5200 still good
PostPosted: Sat Oct 19, 2013 6:34 pm    Post subject: 5200 still good Reply with quote
FYI. I tend to use 3M 5200 in small amounts. So having a whole tube cure after using just a little bit is a big waste. I found that if I use a bit of plastic wrap (or a baggie) over the nozzle (under the cap) and keep it in the refrigerator it will last a long time. Today I used some 5200 from a tube that has been in the fridge for at least 4 months and it was fine.
PostPosted: Sat Oct 19, 2013 7:01 pm    Post subject: Reply with quote
Put it in the freezer, Saran wrap the whole tube, double on the spout. I was give one door shelf for my sealing compounds by the Admiral.
hambone
PostPosted: Sat Oct 19, 2013 11:25 pm    Post subject: Reply with quote
Yep!
Hawg Hunter Productions.
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Sun Oct 20, 2013 5:58 pm    Post subject: screw it Reply with quote
I screw a sheetrock screw into the spout, and it seals it fine. I used it over and over for months. And it still hasn't dried out.
Page generation time: 0.042s (PHP: 55% - SQL: 45%) - SQL queries: 21 - GZIP disabled - Debug on
