Another Battery Question... Help!
Goto page 1, 2, 3, 4  Next
caution
Vessel Name: Caution Horse
PostPosted: Mon Aug 01, 2005 11:06 pm    Post subject: Another Battery Question... Help! Reply with quote
There was a lot of great information on batteries and electrical in some of the threads, which I'm still absorbing, but I have some specific questions and need to get straightened out in time for a trip to the San Juans the day after tomorrow.
We have a 2004 CD-25 that came from the factory with a refrigerator, Wallas stove, 2 batteries (one deep cycle for the house, one non-deep cycle for starting), and a VSR (voltage sensing relay). The VSR was installed by Sportcraft Marina down in Oregon. We have a Honda 150 main, plus a Yamaha 8hp (since the orginal Honda 15 was stolen.) The Yamaha is an electric start model that also charges the battery. Incidentally, I believe that the Guest battery charger on the 2004 model is actually the 3-stage variety, per its documentation.
The two motors are connected directly to the starting battery. The only other things connected to the starting battery are 2 Scotty electric downriggers, only because nothing else would fit onto the terminals of the house battery -- they are chock full of the other 12-volt connectors.
The VSR has 3 switches: Starting battery, House battery and Emergency parallel. I just leave all of these switches in the "On" position, figuring that both batteries will get charged and the VSR will handle that automatically. (But I don't know exactly how that device works, so maybe I'm not using it properly.)
We have been doing a lot of fishing lately, so we generally start out of Dagmar's in Everett, make a quick run to the Tulalip Bubble (45 minutes?), then troll for hours on end with all of our electronics running, with only the trolling motor running. We then go back to Dagmar's and plug back in to shore power for a week, which presumably charges both batteries. Two days ago, however, we started from Dagmar's, fished all day (8 hours or so), then ran on the main motor to Everett, parked the boat at the Everett Marina for the night and went home. We did not plug in to shore power, but we turned off everything electrical except for the refrigerator. When we came back the next morning, the motor would not start -- the battery was too weak.
So far this makes sense -- the refrigerator ran down an already low battery (duh). But doesn't the VSR protect against this? Also, when the motor wouldn't start, I of course plugged into shore power and turned on the battery charger. I then tried to start the motor almost immediately, and it still would not start. I then turned the "House" switch on the VSR to "off", and surprisingly, the motor started right up!
So...
Question #1: Could the charger have given enough of a charge to the battery, in (literally) the 2 extra minutes of charging? Or did switching off the House battery do the trick by taking the weak battery out of the circuit?
Questin #2: While we are trolling, I assume the small motor cannot charge nearly enough to keep up with the refrigerator, stove and electronics. But will the VSR prevent the starting battery from being drained in this situation? Do I have to turn the Start switch to Off, to prevent it from being drained?
Question #3: We have noticed lately that when we start the main motor, after having trolled for a few hours, some or all of our electronics (fish finder, radar, GPS and stereo) shut off and then come back on. They never used to do that, and we can't think of anything we've done differently -- it just seemed to start happening. Any idea why that would start happening?
Question #4: Does anyone know how a VSR works, i.e. what it actually does? I don't know the manufacturer so I haven't been able to find any info on the web. Should both batteries get charged if I just leave both switches on? (Whether I'm charging from the engine(s) or from shore power?)
Question #5: Is it completely insane to have the downriggers on the battery with the motors? I have a tough time believing they could draw enough current to be a problem, with the small Yamaha charging all the time, since we only retrieve the downriggers about 2 times per hour, per downrigger. (5 amps x 30 seconds per retrieval comes out to about .04 Amp Hours, by my math...)
Last question -- with all of our electronics, it seems like moving up to a larger house battery is a no brainer. Anyone disagree? Any other suggestions on how to improved this system, or even some thoughts on some better usage techniques? Should we switch off the Starting battery every time we turn off the main motor, so that the electronics never drain the starting battery? (Sorry, I know it's a lot of questions, but I need to start somewhere.)
Thanks all.
Tom and Sherry on the Caution Horse...
dogon dory
Vessel Name: DogOnDory
PostPosted: Tue Aug 02, 2005 2:12 am    Post subject: Reply with quote
Minnow
City/Region: East Amwell
State or Province: NJ
Vessel Name: Minnow
Photos: Minnow
PostPosted: Tue Aug 02, 2005 8:16 am    Post subject: Reply with quote
The biggest problem is that you are connecting the batteries all the time by having the emergency parellel switch on. It is there for an emergency, ie:when the start battery is dead. Leave it off, and the vsr will connect the batteries when the start battery is fully charged and allow the house battery to then charge. When the batteries, (now one bank) drop below a threshhold voltage level, the relay opens to isolate the start battery.
