Mercury 75 EFI Doesn't Like to Start
RickFish
City/Region: Seattle Area
C-Dory Model: 19 Angler
Vessel Name: Salish-C
PostPosted: Mon Oct 30, 2017 2:21 pm    Post subject: Mercury 75 EFI Doesn't Like to Start Reply with quote
I have a 2007 19' Angler with a Mercury 75 EFI. The motor runs great and only has about 200 hours, but it doesn't want to start consistently. When I try to start it, I will get a "click" from the starter relay. After several tries, it finally turns over and starts immediately. I have 12.5 volts at both the solenoid and starter, so it's not the batteries. Would a bad EFI card cause this? Any ideas on what else to try?
Rick
Work when I have to, fish when I can
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Mon Oct 30, 2017 2:38 pm    Post subject: Reply with quote
I'm not familiar enough with the merc to be able to say what it is exactly, but I had the exact same problem with a 2009 Yamaha 225 on our previous boat.
I searched the internet for the same symptoms you described and discovered it was a relatively common problem. The starter relay starts to work intermittently. For me I would try to start the boat, and just get a click. I would wait and try again, and after a number of tries it would finally turn over and start.
I ordered the part from SIM Yamaha, replaced it myself and it fixed the issue.
I know that Yamaha made some of the powerheads for Mercury around the mid 2000s but I don't know if it was your year. I would look at that starter relay.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
PostPosted: Mon Oct 30, 2017 3:58 pm    Post subject: Reply with quote
Two most common are: starter relay, as above, and corrosion. 12.5 volts with a fully charged battery which should be 12.7 volts is a drop. When you place a load there is just not enough good conductive surface.
Go thru the whole system pull each connection, clean it with a small wire brush, put in a conductive grease and tighten. That is the cheapest --and needs to be done every year or so.
Is the Bendix gear engaging when you get the "click"? That is pulled up as the first stage before the motor rotates. That needs to be kept clean of salt and materials, plus occasionally a light grease application to the shaft.
RickFish
PostPosted: Thu Jan 25, 2018 5:53 pm    Post subject: Reply with quote
After replacing the solenoid to no avail, the bendix was engaging but not turning the motor over. I bought a replacement starter. It was a different style and an improvement over the original design. Motor started on the first try! Looks like it was a bad starter all along, but now I know a lot more about the entire engine electrical system.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu Jan 25, 2018 6:53 pm    Post subject: Reply with quote
I would check the amperage or amps with AC/DC with ammeter
less than $50 from Sears
and
have the batteries load tested
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Thu Jan 25, 2018 6:55 pm    Post subject: Reply with quote
I would clean and tighten the battery connections and on OB side terminal block and down stream to the starter just to R/O poor or bad connections
Page generation time: 0.1119s (PHP: 64% - SQL: 36%) - SQL queries: 24 - GZIP disabled - Debug on
