2000 honda 8 hp
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Sun Apr 30, 2017 5:51 pm    Post subject: 2000 honda 8 hp Reply with quote
I have a honda 8 hp made in 2000 I just checked it and have water in the oil anyone have any ideas where it could be coming from . I have alwise flushed it after each use in the salt ,it runs fine no smoke or water vapor coming out the exaust . Anyone have any ideas have looked on line and not found a lot.
Richard
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Apr 30, 2017 6:10 pm    Post subject: Reply with quote
It's pretty common, caused by the engines running too cold and getting condensation buildup from combustion. The cure is a thermostat that opens at a higher temp. Mine did the same thing, it too is around the same vintage.
Your thermostat could also be stuck open.
UncleRichie
Photos: C-Critter
PostPosted: Sun Apr 30, 2017 10:53 pm    Post subject: Reply with quote
Thanks will try and see if it gets more water in it changed the oil but have not changed the thermostat for a while .
Richard
Catman
C-Dory Year: 2017
Photos: Bambina
PostPosted: Sun Apr 30, 2017 11:45 pm    Post subject: Reply with quote
Uncle Richie, good to hear from you, and I'm glad to know you're still enjoying your 22'.
Page generation time: 0.0344s (PHP: 58% - SQL: 42%) - SQL queries: 21 - GZIP disabled - Debug on