The second problem is the wiring configuration. There are many ways of doing it, but most of them are just not optimum. The whole point of the vsr/battery switch cluster, is to be able to isolate the batteries, or to selectively connect them. Wired like yours, you cannot connect your motors to a good house battery if your start battery is dead or shorted.
I feel that the wiring diagram that comes with your unit is not correct for most applications, as the emergency parellel connects the two batteries, not the two loads. This works, except in an situation when one battery is shot, and you need both the motors and the house loads to work. (Isn't that the point?)
This is the company that makes the switch, click on the wiring diagram to see how yours is probably wired. http://www.bepmarine.com/showproduct.cfm?productid=501
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Tue Aug 02, 2005 9:51 am    Post subject: Reply with quote
Second thing that jumps out is your comments about the electronics blipping off when you start the engine. That's a sign of a weak battery. The amp draw from the starter is drawing voltage so low that the electronics are affected. Assuming you are using lead acid batteries, if they have ever been fully discharged, they will never perform the same afterwards. Each time they get discharged the worse the problem gets. That would explain why it didn't used to happen but now it does.
I totally agree there. In fact, everything may be wired correctly and you're only facing a global battery replacement and a new, more battery friendly useage procedure. In 30 years of travel trailer RV'ing I've learned that the typical RV'er only gets between 12 and 18 months out of so called "Marine deep cycle" batteries and useage between RV and boats is pretty similar. Long idle periods, occasional Senior Moment full discharges, heavy use at times, and more often unsophisticated chargers plugged in for days/weeks, rapidly take their toll.
The smart boater (and rv'er) usually switches to true deep discharge designed 6 volt golf cart batteries wired in series if they have room or they obsessively care for their stock batteries. Even then, feces occurs and battery life of the Golf Cart type is typically 4-5 years.
In a previous wifetime I served on diesel submarines where batteries are absolutely critical. The Navy takes incredible pains to extend the life of those batteries, maintaining them on a daily basis and checking them continuously. Us boaters and RV'ers just pay the price for lack of maintenance and learn to buy new batteries on a regular basis....
Don
Bearbait
City/Region: North Pole
C-Dory Year: 1991
PostPosted: Tue Aug 02, 2005 12:17 pm    Post subject: Reply with quote
1. Most likely taking the house battery out of the circuit helped.
2. You're right the trolling motor won't keep up with the load. The VSR will prevent the starting battery from discharging if you have the emergency swich off. By keeping this switch on the VSR is not accomplishing anything.
3. If you have the emergency switch off your starting battery won't affect the other electronics.
4.I don't know how it works, just what it accomplishes. Yes, keep the switches to both batteries on and both will be charged.
5. You probably won't drain the starting battery with the downriggers but the reason for the VSR and 2 batteries is to remove any chance of not having a good starting battery. With a manually startable kicker that charges you may be willing to take the risk, it's up to you.
Last Question. If you insist on using the fridge, yes you'll probably need a larger battery. If you don't use the fridge your kicker should provide most of the juice needed while trolling and the battery should be good.
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Tue Aug 02, 2005 3:07 pm    Post subject: Reply with quote
All good suggestions! Just an FYI, I think the Yamaha T8 has a 10amp alternator so that is what you have to work with while running the kicker. That said it should provide plenty of power for your GPS/Sounder and downriggers.
I've run my Sounder and Scotty Electrics on my sled all day without draining the batteries enough to start the big V8. My kicker doesn't charge the batteries while running.
Were it me, I would probably install a second house battery. This will allow for multiple days of fridge use. I would also make sure to not turn on the emergency switch on the VSR UNLESS you have a dead starting battery.
Gary Johnson
KB7NFG
Falco
City/Region: Flagstaff
Photos: Bucking Coho
PostPosted: Tue Aug 02, 2005 8:03 pm    Post subject: Re: Another Battery Question... Help! Reply with quote
There are a number of things going on here - perhaps only some of which can be communally solved. You might consider taking the boat to a trusted mechanic to ensure everything is OK now that you know how to shut off the emergency start feature on the VSR.
