Pin striping peeling a little bit
Take it EC
City/Region: Bellevue
C-Dory Year: 2012
Vessel Name: Take It EC
PostPosted: Fri Sep 18, 2015 10:46 pm    Post subject: Pin striping peeling a little bit Reply with quote
I had noticed a year or two ago that one of the fine pin striping that surrounds the hull strip peeled in a two inch section. Should I glue it or anything?
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sat Sep 19, 2015 12:48 am    Post subject: Reply with quote
You can buy that pin striping at most any auto parts or auto paint store around.
Chuck
Bootleg Hooch
Take it EC
C-Dory Year: 2012
PostPosted: Sat Sep 19, 2015 1:14 pm    Post subject: Pin stripping peeling a little bit Reply with quote
So do people replace it from time to time.
Spike
City/Region: Kent
PostPosted: Sat Sep 19, 2015 5:42 pm    Post subject: Reply with quote
I have a small section on my boat that is peeling also, just have not got off my butt yet to replace it. I bought the pin striping already. Just have to do it. But I will redo the whole thing instead of trying to scab in an 18 inch section.
PostPosted: Sun Sep 20, 2015 12:48 pm    Post subject: Reply with quote
I had about a half inch showing lose, several years ago.... Stuck it down with some 3M VHB (very high bond) double stick tape. It has not returned. In fact, I would have to look pretty close to find that spot.
PostPosted: Sun Sep 20, 2015 3:09 pm    Post subject: Reply with quote
https://www.masterstripe.com/striping/striping1.htm
I just Googled "auto pin striping".
And to remove the old striping: http://www.autogeek.net/3m-stripe-off-wheel-07498.html
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Sun Sep 20, 2015 4:22 pm    Post subject: Reply with quote
I had a problem with the striping tape around the cabin top brow color. It seemed to have burned thru in several areas from the sun. I ended up buying new 1/4" vinyl striping tape from a company named "Stripeman Graphix Inc." The tape was identified as "tfx premium grade vinyl." It is made in the US, comes in a 150' roll, and is available in a ton of colors. Because I could not get all of the original tape off I had to lay the new tape over the old, which the vendor said would work just fine. It has now been over 2 years and the "new" tape still looks great - like I just applied it. Because it is so micro thin you cannot tell any of it covers old tape. There has been no shrinkage, slippage, burning, or dulling, and it can be waxed over. I am very pleased with tape. I might add, we went with a slightly different color that compliments the boat better and that was a fun byproduct of buying new tape. While 150' sounds like a lot, that was the smallest roll available in 1/4". It was relatively inexpensive so not a problem. I did have plenty leftover and it allowed me to apply the tape without worry of running out. Plus, I can replace sections if ever necessary, which has not been so far. We are very happy with the results.
Rob
Page generation time: 0.1318s (PHP: 64% - SQL: 36%) - SQL queries: 25 - GZIP disabled - Debug on
