Solar Vent Installation
hank clow
City/Region: L'Anse
Vessel Name: Meri Aura
Photos: Meri Aura
PostPosted: Mon Jun 29, 2015 8:38 am    Post subject: Solar Vent Installation Reply with quote
I plan to cut a 3 3/4" hole in the center of the forward hatch to install a solar vent. I did this in a sailboat 20 years ago without a problem. I was told the hatch might shatter.....any comments?
Hank Clow
mccml
City/Region: Montoursville, PA
Vessel Name: Crystal Sea
Photos: Crystal C
PostPosted: Mon Jun 29, 2015 11:00 am    Post subject: Reply with quote
Hi Hank! Glad to see you are working on the boat projects. Here is a link to how other people put their solar vent in the v berth hatch.
http://www.c-brats.com/viewtopic.php?t=999&start=0&postdays=0&postorder=asc&highlight=
Mark
Our Anchor holds,
Mark and Carol
(Crystal Sea)
PostPosted: Mon Jun 29, 2015 1:13 pm    Post subject: Reply with quote
I've cut acrylic, which is what Bomar hatches use, a number of times and it all came out well. Bomar doesn't use Lexan, according to their catalog. Here's a web site on cutting acrylic: Acrylic cutting. Nothing new, except at the bottom is a note on how to anneal the cut. New to me.
I did have a Bomar hatch on a Catalina sailboat that crazed without cutting. Sold the boat, though not because of the hatch.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Jun 29, 2015 7:01 pm    Post subject: Re: Solar Vent Installation Reply with quote
Hank Clow
Put masking tape on both sides, get out your hole saw & go REALY SLOW with steady even light pressure.
PostPosted: Mon Jun 29, 2015 8:32 pm    Post subject: Reply with quote
Might not a hole saw meant for cutting ceramic tile work better than one for wood/metal?
Dreamer
Photos: Dreamer
PostPosted: Tue Jun 30, 2015 12:55 am    Post subject: Reply with quote
Run the hole saw in reverse for the initial cut. It breaks the surface without causing a crack. Then just go slow.
Dreamer- Sold 25 Feb. 2013
hank clow
City/Region: L'Anse
Photos: Meri Aura
PostPosted: Tue Jun 30, 2015 8:39 am    Post subject: Solar Vent Installation Reply with quote
Thanks everyone for your input. One of the many joys of C-Dory ownership is the helpful response from other owners. A shake-down cruise on Lake Superior is coming up followed by the actual installation of the solar vent. Wish me luck.
By the way, we are planning an extended visit to Isle Royale in mid-July and look forward to being joined by any C-Dorys in the area.
Hank Clow
PostPosted: Tue Jun 30, 2015 7:14 pm    Post subject: Reply with quote
Sounds like you won't need it, but just so you know (presuming you have the same Bomar/Pompanette hatch as on many 22's) Pompanette does sell just the replacement lens for the forehatch (and gasket too).
Page generation time: 0.0872s (PHP: 48% - SQL: 52%) - SQL queries: 25 - GZIP disabled - Debug on
