Joined: 02 Nov 2003 Posts: 20813 City/Region: Pensacola
Posted: Mon Nov 06, 2017 2:34 pm Post subject: Hinkley Dasher |
We have talked about electric boat drive technology in the past. Well, the future appears to be here....in the Hinkley "Dasher". This is a 28'6" LOA, 8'7' beam, 1' 11" draft, and 6500 lb open center console, luxury bay boat. It is a far cry from the the Electric Duffy and Elco boats.
The Dasher has a "cruising speed" of 10 mph, with a range of 40 miles and top speed of of 18 to 27 mph (depending on weight and conditions) with a range of 20 miles.
Several game changers here. First is the use of two 40 Kilowatt hour banks of "Waterproof BMW I3 Lithium Ion batteries", and two 80 hp electric motors. Recharge time of 4 hours, using two 50 amp circuits (probably 220 volts). Features included in house custom 3 D printed titanium hardware and fittings, carbon fiber hull, "hand painted Artisanal Teak" (I think that means that the deck and railings are probably carbon fiber/epoxy resin, that some poor soul spends a hundred or more hours painting to look like teak).
Oh yes, the price: somewhere around $500,000 But then you also have to modify your dock to handle those two 50 amp charging stations....
Only time before we see our first all electric C Dory! _________________ Bob Austin
Posted: Mon Nov 06, 2017 3:02 pm Post subject: |
What a 500K electric boat and NO SOLAR panels
I'm waiting for the electric drive C-Dory with twins.
SleepyC
Posted: Mon Nov 06, 2017 3:39 pm Post subject: |
Harvey,
The electric C Dory with twins can be yours. But the twin 40's are going to cost an additional $24,000 over a single 80 hp. For what ever reason the 80 and 40 "Deep Blue" Torqeedo outboards are the same cost. Well, you say, the $24,000 for an electric outboard, is only about twice what an gas engine is--so what's the rub?
Each battery costs $32,000! 2 batteries are recommended--and 4 are optional.
Also the weight of the 40 and 80 are the same. Either with two batteries is about 1020 lbs. If you option the 80 with 4 batteries, it is going to weigh or about 1660 lbs (you still need a 12 volt battery for the boat's house systems)
You are also going to have to have some way to charge the system--at 80% discharge the 4 batteries are going to take 220volt circuit about 14 hours--and even if I covered the entire roof of my home, it probably would not give enough current...
So motor and battery for a C Dory 22 would run somewhat about $150,000--assuming you wanted a decent range....(A British web site shows lower prices for the batteries--somewhere in the $20K range--so maybe it would be less).
Range: On a conventional small day motorboat up to 3 tons, at a slow speed of 4 knots Torqeedo Deep Blue with two batteries electric outboard engine will have a range of 21 to 60 nautical miles and will have a running time of 5 to 16 hours.
At full throttle, Deep Blue engine speeds increases to 20 to 30 knots, however the range on the Torqeedo Deep Blue electric outboard will drop to 10 to 15 nautical miles and a run time of 30 minutes. These ranges, charges and distances remaining are all shown on the Torqeedo digital read out on the controller, so allowing you to know exactly which range you have left.
So maybe the Hinkley is not such a bad deal after all? |
Joined: 27 Oct 2012 Posts: 3374 City/Region: SW Michigan
Posted: Mon Nov 06, 2017 5:04 pm Post subject: |
For $500K, you'd think it would include a transom!
Maybe it's like the way they used to sell pickups (at least in the south), the rear bumper was BFE. |
Posted: Tue Nov 07, 2017 1:30 pm Post subject: |
Bob, Thanks for all the details. It looks like I am going to keep my current boat and not complain about $3 fuel. It has twins, and that makes me
SleepyC
