A Fishin C Guest
Posted: Tue Feb 23, 2016 8:53 pm Post subject: Wiring Wallas |
Getting ready to install my Wallas 800.
I will wire to battery within an inline fuse.
One battery I have already wired the 2 downriggers directly to with inline fuses.
1. should I wire the wallas to this battery also, or the other one?
2. If the answer is to wire to the other battery, can I start and run my engine switched to both batteries? |
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Tue Feb 23, 2016 9:26 pm Post subject: Wallas |
You need to wire direct to battery with a fuse use the size wire i gave you i had 3 things wired direct trim tabs ,wallas, fridge this is the way it came from cc factory Good luck take care Jim _________________ retired 8/08 from UAL, still working pt tm
jennykatz
Photos: Jennykatz
Posted: Tue Feb 23, 2016 9:27 pm Post subject: Wallas |
There were instructions in the box with wallas |
A Fishin C Guest
Posted: Tue Feb 23, 2016 10:40 pm Post subject: |
sounds good Jim, thanks
will be installing when I get it back serviced from Trotac Marine |
