Adding stabilizer
RobLL
City/Region: Bremerton
PostPosted: Sat Feb 07, 2015 6:51 pm    Post subject: Adding stabilizer Reply with quote
I finally got fuel stabilizer. How do I it to mix well with tanks almost full? Am I apt to create a problem not well mixing them somehow? My two 20 gallon tanks are: one is full (18 gallons?), and the other about 15 gallons.
PostPosted: Sat Feb 07, 2015 7:03 pm    Post subject: Reply with quote
My preference is to put the stabilizer in first, then add the gas on top of it. I do believe it will disperse in the gas, though. It is also important that you run the engines to get some stabilizer going through the carb or fuel injectors. Then, completely drain the carb and bowl.
PostPosted: Sat Feb 07, 2015 7:22 pm    Post subject: Reply with quote
I think Jim is right on. Add the Stabil when you are filling the tanks. That mixes the mess very well, then as he says, run the engines. If you add it every time you fill then you have no worries abut whether it gets run up into the carbs. My preference, (coming from my mechanics,) is to add it at the higher concentration each time. That way no problem if the boat sits for an extended period. (I have had mine sitting for up to 6 months one time, and it started right up.) It's really better if you run the boat more often Laughing
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sat Feb 07, 2015 7:34 pm    Post subject: Reply with quote
What type of gas and which full additive? How long with the gas be stored? curious
Brent Barrett
RobLL
PostPosted: Sat Feb 07, 2015 8:10 pm    Post subject: Reply with quote
"What type of gas and which full additive? How long with the gas be stored? curious"
My marina supplies only non-ethanol gasoline
Sta-bil Marine
I run my boat some every few weeks, usually more often
BrentB
Photos: BrentB
PostPosted: Sat Feb 07, 2015 8:12 pm    Post subject: Reply with quote
thanks
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sat Feb 07, 2015 8:20 pm    Post subject: Reply with quote
Put your stabilizer in and tow your boat around the block on er or twice.
Chuck
Bootleg Hooch
RobLL
PostPosted: Sat Feb 07, 2015 8:25 pm    Post subject: Reply with quote
LOL - I'd have to ask the giant 'hyster' to drive it around the marina a couple times.
AstoriaDave
City/Region: Astoria
PostPosted: Sat Feb 07, 2015 9:45 pm    Post subject: Reply with quote
RobLL, if you have a little free space in those tanks, mix the stabilizer with a quart to a gallon of fresh gas and add that mixture to the tank. Then rock the boat to agitate the tanks. Cheaper than a session at the gym. Get your spouse sold on C-Dory Pilates, and it will be mixed in a jiffy!
Dave Kruger
Astoria, OR
fishingmark
City/Region: Kelseyville
Vessel Name: c-yah
PostPosted: Sun Feb 08, 2015 11:13 pm    Post subject: Reply with quote
Just dump the stuff in will mix well with the fuel in the tank. Good idea to run some fuel through your motor too.
Page generation time: 0.1736s (PHP: 85% - SQL: 15%) - SQL queries: 28 - GZIP disabled - Debug on
