Fuel tank sending unit leaks
Carol & Bob Larsen
City/Region: Mattapoisett
C-Dory Year: 1997
Vessel Name: Carol Lani
PostPosted: Sun Mar 06, 2016 9:14 pm    Post subject: Fuel tank sending unit leaks Reply with quote
I have a 20 gal tank that was disassembled by the previous owner for cleaning. The sending unit leaks around the joint when I fill it full. I tried removing it and using Permatex to seal it up, but it still leaks (the Permatex did slow it down some). Any suggestions on how to repair it?
Bob
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sun Mar 06, 2016 9:23 pm    Post subject: Reply with quote
Bob: Sorry, I can't help you with your problem (I'm sure another C Brat will do that shortly!)
It's good to see another Mass. C Dory owner on here! I launch frequently in Buzzards Bay during the warmer months (Bourne/Onset area). Last season I was contemplating heading further west in the water towards your neck of the woods. Now that I have more fuel range I'll definitely do it this year, plus Martha's Vineyard.
Good luck with you fuel leak issue.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Mar 06, 2016 11:32 pm    Post subject: Reply with quote
Mine did that too. They never leaked much, more like an occasional seep, but I finally just replaced the tanks as I don't want gas leaking on the boat.
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Mon Mar 07, 2016 6:20 am    Post subject: Reply with quote
I have the same problem, where can I source new ethanol proof gaskets or gasket sealer?
What if I buy the whole sender, is the gasket ethanol-proof?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Mar 07, 2016 10:30 am    Post subject: Reply with quote
Who makes the tank and fuel sender uni
Posting pics would help
I don't know if this will work but Moeller
has 5 Hole Gasket for Electric Sending Units (Includes Mounting Screws)
# 035728-10
see
http://moellermarine.com/moeller-marine/fuel-accessories/5-hole-gasket-for-electric-sending-units-includes-mounting-screws-035728-10/
or
If a WEMA sender, you can measure it and email them for a gasket. see
http://www.wemausa.com/
Brent Barrett
Carol & Bob Larsen
C-Dory Year: 1997
PostPosted: Mon Mar 07, 2016 5:51 pm    Post subject: moeller gasket Reply with quote
Thanks for the info Brent. I just ordered one from Amazon. I'm sure the old one will be toast after I pry it out of the Permatex. I have a suspicion that one or more of the screw hole may be stripped. I'll try to get the tank out this week...
Bob
BrentB
Photos: BrentB
PostPosted: Mon Mar 07, 2016 6:17 pm    Post subject: Reply with quote
Welcone, Bob
Request an album for pics and
post an update!
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Tue Mar 08, 2016 12:12 am    Post subject: Reply with quote
I replaced the Moeller fuel sending units on my tanks a couple years ago and had the same problem with leaking. Even though the holes in the gasket appear to be evenly spaced, they are not. The gasket will only fit properly in one position. Then be careful not to over torque. There should not be any need for sealant. Good luck, Ken
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Tue Mar 08, 2016 5:23 am    Post subject: Reply with quote
THANKS! Love this site and it's knowledgeable wonderful members.
Page generation time: 0.0921s (PHP: 85% - SQL: 15%) - SQL queries: 27 - GZIP disabled - Debug on
