Quick Question for Possible Fuel Leak
Westie
City/Region: Bodega Bay
Vessel Name: True North
Photos: Westie
PostPosted: Sun Jan 03, 2016 3:49 pm    Post subject: Quick Question for Possible Fuel Leak Reply with quote
Hi there,
Its been a few week since I was at my boat so I drove out today to check on it and run the engines.
I store the boat in a berth with the engines all the way up. When I lowered the engines, I notices a very light film on the water near the port engine; nothing on starboard. I started the engines and everything looked fine but I continued to see film on the port. It was very light but seemed consistent.
I flushed and raised the engines and didn't see anything.
Could I have a leak in the lower unit (gear oil)? I do not recall using a gasket when I did the oil change. What experiences do you have regarding this??? What else should I check?
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Jan 03, 2016 4:19 pm    Post subject: Re: Quick Question for Possible Fuel Leak Reply with quote
Westie wrote:
Hi there,
The Lower Unit drain plug will have a gasket / O ring.
The Engine oil plug will have a fiber or metal gasket.
If carb eng. you could have a little fuel leak from the vent's tilted all the way up. I see you have Suzi's (as do I) they also have a reputation for oil in the exhaust through a failed gasket / seal. Wink
Westie
Photos: Westie
PostPosted: Sun Jan 03, 2016 7:12 pm    Post subject: Reply with quote
Thanks for the reply. Do you think I should pull it out and replace the plugs (along with oil change) or just keep an eye on it?
I have another 45 hours until service is due.
tsturm
Photos: JMR-TOO
PostPosted: Sun Jan 03, 2016 7:44 pm    Post subject: Reply with quote
I am anal about things like that. I would pull it & make sure there are gaskets on the drain, fill & vent lower unit plugs.
Wink
Have a good one!!!!
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sun Jan 03, 2016 10:09 pm    Post subject: Reply with quote
Power trim and tilt would be a place to look also, unfortunately.
Boatless for now but looking
Westie
Photos: Westie
PostPosted: Sun Jan 03, 2016 10:19 pm    Post subject: Reply with quote
breausaw - interesting you say that. My port engine has had some minor issue with trim/tilt. It made a chattering noise a few times when going down. It literally went away after a few times. I was planning to check the fluid level on the next pull out.
Also - the film on the water was really thin. I'm not experienced enough to say it wasn't gas but it had less color spectrum then gas I've seen. Would hydraulic fluid look more black and white on the surface of the water?
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Mon Jan 04, 2016 10:13 am    Post subject: Reply with quote
If you have hydraulic steering , check around the steering cylinder as well . That oil is very light . Feel around in the splashwell and the seals on the ends .
Marc
Wefings Marine Website
Since 1909
breausaw
Photos: Triple J
PostPosted: Mon Jan 04, 2016 9:28 pm    Post subject: Reply with quote
My power trim cylinder failed last year and the sheen looked just like gas, thought it was gas.
PostPosted: Mon Jan 04, 2016 10:23 pm    Post subject: Reply with quote
I saw some sheen, that looked like fuel before I had my SeaStar hydraulic cylinder replaced. As mentioned, that hydro oil is pretty thin. Try picking up the "spill" with an oil absorbent pad and smell it. The fuel will smell.
Page generation time: 0.0353s (PHP: 72% - SQL: 28%) - SQL queries: 26 - GZIP disabled - Debug on
