Mechanical Steering
cbadmin
PostPosted: Mon Oct 27, 2003 4:21 pm    Post subject: Mechanical Steering Reply with quote
From: Mike (Original Message) Sent: 2/25/2003 8:27 PM
I got good news and bad news. The good news is my stiff, and nearly frozen, steering was due to crud inside the tilt tube or steering tube or whatever you call it. The cable is free as can be. The bad news is, I'm waiting another season before upgrading to hydraulic steering. It's a money thing.
About that tube. It is the hollow tube with threaded ends upon which the motor tilts. The steering cable nut attaches to one side. When I got the cable out, finally, there was some pretty stiff crud packed around it in the tube. I cleaned and polished everything, including the bore of the tube, and put it back together with some grease on all the moving parts. I was surprised to see that the grease zerks for the tilt pivot did not feed a little grease into the tube as well. I expected to find a hole or two to allow the grease to get in and lube the cable mechanism. If the only grease that the sliding cable end gets is what I smeared on there, then it is probably best to pull the cable out more frequently than once a year. Is there some way to freshen the grease in there that I am missing? I also figured there should be some lip seals or wipers of some sort, but the ends of the tube are open to the elements. Weird. Who invented this stuff?
She spins easy now. I can go lock to lock with one finger spinning a spoke of the wheel.
Mike
Mike,
There is a seal on the port end of the tilt tube; the starboard end is covered by the cable nut.
Honda’s main concern regarding the tilt tube zerk fittings (from a manufacturer’s standpoint) is that the tilt tube itself is lubricated so that there isn’t an issue with the motor tilting (or not). Maintenance on the cable is up to the owner (or his/her mechanic). Remember, Honda has no idea what kind of steering is going to be used on the engine; if it is hydraulic there is a solid stainless shaft going through the tilt tube, if the engine is one of a pair (as on the TomCat) there isn’t anything going through the tilt tube and having grease feeding in there wouldn’t be a good thing.
Les
Aha! I don't have one of them seals. It must be housed in a nut of some sort that threads onto the port end of the tube? I'll take a look at the local marine store. It seems I saw some nuts on the rack with a little zerk fitting in them. Would that be the deal?
Thanks, Les. It really bugged me to see the one end of that tube without any protection.
Mike
Mike,
The big nut on the port side has an o-ring inside it; there aren’t any exposed threads on which to mount one of those nuts with zerk fittings. One end is not unprotected.
Les
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Tue Nov 09, 2004 5:07 am    Post subject: Reply with quote
I have the Teleflex cable system on our 2003 Cruiser, powered by a Honda 90. The CDory Owners Manual, page 6, Steering System, states as follows: "Keep all moving parts clean and free from build up of salt and other foreign material. This will affect their operation and create steering problems. Pay particular attention to the hinge tube of the outboard. Periodically remove the cable from the tube and clean and re-lubricate it with waterproof grease."
I think I can figure this out from previous posts, but want to be sure what the procedure is. Do you remove the outboard nut on the starboard side of the motor mount, then (somehow) get the cable loose (how?), dig out the old grease from the tube, repack, and reassemble? Any tricks here I should know about?
Thanks in advance.
2003 CD22 Cruiser with Honda 90
Grazer
City/Region: Yukon
State or Province: YT
Vessel Name: C-Horse
Photos: Grazer
PostPosted: Mon Jan 06, 2014 4:20 pm    Post subject: Reply with quote
Hello All,
I just wanted to resurrect an old thread to do some annual maintenance to my steering system. I want to pose the questions that "Almas Only" requested back in 2004. Anyone with advise and procedures on how to conduct maintainance on Teleflex NFB mechanical steering systems would be appreciated.
Grazer
PostPosted: Mon Jan 06, 2014 4:47 pm    Post subject: Reply with quote
http://m.youtube.com/watch?v=b4-L_VaKBLM&autoplay=1&desktop_uri=%252Fwatch%253Fv%253Db4-L_VaKBLM%2526autoplay%253D1
I have not had Mechanical steering since I was a kid (they had not invented hydraulics at that time). Hope this video will help! Laughing
Grazer
City/Region: Yukon
Photos: Grazer
PostPosted: Mon Jan 06, 2014 5:51 pm    Post subject: Reply with quote
Thanks Captain's Cat. Seen that video, but it doesn't detail the actual disassembly or other procedures. On another note, I did find a detailed procedure on mechanical steering maintenance from Alma's Only found here
http://www.c-brats.com/viewtopic.php?t=3032&sid=d461949b6d5910adc3e958871cb0f051
Grazer
Almas Only
Photos: Alma's Only
PostPosted: Tue Jan 07, 2014 7:51 am    Post subject: Reply with quote
http://www.c-brats.com/modules.php?set_albumName=OutboardsandSystems&id=Steering_Lube_01&op=modload&name=gallery&file=index&include=view_photo.php
See foregoing, which is the first of a set of photos that show the process. Let me know if you have questions. I'll send the Honda part number for the o-ring separately.
Almas Only
Photos: Alma's Only
PostPosted: Sat Jan 11, 2014 7:39 am    Post subject: Reply with quote
Steering shaft/tube o-ring is Honda PN 91352-ZV5-000.
Page generation time: 0.0407s (PHP: 70% - SQL: 30%) - SQL queries: 24 - GZIP disabled - Debug on
