LED spot light on bow rail
Goto page Previous  1, 2, 3
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Apr 15, 2018 6:15 pm    Post subject: Re: LED spot light on bow rail Reply with quote
Rock-C wrote:
I would like to mount a LED spot light on the bow rail & run the wiring through the railing. Any tips on making the transition from the rail into the v-birth area ? I'm concerned about sealing the deck under the rail plate.
Here is how I did this project. Polished a piece of 10ga 316L fit & welded it to the bow rail (tig), ran wire on the outside of the rail, made my own cable clam into the V-berth. 1 spot & 1flood can see approx 100' clearly in the Dark of Alaska winters. Can't go fast (5-6 knots) but can travel after dark. No glare Wink
Mr. Green
[url][/url]
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Mon Apr 16, 2018 9:50 am    Post subject: Reply with quote
ssobol wrote:
How durable is your gaffers tape?
I put some on my boat and it didn't last that long. It dries out and starts falling off. Maybe the environment you use it in is more benign.
At least two years. I just pulled mine off yesterday and some of the sticky had gone hard, but it was still holding okay. Used "GooP Off" to clean it up and re-installed new tape.
Mark
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Mon Apr 16, 2018 12:50 pm    Post subject: Reply with quote
hardee wrote:
My favorite was the BBQ version......
Hahahahahahahahahahaha........good one!
Rock-C
City/Region: Salem
C-Dory Year: 1988
Vessel Name: Rock-C
Photos: Rock-C
PostPosted: Sat Apr 21, 2018 11:54 pm    Post subject: Reply with quote
Update on the project. Drilling the rail was not a problem, but drilling up from the v-berth through the deck plate was not so easy. I ended up removing the railing to drill the bottom plate. Ran the wiring & mounted the light. This gave me a chance to re-bed the deck for the railing. The wires are ran to the dash. All that's left is to mount the switch & connect the power. Thanks for the great advice.
Terry, Ann & Chloe
Rock-C
C-Brat # 26
PostPosted: Sun Apr 22, 2018 11:27 am    Post subject: Reply with quote
Good choice--SS is hard enough to drill, let alone drilling upward in a blind hole!
Page 3 of 3
Page generation time: 0.1115s (PHP: 89% - SQL: 11%) - SQL queries: 23 - GZIP disabled - Debug on
