Water in Cabin Yet Again
Goto page 1, 2, 3, 4, 5  Next
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue May 31, 2016 7:12 pm    Post subject: Water in Cabin Yet Again Reply with quote
Been battling this problem for several years in my CD22. If the boat sat in water and collected rain in cockpit the cabin filled with up to 2" of water. I knew the seam at base of cabin bulkead was cracked and figured it was the cause. I tried heavy 5200 along seam to little avail. This spring I had the entire seam reglassed professionally including sealing off the drain hole. Today I launched the boat for first time and had to take it back out to address an unrelated issue. In the brief moments it was in the water, I managed to collect a cup of rusty colored water at the step to the berth area. I am totally mystified where this water can possibly be coming from. Is it possible to have water in the hull that is seeping out somewhere? I don't know where to go from here.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue May 31, 2016 7:24 pm    Post subject: Reply with quote
The screw holes for the bronze keel band were sometimes drilled too deeply. Try pulling them to see if you get a drip/wrap from one or more of them. The water is possibly in the floatation foam under the berth.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue May 31, 2016 7:40 pm    Post subject: Reply with quote
Hmmmm. Worth a try. There is some cracking on the corners of the berth entry where floatation water could def seep out.
PostPosted: Tue May 31, 2016 10:17 pm    Post subject: Reply with quote
The brass strip is one place, the anchor locker is another. My boat did not have a good bottom to the anchor locker, and no drain hole. I put in a drain hole, glassed in a tube from a new bottom to the outside.
Some boats have gotten water forward from the deck fittings leaking as well as the rub rail.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue May 31, 2016 10:56 pm    Post subject: Reply with quote
Thanks Bob. I don't have a windlass and don't use anchor locker.
PostPosted: Wed Jun 01, 2016 1:34 am    Post subject: Reply with quote
You may still have an anchor "locker" at the forehead peak of the vee birth and they typically have a drain with a clam shell cover on the Port side above the water line. In heaven water, Big waves or wakes you can get water intrusion into that clam shell. In some cases that drain is not intact, and can allow water to get into the space between the hull wall and the basin of the anchor locker, allowing the water to get down to the space under the portal potty recession.
Embarrased Embarassed
PostPosted: Wed Jun 01, 2016 2:01 am    Post subject: Reply with quote
As others have mentioned, there may be some yellow/orange colored foam in the forecabin (supporting the V-berth footwell area). If water comes in anywhere "above" that it can easily sit in the foam and thus become "rusty" colored. Then later it drains aft...
As said above, the most common culprits for water ingress there tend to be the bronze bow strip screws and the anchor locker tabbing/drain area. It would also be possible that any other leak ahead of the V-berth/cabin bulkhead could seep down into that area and then find its way aft (bow pulpit stanchion bases, etc.).
Compromised core can also cause brown/rust colored water - that might have a sweetish smell, but based on the common findings I'd much more likely suspect the bow strip or anchor locker tabbing areas first. (The anchor locker base may be made of plywood, so that's another thing that may be involved.)
PostPosted: Wed Jun 01, 2016 10:45 am    Post subject: Reply with quote
I had an issue early on with water getting into the cabin of my 22. This is probably obvious, but one thing to check is if the water is salty or not (assuming you're in salt water). If salty, obviously it's through the hull someplace and the brass keel guard is a likely spot. If fresh, it's rain water. In my case, the rain water was getting in through a bad seal around the fresh water fill port. On my previous 22 (a more recent model than yours), the water fill was just forward of the bulkhead on the port side. Just aft of the water fill was a raised bit of glass that was designed to keep water from flowing down the top flat surface of the gunwale and into the cockpit. This raised area creates a little "dam" and water puddles there. With a bad seal around the fresh water fill port, water would run down behind the aft seat cabinet and then seep out on the the cabin floor.
Another possibility is rain water entering though the riveted holes for the rub rail. That can happen anywhere the rub rail is attached and again water can leak behind the cabinetry and run out onto the cabin floor.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Jun 01, 2016 11:14 am    Post subject: Reply with quote
Great info, thank you. Will def investigate the bow guard first as it seems more likely in my circumstances. Should the floatation be saturated, what is the remedy?
PostPosted: Wed Jun 01, 2016 11:40 am    Post subject: Reply with quote
if the floatation is saturated--then removing it, and putting storage in, is the best way to get at it. However, it is probably not saturated.
Is there no deck pipe (for the anchor rode to go into the forward well, in front of the V berth? If there is no deck pipe, then you are correct it is unlikely that water is getting in thru the anchor locker. (which all of the 22's have--look forward of the fiberglass bulkhead forward of the cushions.
PostPosted: Wed Jun 01, 2016 12:13 pm    Post subject: Reply with quote
BTW - for a boat the age of yours (1988) it's unlikely that the brass keel guard screws are the issue. That issue happened mostly in the early 2000 years (like maybe 2002-2004). It's possible that someone made the same mistake 12 years earlier but seems unlikely to me. The issue at the time was installers using screws that were too long and penetrating all the way through the hull. In a boat from 1988, I'd suspect some failing sealant or rub rail rivets as a more likely cause (unless of course it's saltwater).
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Jun 01, 2016 1:01 pm    Post subject: Reply with quote
Thanks Roger. There is a locker but no pipe or other passage from deck. It's salt water as water appeared on launch on a clear day. If floatation is orangy, I suspect from there given color of water. Driving me nuts.
I did have keel damage couple of years ago at tail end of keel from enounter with rock that was repaired and in good shape...
PostPosted: Wed Jun 01, 2016 1:16 pm    Post subject: Reply with quote
Another thing you might look for is damage to the underside from a failed part on the trailer. This can sometimes be hard to see while fully forward on the trailer since the offending trailer part (often a roller) may cover the damage.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Jun 01, 2016 1:20 pm    Post subject: Reply with quote
Roger, just finished bottom painting off trailer prior to launch.
PostPosted: Wed Jun 01, 2016 3:39 pm    Post subject: Reply with quote
Don't assume that it is salt water (without tasting or other determination)--the water may appear because of the "attitude" of the boat when floating vs when it was on the trailer.
Also, is it possible that the water got into the foam/ under the forward area when you had the prior problem, and appears now because of the attitude of the boat in the water?
Page 1 of 5
Page generation time: 0.1417s (PHP: 88% - SQL: 12%) - SQL queries: 33 - GZIP disabled - Debug on
