Anchor rode fray
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Mon Jun 30, 2014 8:11 pm    Post subject: Anchor rode fray Reply with quote
I ran my anchor line out yesterday and notice a couple of spots where it is starting to wear. How much wear does everyone allow before they replace it? Would you even consider doing a splice?
Jody Kidd
KE7WNG
Northern, Utah
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Mon Jun 30, 2014 8:29 pm    Post subject: Reply with quote
Depending on where the wear is you may be able to just reverse the line so that the worn part is farther in than you normally use. That would mean doing an eye splice and thimble on one end and a rope to chain splice on the other end. There is a "long splice" intended to join lengths of line together. I have used it to extend the length of my anchor line from 200' to 300' with the splice so far in I rarely see it. Not sure just how much wear is ok. If I saw several strands worn through I'd replace the line, it is a lot cheaper than your boat.
Patti and Barry
formerly C-Cakes, now
rving around N. America
jkidd
PostPosted: Mon Jun 30, 2014 9:45 pm    Post subject: Reply with quote
well it's about 75 feet out and about 1/3rd the way through one of the 3 strands.
PostPosted: Mon Jun 30, 2014 9:55 pm    Post subject: Reply with quote
My concern is that you are using a rope grip type of windlass. I suspect that the wear is due to the windlass. I have never done a long splice on a rode which is used on a rope grip gypsy, but I would be concerned that the long splice would not hold up.
I agree with end for end the line, and doing a new rope to chain splice. If it is a 150 foot line, and that place will still be under wear, then I would consider a new rode.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Mon Jun 30, 2014 10:19 pm    Post subject: Reply with quote
Jody, based on your description, I'd just replace the line. Use the left over to practice splicing, make dock lines, etc. and, if you intend to boat where you may be anchoring in 25-35' of water you may want to consider increasing the length to 200'.
jkidd
PostPosted: Mon Jun 30, 2014 10:21 pm    Post subject: Reply with quote
It's 1/2" X 200 ' I suspect that it piled before it went through the deck and jammed and that is what caused it. According to the manufacture the C-Dory doesn't have quite enough distance between the deck and the anchor locker. so sometimes it can be a bit temperamental. So what are some of the better brands of line to buy?
PostPosted: Tue Jul 01, 2014 1:09 am    Post subject: Reply with quote
Many people are going with 8-plait, for example, Yale Brait. I haven't used a windlass yet (getting up my nerve to drill that big hole), but I have 200' of 1/2" Brait, and I can say that their claims of it packing down better (smaller) in the locker are true (as compared to three-strand). That may give you more "fall" in future, for the same length rode. I was just reading the instructions for the Lewmar 700 horizontal and it calls for at least a 12" fall.
Along those lines, I was just thinking today that I could move the windlass aft a bit if I used a different foredeck cleat (I have one on hand that is 8" vs. 10" but is actually the same effective size as it is beefier/higher). That would put the rode a bit further aft/deeper... maybe that would be a good thing (but I was also thinking it might cause mud, etc. to spatter into the v-berth). Ironically, I had just decided to mount mine right about where you put yours..... Crook
I don't exactly know why, but I've lined up and re-lined up this windlass about 200 times! (Before drilling.)
Anyway, back to the Brait. I really like it. Does pack down small, doesn't seem prone to hockling, etc. About the only thing I think might be a negative is that it seems like it could be "pickery." But I'd think that if that were a problem it would be more on wooden docks or rough pilings, so not anchor rode type places.
PostPosted: Tue Jul 01, 2014 1:14 am    Post subject: Reply with quote
You can buy cheaper lines. But I find the companies such as New England Ropes, Sampson and Yale are the quality nylon ropes. I have found that the cheaper lines tend to heckle more, and may be stiffer. one half inch is going to run about $.60 a foot.
I got 300 feet of 8 plait 1/2" line and 30 feet of G4 1/4" chain, in the 22 anchor locker. the 8 plait stores in less space of the 3 strand. (but not really cheap). I believe mine was 80 cents a foot.
I made a Sunbrella panel which is screwed into the back of the small fiberglass anchor locker bulkhead, and attaches just under the deck (a 1/2" dowel is the upper support).
jkidd
PostPosted: Tue Jul 01, 2014 9:24 am    Post subject: Reply with quote
Thanks for the replies. Looks like I will be replacing mine with 8 plait and 30' of chain. Does anybody have a recommendation as to where to buy from?
Water Bill
City/Region: Lake Keowee, SC
State or Province: SC
C-Dory Year: 2018
Vessel Name: Mystery Girl (Ranger Tug R-23)
Photos: Mystery Girl and C-Swell
PostPosted: Tue Jul 01, 2014 10:22 am    Post subject: Reply with quote
Jody,
I purchased an 8 strand plaited anchor rode from Defender. It came pre spliced with 275' of rope and 25 feet of 1/4" G4 Hi-test chain. I believe it was item 001514. I use it with my old Simpson Lawrence Sprint 400 vertical windless and have no complaints. It feeds into the anchor locker with out any problem. Defender puts it on sale every once in awhile. If I remember right what I saved on the sale price covered the shipping cost.
Bill
PostPosted: Tue Jul 01, 2014 11:02 am    Post subject: Reply with quote
I also got mine from Defender. Did my own splice.
jkidd
PostPosted: Tue Jul 01, 2014 11:18 am    Post subject: Reply with quote
How hard is it to do the splice on 8 plait?
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Tue Jul 01, 2014 1:43 pm    Post subject: Reply with quote
Mine was from Defender too. 50 foot of chain & 250 ft 1/2 in 8 plait. I had them do the splice, being I know it's the place the windless will most likely slip on the rode if not done very well. They did a very good job & I still get at the splice occasionally a momentary slip. I have in the past made a few of these splices, but only with three strand & they didn't look professional, like I imaginable Bob's do.
jkidd
PostPosted: Tue Jul 01, 2014 2:02 pm    Post subject: Reply with quote
I spoke to the folks at Defender they told me that the brand of rope they use is Buccaneer this isn't one that I had heard of. Is that the brand they used on yours Jay, Bob, Bill. My last rode was 20 feet of chain and 200 feet rope. I'm thinking I want at least 30 feet of chain and 275 feet of rope. Does that sound like it will work?
Hunkydory
PostPosted: Tue Jul 01, 2014 2:27 pm    Post subject: Reply with quote
The rope I purchased was advertised as New England when I purchased it two years ago, but if I remember right at that time there were several different suppliers to choose from. There set pieces at the time came in lengths like Bill bought. I had to do a custom order to get the 50 ft of chain with 250 of rope, but could also of got most any other combination desired. I can't remember the exact price, but I do remember thinking it was reasonable.
Page generation time: 0.0547s (PHP: 65% - SQL: 35%) - SQL queries: 32 - GZIP disabled - Debug on
