Gasoline Fittings Thread Sealant
CDory23
Photos: CDory23
PostPosted: Sat Mar 05, 2016 5:38 pm    Post subject: Gasoline Fittings Thread Sealant Reply with quote
I"m doing a complete fuel system overhaul as part of preventative maintenance and because I just completed carb rebuilds and jet changes to my Yamaha Twin 40's. Thanks JOEL-SEA3PO for all of the help! They are running much better then before.
I have completely cleaned all fittings- took some time because the original installer used teflon tape to seal-I feel thats a no no for gas thread sealant.
So what would be the best stuff to use for thread sealant? This stuff?
http://www.starmarinedepot.com/permatex-thread-sealant-with-ptfe-1oz.html?gclid=CjwKEAiApOq2BRDoo8SVjZHV7TkSJABLe2iDg8TucGeEA9mAPKmelSDkHwpC4yKfkgvfQLctd8TESxoC7GLw_wcB
I may be overthinking this a bit much as I have two filters before anything gets to the engine, but I don't want any chances of any deposits clogging up the new carbs or any part of the system.
PostPosted: Sat Mar 05, 2016 6:31 pm    Post subject: Reply with quote
For the fuel systems I use, the fittings arre put together without sealent. I make sure the threads and sealing faces are smooth and crank them together. That seams to hold for bothe pressure and suction.
I have used Permatex products and they are good. That seqalent should work.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Sat Mar 05, 2016 7:08 pm    Post subject: Reply with quote
I just did a project where I looked into this. Permatex makes a couple of different liquid sealant/gaskets. Permashield is the one that is "fuel resistant" to gasoline. From what I could tell, the manufacturer doesn't want to claim "gasoline proof," but it basically is. Plus, it helps lubricate pipe threads so that it's easier to get them sealed properly. I used it on the hose adapters coming out of my fuel filter. Wear rubber gloves, as the stuff you get on your hands can't be cleaned off with gas.
Mark
AstoriaDave
City/Region: Astoria
PostPosted: Sat Mar 05, 2016 7:23 pm    Post subject: Reply with quote
CDory23,
I have used that same PTFE based Permatex threadlocker on fuel systems, and had good results. If your surfaces are very clean, that is enough. The small amounts which may enter the fuel stream should be caught by the fuel filter. Agree the tape can be problematic.
Permatex produces multiple variations on it, all pretty much the same chemistry but with different fillers, etc. That one is just fine. Exclamation
Dave Kruger
Astoria, OR
PostPosted: Sat Mar 05, 2016 7:47 pm    Post subject: Reply with quote
The mechanics I used to work with used Leak Lock, so that's what I use (not that I put together all that many fuel fittings, but when I do). It's not something I researched personally though. No problems on the fittings I did use it on (on my current boat or reported by current owners of past boat).
PostPosted: Sat Mar 05, 2016 8:44 pm    Post subject: Reply with quote
"I'm doing a complete fuel system overhaul as part of preventative maintenance and because I just completed carb rebuilds and jet changes to my Yamaha Twin 40's. Thanks JOEL-SEA3PO for all of the help! They are running much better then before."
CDory23, Just curious. I'm guessing you are not replacing the fill ports and caps, tanks or vents. So that would leave the hoses. Curious what you are using for the replacement hose (type) and approx price for the whole hose system.
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Sat Mar 05, 2016 10:16 pm    Post subject: Reply with quote
Here is another commonly available product I have used with success in the past.
http://eclecticproducts.com/seal-all.html
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Sat Mar 05, 2016 11:43 pm    Post subject: Reply with quote
I see you are asking CDory 23, but I'll chime in too. I replaced my fuel system for much the same reasons (tanks, hoses, vents, separator housing, re-installed fills, etc.). I used Trident Hose, because I like it and am familiar with it, but there are other good marine hoses (Shields, Vetus, etc.).
For the fills I used Trident #329. This is the "Michelin Tire Man" version of their fill hose. I used it instead of the Trident 327/328 (straight versions) because I didn't want the bends to put strain on the filler necks of the tanks (especially the port side one where it dog-legs around the lazarette). The "Michelin Man" version is more flexible (but still plenty stiff for fills).
For the rest of the runs (tank to valve to separator, vents, etc.) I used Trident #365.
