opinion. |
Posted: Sat May 05, 2018 3:14 pm Post subject: |
What you are talking about is a trolling motor, not a bow thruster. A bow thruster is built into the hull, and a prop centered in a tunnel.
Both trolling motors and bow thrusters use a fair amount of power. I have a 24 volt (about 140# of batteries) 85# thruster on my 18' Caracal Cat--center console fishing boat.
The larger thruster will require 36 volts, or 3 batteries, in the 210# range. There has to be a battery charger, and heavy cables for the power. Nothing is "free".
Yes, the trolling motors will do all of this. These boats have a lot more windage than a skiff--and thus in calm conditions 80 # thrust may be enough, but if the wind kicks up--no. My dinghy motor is a Torqeedo 1003, about a 3 HP electric motor, with a lithium ion battery. It will push a 22 at about 3 mph for a short distance--slower--far longer.
There are several "Brats" who have these trolling motors on the 22's--not sure about a 25. _________________ Bob Austin
pluscount
Vessel Name: Draken
Photos: Draken
Posted: Sat May 05, 2018 3:25 pm Post subject: |
thataway wrote: | What you are talking about is a trolling motor, not a bow thruster. A bow thruster is built into the hull, and a prop centered in a tunnel.
My noobieness is showing.
Thanks. that all makes sense. |
robhwa
Joined: 04 Dec 2013 Posts: 275 City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
Posted: Sat May 05, 2018 5:45 pm Post subject: Electric trolling motor on bow of CD22 |
Yes, I have a Minn kova Terrova 24 volt saltwater motor mounted on to the bow of my CD22. I have the 54 inch shaft, and it fits from short of the port side of the bow across the front deck, and doesn't protrude. Since it is down when I am fishing from the bow deck it isn't in the way. It doesn't affect the hatch at all.
I use two 31 series AGM batteries to produce the 24 volts under the port front seat and a 2 channel 20 amp charger there. I have carried a 2000 watt generator on occasion to charge in case needed on a long day but didn't need it. I plan to install two 100 watt solar panels on the roof soon.
Those few CD people that have this are kind of like the ones with autopilots. Once you set it up you won't want to ever not have it. Yes it is good for trolling, perhaps essential in for very slow trolling in wind since the CD22 cabin is a great sail and autopilots can have trouble maintaining course at slow speed with wind. However, the trolling motor takes the white knuckles out of docking in wind or tide too. Drop the motor, and you can spin on a dime, move forward or backward, and, in combination with the motor, sideways left or right.
If you get i-Pilot Link you can actually have it take you right into your slip if there is no tide or wind, and if you need to stop to wait for something, you hit the Anchor mode and it will keep you right on the same spot until you want to move again. Utterly cool.
After you get used to it, it is clearly better than a bow thruster, except if you mount it on the port side you can't easily dock on the port side. I dock in my slip on the starboard side, which is more common for CD owners.
Very easy to mount, just be careful to follow directions on other pages for drilling larger holes, cutting out some of the balsa core, and refilling with epoxy and redrilling so that you don't have danger of water getting into the balsa core.
Earlier I wanted to get an Ulterra, since I could deploy and stow without getting on the bow, but I got the Terrova as i would have had to cut out a little bit of the railing for the straight sweep of the Ulterra, something I now wish I had gone ahead and done. My back isn't getting any younger, but with the new doohicky that takes some of the weight of deployment, the Terrova isn't a problem to deploy or to stow. |
Posted: Fri May 11, 2018 6:37 pm Post subject: |
Another option that will work for your trolling slow and bow thruster use is a pair of twins--- yup, twin 40's will do, shut one down for your slow ride, then running both, use opposing throttles when docking for your bow thruster experience.
Just sayin
SleepyC ![Moon](images/smiles/emmoon.gif) _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Phil Barnes
Joined: 20 Jul 2010 Posts: 126 City/Region: Colorado /San Juan Islands
C-Dory Year: 1991
Vessel Name: Swan-C
Posted: Fri May 11, 2018 7:39 pm Post subject: |
Aurelia also uses one on the bow of his CD 19 "Ari". There is a photo or two in his album. |
Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1236 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Joined: 27 Oct 2012 Posts: 3396 City/Region: SW Michigan
Posted: Sat May 12, 2018 4:44 pm Post subject: |
Doesn't provide any details or photos of the thruster.
I do like what he did to line the walls of the berth. Might have to look into doing that myself. |
