breausaw
Vessel Name: Triple J
Photos: Triple J
Posted: Thu Jun 23, 2016 12:24 pm Post subject: Testing motor on the trailer at ramp |
Okay so I'm going to go test my motor out at the ramp without launching. I've never done this before so I guess my question is do I leave the straps on or take the straps off and just leave it attached at tthe bow.
I'm thinking of leaving the stern straps on to stabilize the boat because I'm going to put it in gear and run the motor up.
I'm heading there now.
Thanks _________________ Jay
Boatless for now but looking |
Joined: 02 Nov 2003 Posts: 20802 City/Region: Pensacola
Posted: Thu Jun 23, 2016 12:39 pm Post subject: |
Leave the stern straps attached, Only put the boat in far enough to bring water up to the "cavitation" plate on the lower unit. If you take the stern strap off, the stern may float and become uncentered on the trailer, Also when you put the motor in gear, it will push the boat forward on the trailer.
Be careful at the ramp--do not run the motor up too much--can cause damage at the end and side of the ramp. _________________ Bob Austin
tsturm
Joined: 01 Nov 2003 Posts: 1134 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Thu Jun 23, 2016 12:49 pm Post subject: Re: Testing motor on the trailer at ramp |
breausaw wrote: | Okay so I'm going to go test my motor out at the ramp without launching. I've never done this before so I guess my question is do I leave the straps on or take the straps off and just leave it attached at tthe bow.
Thanks |
Leave it strapped down so it stays centered on the trailer. Every time I return from Seward to Soldotna I stop at Kenai Lake & do this exact process. Removes / flushes that nasty salt from motors & trailer!
Hunkydory
Joined: 28 Mar 2005 Posts: 2656 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Thu Jun 23, 2016 12:50 pm Post subject: |
It's been no problem with straps left on for us. We do this routinely when leaving salt water, where the wash outs are busy or not available. On the remote ramps we have used, the boat didn't need to be very deep to have the motors immersed enough to be ran safely. _________________ Jay and Jolee 2000 22 CD cruiser Hunkydory
https://share.delorme.com/JuliusByers |
breausaw
Photos: Triple J
Posted: Thu Jun 23, 2016 2:17 pm Post subject: |
Left the straps on had no problem just had to keep pulling the truck forward every once in awhile because the tide was coming in; 40 foot tide today do the math.
Motor still has a problem found a certified verado tech taking the boat there Saturday, overheating problem describe in another thread. |
breausaw
Photos: Triple J
Posted: Thu Jun 23, 2016 2:34 pm Post subject: |
breausaw wrote: | Left the straps on had no problem just had to keep pulling the truck forward every once in awhile because the tide was coming in; 40 foot tide today do the math.
BTW, thanks for the replies |
Foggy
Joined: 01 Aug 2013 Posts: 1519 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Thu Jun 23, 2016 4:52 pm Post subject: Re: Testing motor on the trailer at ramp |
breausaw wrote: | Okay so I'm going to go test my motor out at the ramp without launching. SNIP |
OK. I'll bite. What do you mean by "test my motor out"?
See if it starts? See if it goes into gear?
I get running it in fresh water to remove salt, but "test it out"
I don't get.
Am I missing something here? What's up with this?
Aye. _________________ "I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life. |
breausaw
Photos: Triple J
Posted: Thu Jun 23, 2016 6:00 pm Post subject: Re: Testing motor on the trailer at ramp |
Foggy wrote: | breausaw wrote: | Okay so I'm going to go test my motor out at the ramp without launching. SNIP |
I don't get.
Aye. |
Follow link, all will be revealed.
http://www.c-brats.com/viewtopic.php?t=24294 |
Foggy
C-Dory Year: 2014
Photos: W B Nod
Posted: Fri Jun 24, 2016 7:34 am Post subject: |
breausaw wrote: | Update,
SNIP I took the boat down to the launch ramp and ran the motor up to 3000 RPM in gear, the temperature shot up above 200.SNIP |
In my area (unsalted, clean water, nice ramps), doing this along with "power
loading" onto a trailer is decried and, in some areas, illegal. It washes out
the loose bottom beyond the formed ramp underwater (as noted above) which
can, in time, ruin a concrete underwater ramp and cause hazards for others who
wish to use launch their boat at the ramp in a proper fashion.
My suggestion, to "test your motor out" for the overheating problem, would
be to test it in open water as in normal use and not disturb or congest launch
ramps to the detriment of others.
Aye.
PS: Above confirmed by the Ramp Police. |
Larry H
C-Dory Year: 1991
Photos: Nancy H
Posted: Fri Jun 24, 2016 4:20 pm Post subject: |
Here's my opinion as a retired OB mechanic.
Running in gear at high rpm's on the trailer (backed down a ramp) is not a good test of the cooling system, and not the best idea. Outboard motors are designed to produce high power and cool properly on a MOVING boat. The water flow from the hull onto and around the motor is important. A stationary motor is trying to suck the water from under the hull and trailer (where the water is shallow) to feed the prop and cooling intake. Without the moving boat feeding water to the prop, the prop is sucking water from the sides ahead of the motor. This can suck air down the hull from the chines and draw air into the water pump intake. The trailer bunks further screw up the water flow.
In addition, as mentioned, the prop wash can erode the lake bottom beyond the end of the ramp. If flushing salt from the motor, that salt goes into the lake, where it can cause problems for the fresh water ecosystem. In some areas, flushing salt into freshwater lakes is prohibited by law.
Running a motor (at idle speed), on the trailer, backed down the ramp, is a good way to check out the battery and starter, and to see if the water pump is pumping. It's not a good way to test for overheating. _________________ Larry H
A C-Brat since Nov 1, 2003
Foggy
C-Dory Year: 2014
Photos: W B Nod
Posted: Fri Jun 24, 2016 6:11 pm Post subject: |
Larry H wrote: | Here's my opinion as a retired OB mechanic.
Running a motor (at idle speed), on the trailer, backed down the ramp, is a good way to check out the battery and starter, and to see if the water pump is pumping. It's not a good way to test for overheating. |
Now confirmed by the OB Mechanic Police.
Aye. |
Kushtaka
Photos: Kushtaka
Posted: Fri Jun 24, 2016 9:21 pm Post subject: |
I agree that this isn't a great way to test your motor but for another reason besides it not cooling well. Your prop boat is more akin to a car with a transmission and more importantly a torque converter that allows your engine to unload into the prop as the boat itself gains speed through the water (the torque converter being prop slip). Thus the boat is operating properly with the prop "gripping" smooth water and moving the boat, and can't really be done without the boat moving. That is why you have consistent speed through the water at certain rpms, just like a car does in any given gear.
Thus, on the trailer, your engine has no resistance on it and will gain rpm more quickly and will easily over rev.
Contrast this to a jet boat where rpm = only water volume, and the engine being able to unload normally on a boat at rest. The water being pumped is independent of speed.
As another caution, if your straps extend at an angle backwards from your trailer to their attachment point on your stern they will not keep your boat from moving forward if your bow slips off to one side or another. I've seen it happen. Ugly. Only went a foot or so, but it banged up the front of the boat nicely. |
