v-berth "middle" cushion
dread
City/Region: Berkeley
Vessel Name: Tessa
Photos: Tessa
PostPosted: Tue Apr 19, 2016 7:58 pm    Post subject: v-berth "middle" cushion Reply with quote
My 2006 25' Cruiser does not have a cushion in the opening of the v-berth between the starboard and port cushions. (There must be a more nautical way to say that!) Did the boat originally come with that feature? Does the manufacturer carry replacements, or do you know of a good way to build one?
Don Read
PostPosted: Tue Apr 19, 2016 8:22 pm    Post subject: Reply with quote
There should be an insert there. Nothing more than a piece of plywood covered in foam and Sunbrella to fit the space. With some measurements, any marine upholstery shop should be able to make one. Hardest part is sewing the Sunbrella fabric to fit.
PostPosted: Tue Apr 19, 2016 8:29 pm    Post subject: Reply with quote
Journey On came with a cushion between the port and starboard cushions. It covered the space aft of where the 2 big cushions join. There's a couple of strips fastened to the boat to hold it up and two blocks on the bottom of the cushion to hold it in place.
I assume you could call the present factory and ask from where they're getting the cushions. Or make one as suggested.
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Wed Apr 20, 2016 4:51 am    Post subject: Reply with quote
Dessert 1st came with a cushion (kind of a trapezoid shape), but the original owner replaced it with a hinged seat/board. It works very well.
In the space where a cushion would be we keep a Type IV throwable cushion.
We like the arrangement better than original.
Best,
Casey&Mary
Page generation time: 0.0197s (PHP: 60% - SQL: 40%) - SQL queries: 21 - GZIP disabled - Debug on
