dibwit75@yahoo.com
C-Dory Year: 2013
Vessel Name: Buena Vida
Posted: Sat Oct 07, 2017 12:50 pm Post subject: I am getting water under sink, 23' c-dory. Anyone else? |
I get water under sink all the time. Checked for leaks from fittings off of freshwater tank. Nothing found. I have a washdown hose off the tank. Any advice |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2770 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Sat Oct 07, 2017 1:27 pm Post subject: Re: I am getting water under sink, 23' c-dory. Anyone else? |
dibwit75@yahoo.com wrote: | I get water under sink all the time. Checked for leaks from fittings off of freshwater tank. Nothing found. I have a washdown hose off the tank. Any advice |
Loose drain fitting at the sink or hull connection? _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
South of Heaven
Photos: Blue Water
Posted: Sat Oct 07, 2017 2:26 pm Post subject: |
I had this happen on my 25. I traced it back to water leaking from the window. It was always after a big rainy spell.
I was looking for hoses or sink connections too but I think it was rain water....never 100% sure though. I tried to replicate the problem by spraying the windows for a long time but they never leaked! But then other times I'd come to boat after a couple of rainy days and I had water behind the wallas stove area. _________________ <><><> Jason <><><>
Posted: Sat Oct 07, 2017 7:50 pm Post subject: |
I had this happen on my 22. Ended up being the stove drain thruhull fitting leaking. It's usually above calm water, but in waves, the water was splashing in around the thruhull drain where the gasket had partially worn away. Removed and reinstalled fitting with 5200. No more leak! Colby |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Sun Oct 08, 2017 12:24 pm Post subject: |
The very first step is to taste the water with your finger-tips.....fresh or salty?? Once known, you will have narrowed down the search a lot. |
Wandering Sagebrush
Posted: Sun Oct 08, 2017 12:50 pm Post subject: |
Another thought... Where the deck and hull are joined, rivets are used (I believe it is both chemical and mechanical seam), then sealed from the inside. You will see little bumps at about a 6-8 inch interval. You might look at the inside of the hull to see if there is any sign of water trails. |
C-Hawk
Joined: 02 Nov 2003 Posts: 2146 City/Region: Carpinteria / Channel Islands
Vessel Name: C-Hawk
Photos: C-Hawk
Posted: Mon Oct 09, 2017 8:44 am Post subject: |
Do you have a wallas stove? Check the through hull fitting for the exhaust. I used high temp gasket sealer to seal where the exhaust goes through the hull. _________________ Roger
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
God is Great, Beer is Good.... and People are Crazy |
Posted: Mon Oct 09, 2017 3:13 pm Post subject: |
I have had some leakage after a rough crossing, waves 2+ feet, and can hear it gurgling occasionally. Thought it was the sink drain, but that hose was always dry. Turns out is is the Wallas exhaust vent hose. Now I have a plug for that when I'm in anything over 1 foot waves.
SleepyC
