Gasoline Fittings Thread Sealant
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Mon Mar 07, 2016 8:34 am    Post subject: Reply with quote
I'm at a loss as to why you'd use anything at all on it. I should not be necessary. And it if is, you probably need a new fitting.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Mar 07, 2016 10:19 am    Post subject: Reply with quote
I agree.
Only have used the Permatex aviation sealant shown in the previous message for fuel connections (tank pick up elbow, ASV threads, external fuel filter fittings) and bought a tube of Leak-Lock but have not used it
Brent Barrett
PostPosted: Mon Mar 07, 2016 11:36 am    Post subject: Reply with quote
Some of us worry too much. Laughing
Brass fittings conform very well to the hole they are stuck in and rarely need any help from a sealant.
Steel in steel fittings are generally good dry, but the lubrication and corrosion resistance of a good sealant is a good idea.
Stainless fittings can gall easy and they don't conform to a poor fit very well so a good lubricant/sealant is always recommended.
It is easy to over tighten a tapered thread fitting screwed into aluminum or plastic so a good sealant that remains somewhat flexible gives peace of mind and a lasting seal even as the material relaxes.
When the fitting and the hole it goes into are different metals, a good sealant should be used if only as a corrosion inhibitor, especially on a boat.
As long as it is applied sparingly and above the end of the threads so it does not get inside of the lines, a good sealant should always be used if only as a thread lubricant.
Teflon tape is good enough for water joints, but I don't like it for much else. It is very easy to get strings of it into the product stream.
Anyway, that's what I came to believe after all those years at a paper mill fixing leaky stuff. The first few years I was often fixing my own leaks, so once I discovered how good that Loctite 567 stuff worked I never bothered using anything else.
Page generation time: 0.1081s (PHP: 84% - SQL: 16%) - SQL queries: 21 - GZIP disabled - Debug on
