Center opening windshield wiper?
William and Beth Tucker
City/Region: Ocean Isle Beach
Vessel Name: c-dory
Photos: William and Beth (Name TBD)
PostPosted: Sun May 06, 2007 7:03 pm    Post subject: Center opening windshield wiper? Reply with quote
Has anybody installed a manual windshield wiper on the center opening window on a 25ft. C- Dory ?? Keep your life jacket on > Tucker
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Sun May 06, 2007 7:39 pm    Post subject: Reply with quote
I stuck one on the center window of the 22. It sweeps a small area but it sure nice to be able to see out of that small area. If I want to open the window fully I have to open it enough to get my hand out there to park the wiper below the window frame. here's a pic
http://www.c-brats.com/modules.php?set_albumName=innerds&id=wipe3&op=modload&name=gallery&file=index&include=view_photo.php
Ken
1999 22' boaterhome
Vessel Name: c-dory
PostPosted: Sun May 06, 2007 9:58 pm    Post subject: Reply with quote
Thanks Ken for the information and picture... My wife is tired of crawling outside in the rain to clean the center window.. I told her i could take it out but i think a wiper could save our marriage....Keep your life jacket on ! Tucker
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Mon May 07, 2007 1:50 am    Post subject: Reply with quote
You mean like this:
See some other pictures starting here.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Vessel Name: c-dory
PostPosted: Mon May 07, 2007 11:01 am    Post subject: Reply with quote
Thanks !This will save our marriage for sure >plus she will not have to work the manual lever... Thanks for the picture... Is there any thing i should know before installing a electric wiper on the center window ? Does the center window open just as far as it did defore the wiper was installed ?? If not ,how much was lost ?? I thank everyone for input and ideas.. Keep your life jacket on! tucker
Dora~Jean
Photos: Dora~Jean
PostPosted: Mon May 07, 2007 11:09 am    Post subject: Reply with quote
Yes, the window opens fine, might lose an inch or so at the top when the wiper arm hits the brow, but I never open it that far. Only trouble I had was finding the right wiper assembly, couldn't find the one the factory used with the shorter spindle, so finally gave up and bought the 2 1/2" (I think) standard unit. Had to build a wood spacer block on the inside to compensate. One of my nicer mods IMHO. I can measure the wiper blade size I used, that will help.
I use that wiper nearly every trip, the passengers appreciate it as much as I do. In fact, I installed a duplicate set of wiper switches on the passenger side for the port and center windows only. Then they can have charge of their own viewing!
james
City/Region: CRYSTAL RIVER
Vessel Name: COOL CHANGE
Photos: COOL CHANGE
PostPosted: Mon May 07, 2007 11:31 am    Post subject: Reply with quote
Try "RAIN-X"
I hardly have to use my wipers, plus it helps to prevent the salt water(if you are in salt water) from etching the glass.
James
"Beware of the man with no weaknesses, he is not to be trusted." Lin Yutang, The Importance of Living.
PostPosted: Mon May 07, 2007 12:15 pm    Post subject: Reply with quote
Steve-
Nice job! Clean installation, and simple! Your CD-25 looks great!
For those of you with a 22 ft C-Dory, the space in which the motor is mounted on Steve's (original Cruise Ship model) CD-25 is unavailable, as the overhead electronics shelf comes in right at the top of the window. (Newer models, especially with the high top, may not be this way.)
The bottom of the window is also blocked, this time by the dash tray.
I once tried to mount an electric center window wiper on my '87 CD-22 by putting the motor in the strut between the center and port windows, but there were difficulties regarding the sweep angle of the motor I had.
I do, however, think it can be done. Most of the better motors available today have the sweep angle adjustable for 45, 60, 80, or 110 degrees, and one of the two lower settings should work.
You also have to make a number of adjustments when doing W/W work, changing the wiper arm length, wiper width, sweep, and motor arm position and length as necessary, and often an adjustment in one component requires changes in the others!
It would also probably be possible to use a pantographic set up, where the blade sweeps parallel to the window frame rather than radially. This would clean a larger portion of the window.
All of this is complicated by the need to open the window for ventilation, etc,
I didn't have that issue with mine, since the older boats don't have an opening center window, but I modified the project since I rarely really need the full electric capability, and just went with electrics on the port and starboard windows and a manual wiper set up on the center one.
Rain-X is a great, simple solution without all the headaches!
Joe,
Dora~Jean
Photos: Dora~Jean
PostPosted: Mon May 07, 2007 7:49 pm    Post subject: Reply with quote
Thanks for the compliment Joe (BTW, I only take pictures of the 'good' parts of my boat, the rest, well...lets just leave it to the imagination).
Good points on the installation of wipers. Yes, I had to adjust the sweep angles (a little fun with the cryptic instructions they give you) and the wiper length. I too use Rain-X, exterior type on outside and inside for fog. It does work well, but in poor light (i.e., nighttime), the wiper really helps. Also for spotting those elusive dolphins a mile out.
On the CD-22, would it be possible to notch out the overhead shelf to install a wiper assy up there? Just guessing, not familiar with them.
beermanPDX
City/Region: Portland
Photos: Jean Marie
PostPosted: Wed Oct 23, 2013 12:59 pm    Post subject: Reply with quote
Reviving an old but relevant thread. I added a $40 manual wiper to my center opening window last weekend. I'm kicking myself for not doing it sooner. The install took 15 minutes. The window opens fully with no interference from the wiper arm at all. When not being used, the wiper parks to the side so it's not in view. Granted, it's not a pantographic arm, but it clears an adequate area of the window so I can finally see!
Sorry for the bad cell phone picture. The wiper handle is next to the clock and the wiper arm is shown mid-sweep in the center of the window. The handle looks far away, but I can reach it from the seat.
Cheers Beer
Rob
2008 25 Cruiser - Sold
2002 Nordic Tug 32/4 - Sold
1989 40 Tollycraft Sport Sedan
jerry97230
Vessel Name: C NILE
Photos: C NILE
PostPosted: Thu Oct 24, 2013 11:25 am    Post subject: Reply with quote
I want to move my wiper motor but can not get the cover off to unbolt it.
What is the secert? Have not gotten aggressive, not not want to break it yet.
Jerry C Nile C22
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Thu Oct 24, 2013 12:10 pm    Post subject: Reply with quote
you have to remove the wiper arm outside (good luck with that!) in order to get the motor off.
Patti and Barry
formerly C-Cakes, now
rving around N. America
jerry97230
Vessel Name: C NILE
Photos: C NILE
PostPosted: Fri Oct 25, 2013 11:19 am    Post subject: Reply with quote
Actually I have had the arms off but do not see where that gains me anything.
Have not put alot of effort into this yet as it is down the list a bit, but.
Jerry C Nile C22
Page generation time: 0.0413s (PHP: 68% - SQL: 32%) - SQL queries: 30 - GZIP disabled - Debug on
