flagold
Joined: 23 Mar 2004 Posts: 951 City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
Posted: Fri Mar 27, 2015 11:13 am Post subject: |
Cool! Do you put some kind of grate or something to hold a pot and pan? More in the "fun because you can do it? category, I suppose! _________________
Joined: 23 Oct 2003 Posts: 5328 City/Region: Warrenton
Posted: Fri Mar 27, 2015 12:07 pm Post subject: |
Pat Anderson wrote: | Cool! More in the "fun because you can do it? category, I suppose! |
It's easy enough to get burned in that category without using fire, especially when it includes alcohol. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
flagold
Posted: Fri Mar 27, 2015 4:32 pm Post subject: |
Pat Anderson wrote: | Cool! Do you put some kind of grate or something to hold a pot and pan? More in the "fun because you can do it? category, I suppose! |
Pat, I didn't, but if you search "penny stove" or "hobo stove" on YouTube you'll see designs that do (for the simple beer-can). This actually came about because of a friend of mine showed me some of these stove designs that would barely have any flame at all and I was thinking, you know with my knowledge of jet engines I could probably make something that would knock his socks off in the flame department.
Succeeded in that.
As mentioned by TyBoo: I doubt seriously I'd light one of these off on a boat, and it's probably not a safe contraption in any environment but simply good knowledge to have if you ever needed it for emergency. |
Blueback
Joined: 02 Oct 2004 Posts: 235 City/Region: Qualicum Beach, Vancouver Island
C-Dory Year: 1990
Vessel Name: Blueback
Photos: Blueback
Posted: Fri Mar 27, 2015 5:35 pm Post subject: Re: Beer Can Jet Engine Alcohol Stove |
This beer can stove has a structural problem--LOL
First--- Aluminum has a very low strength factor when its beer can thin - then add heat and the tensile wall strength is reduced to zip.
Now load it up with a bowl of water and somebody has the potential to get burnt --all in all a hell of a bad idea--IMO _________________ I'm in the third stage of life:
1-Learn to catch fish.
2-Catch fish -hopefully-
3-Work at rebuilding the endangered runs of salmonids on the West Coast |
flagold
Posted: Fri Mar 27, 2015 5:41 pm Post subject: Re: Beer Can Jet Engine Alcohol Stove |
Blueback wrote: |
Now load it up with a bowl of water and somebody has the potential to get burnt --all in all a hell of a bad idea--IMO |
Good observation. If used, it should be simply for the flame and length of burning, below some solid pan holder. |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Fri Mar 27, 2015 6:10 pm Post subject: |
I would hardly call it a jet engine. The thrust generated is probably too small to be measured. It will also only work with the can pointed up because most of the motive flow comes from the convection of the air due to the heat. The foam is not consumed because the alcohol does not actually burn, just the fumes. The alcohol also burns at a very low temperature which does not raise the temp of the foam high enough to combust.
I also think that the venturi effect is limited. There is also already a venturi at the top of the can due to the can taper.
Air is not compacted by a venturi. Basically the same volume of air is going through a smaller opening. This requires a particular mass of air to move faster to all get through the opening. This also causes a lowering of pressure. Putting the holes in the can in the neck of the venturi will draw outside air into the main stream.
Creasing the can to narrow it also greatly reduces its structural rigidity. You can stand on a straight empty drink can. Crease or bend the sides just a little and it will immediately collapse. |
ghone
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
Posted: Fri Mar 27, 2015 8:03 pm Post subject: |
Yikes! |
flagold
Posted: Mon Mar 30, 2015 6:39 am Post subject: |
Turns out, it does have its uses beyond what I thought:
I've been using that design for a boonies retort for mercury for many years. Also a camper heater too. Amazing how important the inside edges being pointed up is as it sure accelerates the oxygen intake. You can regulate the flame height by less holes,great way to warm your camper/tent whatever longer BUT if it falls over what a firey mess. I put a rock/lead weight inside to hold and be more stable. Under the foam the lead doesn't even melt as below the flame. GREAT video Matt and I sure hope 2015 is a goodn' for you and Connie-respect-John
From the golddredger site. |
Foggy
Joined: 01 Aug 2013 Posts: 1580 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Tue Mar 31, 2015 8:12 am Post subject: |
This thing needs a few rocks to surround it and a grate on top.
Then you can safely roast a wiener or two.
Aye. _________________ Keep an open mind just enough to not let your brain fall out. |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Tue Mar 31, 2015 12:11 pm Post subject: |
Flagold, you always get me into so much trouble...... heck I even bought an expensive Minelab metal detector to pick up all the nuggets like you do.... nah ! I think those were gold painted rocks and you faked it...cause all I found was a whole bunch of pull tabs and some ancient beer cans...still have not found a nugget.... and I live in big time gold country... only gold was what I gave the store to buy that thing......
Now, ya got me making hobo torches... what next ? Where do ya find all this stuff...
Yer Pal
Joel
SEA3PO |
flagold
Posted: Thu Apr 02, 2015 4:22 pm Post subject: |
SEA3PO wrote: | Flagold, you always get me into so much trouble...... heck I even bought an expensive Minelab metal detector to pick up all the nuggets like you do.... nah ! I think those were gold painted rocks and you faked it...cause all I found was a whole bunch of pull tabs and some ancient beer cans...still have not found a nugget.... and I live in big time gold country... only gold was what I gave the store to buy that thing......
Yer Pal
Joel
SEA3PO |
Faceting - you've got to get into faceting!
Enjoy that boat! |