I can offer the following observations:
1. You should never connect all your electronics directly to the battery. If your house terminals are "chock full", you have a problem and whoever did the install for you should be shot. You need to run main power to a fuse block or circuit breaker panel (try a Blue Seas (http://www.bluesea.com)) using a heavy guage marine duplex wire and then wire each electronic/electrical component from there. In this way, you have fused protection for all electrical systems. A lack of fuses and gobbing leads to a battery is a great way to have a boat fire.
2. Your deep cycle should always be fully re-charged and periodically allowed to completely discharge. The fact that your system is charging two different battery types may prove problematic, especially because the VSR system, when properly configured will always be perferentially recharging the starting battery. Starting/cranking and deep cycle batteries also charge differently (probably why you were able to start off only the cranking batt when you connected the charger). I use 4 dual purpose (Interstate) deep cycle/cranking batteries for charging and house in by 22' (twin Suzis) - one for each engine, one for house and #4 currently a spare (pending a heater install).
Hope you get things sorted out!
dogon dory
PostPosted: Tue Aug 02, 2005 11:49 pm    Post subject: Re: Another Battery Question... Help! Reply with quote
caution
PostPosted: Wed Aug 03, 2005 3:10 am    Post subject: Another battery question... help! Reply with quote
Wow, you guys are awesome, as always!
Minnow, thanks for digging up the specs on the VSR, that was really important and helpful. And the problem of the electronics turning off when starting the main was due to me turning on the Emergency Parallel switch.
Also, Dan, I took your advice and added up the current draw for all of the devices, and it totals nearly 10 amps. Since it surpasses the 6 amp (max) of the Yammy 8, we'll need to plan an appropriate usage model and probably beef up the house battery. At least now we know what we're dealing with.
Thanks for the other comments as well, they are all helpful.
Take care, and we hope to meet more of you at future C-Brat events...
Falco
PostPosted: Wed Aug 03, 2005 1:14 pm    Post subject: Reply with quote
Thanks, Dan. I stand corrected. Here is a nice link to deep cycle care and maintenence from the folks at Interstate Batteries:
http://www.ibsa.com/www_2001/content/about_us/current/december_1999/techtalk.htm
Luna C
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
PostPosted: Thu Aug 04, 2005 12:19 pm    Post subject: Reply with quote
Informitive link - for me anyway. Thanks!
Now with Panthera 255 TC
dogon dory
PostPosted: Sat Aug 06, 2005 1:47 am    Post subject: Reply with quote
dogon dory
PostPosted: Sun Aug 07, 2005 10:50 am    Post subject: Reply with quote
Sealife
City/Region: Woodland Hills
Vessel Name: SeaLife
Photos: SeaLife
PostPosted: Thu Mar 09, 2006 11:26 pm    Post subject: Advice needed!! Reply with quote
I use my boat frequently, sometimes a couple of times per week...so it doesn't sit idle for long. Today, I decided to test my batteries with my volt meter and found both reading only 11.9, about totally discharged. Both battery switches had be inadvertly left on, but all electronics are turned off and the boats on a trailer with the plug out....so the bilge pump should not have come on and drained them. It is factory rigged with Bep switches: one starting, one deep cycle; one starting switch, one house switch, one paralleling switch, and one bus breaker. I am powered by two 50hp Suzukis. Loads are light. Only electronics, no refigerator.
As the factory explained it to me, the switch setup, without turning them off, will automatically direct house power to the house battery, preventing draining of the starting battery. But I find that both batteries are equally discharged, and when charging, are charging at an equal rate. Looking at the Beb webpage, the arrangement I have is supposed to be for a single engine, not twins. Is this my problem? Did the factory goof?
Mike - Sealife
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Fri Mar 10, 2006 12:22 am    Post subject: Reply with quote
Mike, 11.9 for a 12 volt battery is not that low. A 12 v battery in good condition will usually top off at around 12.6 to 12.8 volts and maintain it for a while. My understanding is the bilge pump will come on every couple of minutes, to test for water. Anyway that is what mine does, unless I shut it off manually. If the boat has set for a couple of weeks and the pump has been cycling, that could be why the batteries are down a little.
Page 1 of 4
Page generation time: 0.1187s (PHP: 71% - SQL: 29%) - SQL queries: 33 - GZIP disabled - Debug on
