Sailrite Insulation Option
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Nov 25, 2013 10:05 pm    Post subject: Sailrite Insulation Option Reply with quote
My wife and I insulated the Vberth with this product last winter and are very pleased with it after a years use. We plan to do the remainder of the cabin on our 22 this winter. It is available at Sailrite.com. To complete the Vberth took 6yds. of Item 769, "Headliner Foam Backed White 54 in." at $197.70. It took one can of aerosol adhesive Item 73211 "3M General Trim Adhesive" at $18.95. All seams were taped with white 3M Duct Tape from the local building supply. It took us about two hours to complete the Vberth. The product is fairly form fitting as you can see from the pictures. The liner is 1/4 in. thick so provides good insulation value.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Nov 25, 2013 10:12 pm    Post subject: Reply with quote
[/img]
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Nov 25, 2013 10:13 pm    Post subject: Reply with quote
willronco
City/Region: Everett
Vessel Name: BREVITY
PostPosted: Tue Nov 26, 2013 12:58 am    Post subject: Reply with quote
That looks GREAT!
Does it help with condensation?
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Tue Nov 26, 2013 9:27 am    Post subject: Reply with quote
We have not had any moisture in the Vberth since installing. Here is the link for more detailed description and installation video:
http://www.sailrite.com/Headliner-Vinyl-Bright-White-Foam-Backed-White-54#.UpSub3-9KSM
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Nov 15, 2015 7:08 pm    Post subject: Reply with quote
How is the material doing after 2 years?
Brent Barrett
BrentB
Photos: BrentB
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Sun Nov 15, 2015 7:34 pm    Post subject: Reply with quote
Good question Brent. We have been looking at two products from Sailrite in anticipation of lining the berth on our Tom Cat. We got very small samples of the foam backed headliner and nauga soft vinyl. I too am curious how it has held up.
Margaret, Gene & Docker
tight lines
PostPosted: Sun Nov 15, 2015 8:31 pm    Post subject: Reply with quote
I haven't used this specific product, but I have taken down a number of similar older headliners (open celled foam with vinyl covering) in other boats (Albins had them). Because the foam is open-celled, they had absorbed a lot of moisture and gotten moldy. Ugh.
This may not be an issue in some C-Dory's because they may be used in dry climates, and/or stored indoors or under cover; but if you do use one in a moist environment, it's something to think about.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sun Nov 15, 2015 11:57 pm    Post subject: Reply with quote
After a couple of years we are still very pleased with the product. It looks great and has eliminated condensation in the vberth. There is no moisture or mold between the hull and the material. It adheres good to the fiberglass and has not separated anywhere.
My wife and I did the install in an afternoon and if I remember right the cost of the insulation and aerosol adhesive was $200. No regrets. Ken
Gene Morris
Photos: Reefmadness
PostPosted: Tue Nov 17, 2015 9:19 am    Post subject: Reply with quote
Has anyone installed nauga soft or other vinyl that does not have the open cell foam back? We live and play in a very wet region. We are concerned that moisture will get into to foam back headliner. Just wondering if the unbacked vinyl (nauga soft) will provide adequate insulation.
PostPosted: Tue Nov 17, 2015 11:04 am    Post subject: Reply with quote
I can't say whether Naugahyde alone will be enough (it's obviously basically no R-value, but the change in texture might still be enough for you), but you might consider something from Armacell or similar. This would be a thin, flexible closed cell foam that could be painted or have something (Nauga...) adhered to it. I used to have a camper with a similar product glued to the walls from the factory (Ensolite) and know a few people who have insulated their sailboats with an Armacell product. It doesn't absorb moisture, being closed cell.
PostPosted: Tue Nov 17, 2015 4:33 pm    Post subject: Reply with quote
Only if there is an air space or foam (best closed cell) will any of the vinyl fabrics help with the condensation issues.
I used a closed cell PVC foam on several boats, and can no longer find it on the market. It was about 1/8" thick, conformed well to the surface, and glued well with 3/M spray adhesive. It was made in France, and I got it thru a distributer in Canada back about 30 to 35 years ago.
PostPosted: Tue Nov 17, 2015 6:15 pm    Post subject: Reply with quote
There is a product I used to use for a whole different purpose, called PeLite, a thermoplastice, closed cell foam in various thickness and densities available through JMS Plastics Supply. It is an excellent insulator, and in the denser version might be an excellent product for this purpose. It is not cheap, but it glues well with 3M spray glue and molds with heat to fit curves and crevices. For this type of use I would recommend the medium (at least) or the dense or Firm versions.
JMS Plastics Supply, Inc.
3535 Route 66, Building #4, Neptune, NJ 07753-2625
Voice: 732-918-8115 or 800-342-2602 Fax: 732-918-1131
http://www.jmsplastics.com/thermoplastic/pelite.php
Gene Morris
Photos: Reefmadness
PostPosted: Tue Nov 17, 2015 9:14 pm    Post subject: Reply with quote
Thanks for all the input. Looks like the sailrite foam backed vinyl may be the best bet. Would like to have the "cave" insulated before we head to Alaska.
Page generation time: 0.2277s (PHP: 15% - SQL: 85%) - SQL queries: 32 - GZIP disabled - Debug on
