Hoisting my C-Dory
cwericsson
City/Region: Midway
State or Province: GA
C-Dory Year: 1998
Vessel Name: The Adventure Begins
Photos: The Adventure Begins
PostPosted: Sun Oct 08, 2017 8:09 pm    Post subject: Hoisting my C-Dory Reply with quote
If possible I would prefer to hoist my boat rather than trailer launch it.
However, it doesn't come with hoist points.
Have others added hoist points or do you use straps. If so, type, length, and manufacturer of the straps.
Thanks, Carl
PostPosted: Sun Oct 08, 2017 8:46 pm    Post subject: Reply with quote
I think that hoisting a boat, any boat, is better than backing the trailer in. But you have to have a hoist. Is there one near you? Why don't you ask them about how they hoist a boat in? And you need a boat set up for hoisting. For example, Anacortes doesn't launch from bunk trailers, because there's no way to pass the straps between the bunks and boat. So you need a cutout or a roller trailer.
Journey On sits on a roller trailer with front and rear sets of rollers. There's a good starting point: under the front of the cabin and the middle of the cockpit. You're trying to keep the center of gravity in the middle, between the straps.
And don't forget the spreader bars, unless you're using a regular rolling hoist, such as a Travel-all.
How about finding a place that uses a forklift? I believe that places that store your boat and launch it when you call use a fork lift.
cwericsson
City/Region: Midway
C-Dory Year: 1998
PostPosted: Sun Oct 08, 2017 8:49 pm    Post subject: Reply with quote
Thanks, I'll check with the ones who hoist boats near me and find out what they require.
Carl
Carl W. Ericsson
PostPosted: Sun Oct 08, 2017 9:15 pm    Post subject: Reply with quote
Boris, I don't know about Anacortes, but not true for Cap Santa. They launched my boat and I have a bunk trailer. The bunks don't go all the way forward, so no problem putting a strap on the bow. For the stern, they just jacked the boat up slightly with a floor jack and piece of wood, then slid the sling under. Worked fine. Colby
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Sun Oct 08, 2017 9:32 pm    Post subject: Reply with quote
The sling-in marinas around here are just hooking a clip to each of the eyes on the transom, and a strap through the bow eye. They’re launching dozens or more each day without any issues that I’ve heard of. Many much heavier than a c-dory 22.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
Cap Sante told me they do not require bunk slots for boats under 8000 pounds and 26 feet.
I chose to launch at a ramp anyway.
cwericsson
City/Region: Midway
C-Dory Year: 1998
PostPosted: Sun Oct 08, 2017 9:39 pm    Post subject: Reply with quote
My boat doesn't have any transom hoist points, so I would have to install them. If I can instead buy two hoist straps, that would be a lot easier. I can fabricate spreader bars. I know I will have to trailer launch when no other option is available. Thanks.
Carl
PostPosted: Sun Oct 08, 2017 10:01 pm    Post subject: Reply with quote
Where are you launching? I have never known of a commercial lift or crane where you had to supply your own lifts.
The above is interesting, since some of the bow and stern eyes I have seen on various boats are not up to the loads of lifting. I towed my Grady White 20 Weekender--and had to beef up the bow eye just to tow it behind my Symbol MY. Do they require an inspection of the eyes and way they are fabricated and placed into the hulls?
PostPosted: Mon Oct 09, 2017 10:16 am    Post subject: Reply with quote
One of the transom eyes on my boat bent under the load of towing a person on a tube. Wouldn't try lifting the boat that way.
MikeR
City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
PostPosted: Mon Oct 09, 2017 10:31 am    Post subject: Reply with quote
There are probably differences in different parts of the country (like those crazy East coat marina slips vs. "normal" West coast slips, LOL), but Cap Sante Marina also has a "small boat hoist" over by the P/Q docks which the user operates and supplies own straps / harnesses. It's rated for something like 5000 lbs, but they don't allow you to drive a vehicle onto the pier, so you have to un-hitch and push your boat over to the hoist.
I've thought about using it for the 16, but the extra $25 for the regular sling launch that the Marina operates and provide straps for, without having to unhitch and push your boat, makes the regular sling launch a no-brainer given the two choices. And yes, with the regular sling launch at Cap Sante, bunks are not an issue, same as Edmonds.. they usually just charge a little more for the extra hassle of putting the jack or blocks under the transom.
-Mike
22' C-Dory Cruiser (2016)
16' C-Dory Angler (1989)
10' C-Dory Row Boat (1995)
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Mon Oct 09, 2017 12:08 pm    Post subject: Reply with quote
Can not believe what I have just read. Transom tow eyes and bow eyes are for towing. And the actual weight imposed on those components in a towing application, are far different than a lifting situation.
Now to the hull. A hull is built with a backbone of sorts, whether on a trailer or in the water it bears it weight on it's bottom of the hull.
To pick it up at three end points, causes tremendous forces at all kinds of places in the hull. The lifting action is wanting to fold it.
With the sling/strap system ( the more straps the better ) and don't allow the strap system to pinch in the gunnel.
A boat is built to bear/ or lift it's weight bearing on it's bottom.
Cdory 22 Angler
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold)
PostPosted: Mon Oct 09, 2017 1:22 pm    Post subject: Reply with quote
Let me take a swing at the true problem. Why would you not want to use a trailer to launch? far safer and far easier then a sling. Is it a matter of lack of training? Horror stories from friends that have a lack of training? Rust stories from people that don't rinse? Using a trailer is by far the simplest easy cheapest and safest way to get your boat in the water.
So why do you not want to use the trailer you have?
PostPosted: Mon Oct 09, 2017 2:53 pm    Post subject: Reply with quote
I'm with Tom on this one. Simpler, safer, and more convenient. You are not relying on someone else to do the lifting, or something else, (rings and slings), that could fail and make a real mess, nor are you bound to some other time table other than your own.
Trailering is not hard, backing can be learned, and many more launch sites available.
SleepyCMoon
PostPosted: Mon Oct 09, 2017 3:00 pm    Post subject: Reply with quote
oh and remember that every time you use a sling you will be signing a paper that relieves them from any responsibility to damage to your boat EVEN if they drop it>
PaulNBriannaLynn
Vessel Name: TBD
Photos: Lorelei
PostPosted: Mon Oct 09, 2017 4:12 pm    Post subject: Reply with quote
The OP and I are in the same area. There’s a lot of really small “marinas”, that hoist boats in for a small fee. There’s no waivers to sign or anything like that. You back up under the hoist and the salty marina assistant puts it in the water for you. A lot of the ramps get silted in so the hoist is popular here. I don’t suggest anyone use their tow eyes for this purpose, but that’s what I’ve seen time and time again down here. I have a ramp nearby so I’ll probably just use that with my own boat, though we did hoist our Parker in there before we sold it.
Page generation time: 0.1374s (PHP: 77% - SQL: 23%) - SQL queries: 33 - GZIP disabled - Debug on
