Beer Can Jet Engine Alcohol Stove
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley
flagold
City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
PostPosted: Fri Mar 27, 2015 6:59 am    Post subject: Beer Can Jet Engine Alcohol Stove Reply with quote
Just a short "how to":
https://youtu.be/N5HFN8EiVrI
>Film: C-Dory Buyers Guide<
PostPosted: Fri Mar 27, 2015 11:13 am    Post subject: Reply with quote
Cool! Do you put some kind of grate or something to hold a pot and pan? More in the "fun because you can do it? category, I suppose!
PostPosted: Fri Mar 27, 2015 12:07 pm    Post subject: Reply with quote
Pat Anderson wrote:
Cool! More in the "fun because you can do it? category, I suppose!
It's easy enough to get burned in that category without using fire, especially when it includes alcohol.
flagold
PostPosted: Fri Mar 27, 2015 4:32 pm    Post subject: Reply with quote
Pat, I didn't, but if you search "penny stove" or "hobo stove" on YouTube you'll see designs that do (for the simple beer-can). This actually came about because of a friend of mine showed me some of these stove designs that would barely have any flame at all and I was thinking, you know with my knowledge of jet engines I could probably make something that would knock his socks off in the flame department.
Succeeded in that.
As mentioned by TyBoo: I doubt seriously I'd light one of these off on a boat, and it's probably not a safe contraption in any environment but simply good knowledge to have if you ever needed it for emergency.
Blueback
City/Region: Qualicum Beach, Vancouver Island
C-Dory Year: 1990
Vessel Name: Blueback
Photos: Blueback
PostPosted: Fri Mar 27, 2015 5:35 pm    Post subject: Re: Beer Can Jet Engine Alcohol Stove Reply with quote
This beer can stove has a structural problem--LOL
First--- Aluminum has a very low strength factor when its beer can thin - then add heat and the tensile wall strength is reduced to zip.
Now load it up with a bowl of water and somebody has the potential to get burnt --all in all a hell of a bad idea--IMO
I'm in the third stage of life:
1-Learn to catch fish.
2-Catch fish -hopefully-
3-Work at rebuilding the endangered runs of salmonids on the West Coast
flagold
PostPosted: Fri Mar 27, 2015 5:41 pm    Post subject: Re: Beer Can Jet Engine Alcohol Stove Reply with quote
Good observation. If used, it should be simply for the flame and length of burning, below some solid pan holder.
PostPosted: Fri Mar 27, 2015 6:10 pm    Post subject: Reply with quote
I would hardly call it a jet engine. The thrust generated is probably too small to be measured. It will also only work with the can pointed up because most of the motive flow comes from the convection of the air due to the heat. The foam is not consumed because the alcohol does not actually burn, just the fumes. The alcohol also burns at a very low temperature which does not raise the temp of the foam high enough to combust.
I also think that the venturi effect is limited. There is also already a venturi at the top of the can due to the can taper.
Air is not compacted by a venturi. Basically the same volume of air is going through a smaller opening. This requires a particular mass of air to move faster to all get through the opening. This also causes a lowering of pressure. Putting the holes in the can in the neck of the venturi will draw outside air into the main stream.
Creasing the can to narrow it also greatly reduces its structural rigidity. You can stand on a straight empty drink can. Crease or bend the sides just a little and it will immediately collapse.
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Fri Mar 27, 2015 8:03 pm    Post subject: Reply with quote
Yikes!
flagold
PostPosted: Mon Mar 30, 2015 6:39 am    Post subject: Reply with quote
Turns out, it does have its uses beyond what I thought:
I've been using that design for a boonies retort for mercury for many years. Also a camper heater too. Amazing how important the inside edges being pointed up is as it sure accelerates the oxygen intake. You can regulate the flame height by less holes,great way to warm your camper/tent whatever longer BUT if it falls over what a firey mess. I put a rock/lead weight inside to hold and be more stable. Under the foam the lead doesn't even melt as below the flame. GREAT video Matt and I sure hope 2015 is a goodn' for you and Connie-respect-John
From the golddredger site.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Tue Mar 31, 2015 8:12 am    Post subject: Reply with quote
This thing needs a few rocks to surround it and a grate on top.
Then you can safely roast a wiener or two.
Aye.
"I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Tue Mar 31, 2015 12:11 pm    Post subject: Reply with quote
Flagold, you always get me into so much trouble...... heck I even bought an expensive Minelab metal detector to pick up all the nuggets like you do.... nah ! I think those were gold painted rocks and you faked it...cause all I found was a whole bunch of pull tabs and some ancient beer cans...still have not found a nugget.... and I live in big time gold country... only gold was what I gave the store to buy that thing......
Now, ya got me making hobo torches... what next ? Where do ya find all this stuff...
Yer Pal
Joel
SEA3PO
flagold
PostPosted: Thu Apr 02, 2015 4:22 pm    Post subject: Reply with quote
Yer Pal
Joel
SEA3PO
Faceting - you've got to get into faceting!
Enjoy that boat!
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley All times are GMT - 5 Hours
Page generation time: 0.1689s (PHP: 89% - SQL: 11%) - SQL queries: 30 - GZIP disabled - Debug on