I got some Trident #305 (it was recommended to me), but it was a bit too thin and easily kinkable (I felt) for most of my runs. The only place I ended up using it was for one of the internal lines on my Yamaha outboard (#365 would not have fit because the OD is larger for a given size).
CDory23
Photos: CDory23
PostPosted: Sun Mar 06, 2016 6:04 am    Post subject: Reply with quote
Hardee,
I only replaced the fuel feed lines from tanks to filter, selector switch to outboard. I can visually inspect the inside of the other lines and they looked fine. Total was about $180 plus tax. I went with A1 rated fuel line from west marine. 10 feet of 3/8 and 10 feet of 5/16 which should leave me with a little left over. It ran 5.99 a foot. I also bought bulbs for $20 each and new yamaha fuel fittings for $10 each. (one had plastic chipping so will get tossed and keep the other as a spare). I took apart all of the fittings and filter/water seperator bracket and put them in the ultra sonic for an hour since I had it handy from my carb rebuild/rejet project. I even took the tank suction hose out to inspect and it looked great. Hardest part was getting all of the little pieces of teflon tape out of threads of fittings.
I even thought of replacing the fuel line in the outboard itself but thought that would be a little overkill since it looked in great condition and has almost zero exposure to the sun.
To my surprise all of the old fuel lines and even the bulbs which I cut in half to inspect looked great. I"m still happy I did this project though as it was original and 13 years old.
PostPosted: Sun Mar 06, 2016 3:58 pm    Post subject: Reply with quote
CDory23 wrote:
Hardee,
Glad to hear the system is still pretty clean after 13 years. Do you know how many hours were on that system when you got it. I seem to remember there might have been some discrepancy. The OB's you did the carb jobs on are the original ones with that fuel system right?
Sounds like you do good work.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Sun Mar 06, 2016 4:47 pm    Post subject: Reply with quote
When I was doing my tank project I looked at the various fuel line ratings (A2, A1, A1-15). I had some "new" old stuff in the shop that I was going to use, but then I saw that there were new ratings. The newer ratings are based on reduced vapor permeability, not just fire rating. Most of the hose that appeared as bargains on Ebay was the older A2 rated hose.
Mark
RichardM
City/Region: Akron
State or Province: OH
Vessel Name: Pangur Ban
Photos: Pangur Ban
PostPosted: Sun Mar 06, 2016 5:21 pm    Post subject: Reply with quote
I used the yellow (not white) pipe thread tape sold as Gas Line Pipe Thread Tape at the big box. It feels and applies like Teflon tape, and the round plastic pack is similar to the ones for Teflon tape. The label on my roll says it is for gasoline, fuel oil, benzene and a number of other hydrocarbons.
CDory23
Photos: CDory23
PostPosted: Sun Mar 06, 2016 5:54 pm    Post subject: Reply with quote
Hardee,
Yes the OB's I did the carb jobs on are the original outboards twin 2003 Yamaha F40's. There was about 600hrs on the motors when I purchased and now there is about 760. I feel I should be able to get at least 2000hrs out of these motors especially since I seem to be doing all the work on them now.
I decided to go with this as my sealant:
http://www.jamestowndistributors.com/userportal/show_product.do?pid=9403&familyName=Permatex+Aviation+Form-A-Gasket+No.+3+Sealant
PostPosted: Mon Mar 07, 2016 12:04 am    Post subject: Reply with quote
CDory23 wrote:
Hardee,
Thanks for that reply. I would think you should be able to get well over the 2000 hours if you take good care of those OB's.
PostPosted: Mon Mar 07, 2016 12:37 am    Post subject: Reply with quote
I like Loctite 567 for everything - gasoline, diesel, propane, hydraulic, water, compressed air, even the kitchen sink.
It is expensive, but the $20 tube will last for years. It is usually advertised for use on stainless steel fittings because of its lubricating properties to prevent galling, but it is great on all common materials. It also is good on the plastic fittings in the freshwater tanks because it seals well without having to over tighten the threads.
Loctite makes an aerosol primer that speeds the curing to minutes instead of hours for high pressures or sealing looser joints.
Page generation time: 0.1452s (PHP: 61% - SQL: 39%) - SQL queries: 33 - GZIP disabled - Debug on
