Strange overheating alarm on 2008 Honda 135
Ferg
City/Region: Oak Island
Vessel Name: Here & Now
Photos: Here & Now
PostPosted: Sat Sep 23, 2017 6:08 pm    Post subject: Strange overheating alarm on 2008 Honda 135 Reply with quote
If I suddenly take the RPMs down from cruising speed (4400rpm for me) to idle speed, I get an immediate overheat alarm. I shut down and restart, and go on my merry way. It's happened twice now.
Engine has been flushed with Salt-Terminator after each use, new thermostats, newish impeller, good flow from the pee.
I'm guessing it's the sensor switch gone bad.
Thoughts?
PostPosted: Sat Sep 23, 2017 6:27 pm    Post subject: Reply with quote
I saw the same thing on a 150 which I had been running fairly hard, and brought down to idle. The flow seemed to be fine--I suspect that there was some localized overheating--and in the case I had, I brought the engine back up to a fast idle.
I always back down, and make sure that I have not caught a piece of kelp or plastic over the intakes when I get an overheat, I had one time at Powell, that there was so much fine debris in the water, (up San Juan arm), that I had an overheat alarm. I stopped, backed down, and then shut down, and cleaned off the intake--resolved the issue--and I turned around and didn't go further into the debris field.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sat Sep 23, 2017 6:31 pm    Post subject: Reply with quote
Could be sensor(s) or a failing thermostat?
How old are the thermostats?
Brent Barrett
Ferg
Photos: Here & Now
PostPosted: Sat Sep 23, 2017 8:58 pm    Post subject: Reply with quote
Dr. Bob, there was no debris and the intake was clear, that's why I'm thinking it's a questionable sensor.
Brent, the stats have less than 20 hours on them, and I think that if they would have failed, it would be at high RPM
BrentB
Photos: BrentB
PostPosted: Sat Sep 23, 2017 9:31 pm    Post subject: Reply with quote
Can the OB be connected to computer diagnostic software?
Yamaha has one called YDS
Ferg
Photos: Here & Now
PostPosted: Sun Sep 24, 2017 6:28 am    Post subject: Reply with quote
It does have a diagnostic port. That's my next step, but I don't know if the history will show these two events. We'll see
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sun Sep 24, 2017 7:47 am    Post subject: Reply with quote
Are you sure its an overheat warning? My old Suzuki once had an alarm go off and I couldn't figure it out. Then i came to find out it was a reminder for the oil change. The previous owner must have set it to go off at a certain time interval.
Do you have a battery operated temp gun? If you're absolutely sure it's an overheat alarm then I would take off the cowling immediately after it happens again and get different readings from different parts of the block (assuming theres no plastic there). Those guns are very accurate. I bought one and use it on my volvo engine in my new boat.
<><><> Jason <><><>
Ferg
Photos: Here & Now
PostPosted: Sun Sep 24, 2017 8:26 am    Post subject: Reply with quote
It's defiantly an overheating alarm, but as I mentioned in my initial post, it only happens when I suddenly reduce the RPMs. I shut down the engine and immediately restart with no problem and no alarm. If was truly overheating, it would go back into alarm I think
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Mon Sep 25, 2017 12:58 am    Post subject: over heating??? Reply with quote
My 2003 200 hp Honda did the same thing 3 yrs ago. After much typing and a-s scratching it turned out to be the thermostats.
Has not done it for 3 yrs now.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Page generation time: 0.0439s (PHP: 63% - SQL: 37%) - SQL queries: 26 - GZIP disabled - Debug on
