onthewater
Joined: 17 Mar 2009 Posts: 45 City/Region: Southwest Missouri
State or Province: MO
Vessel Name: Sal Salis Vita
Photos: Sal Salis Vita
Posted: Tue Jun 25, 2013 10:42 am Post subject: Replacement Lazarette Covers (Again) |
Hello All:
I received a PM from a C-Brat asking about our replacement Lazarette covers.
Jack was interested in the part number, and had questions about the installation. I replaced both covers in the Spring of 2012 and intended to post a note about the project along with pics then, but that didn't happen, so I'll belatedly do an update now.
As most are aware, the original covers were designed for vertical installation, and in that capacity they worked fine. However, when installed horizontally (especially in an area open to rain/spray) they leaked (sometimes badly). There was a small channel presumably designed to catch water, but it was quickly overwhelmed, and the laz would get wet. That's OK in a live well, but not-so-much where electrical and fuel components are concerned.
I ordered replacement covers from Defender, and they were very easy to deal with. Because it was a special order directly from the manufacturer, I had to call it in. They were drop shipped. Here is a copy of the part number in an email response to my inquiry at Defender customer service:
"Thank you for your interest in Defender. We can special order the SPA-40154 Dream white for you if you would like . The selling price would be $64.99 each. You would have to call to place the order and refer to item SPSPA-40154" .
I don't know if the price is still the same, but hopefully the part number is still correct. The Dream White color is a reasonably close match to the C-Dory hull color.
I approached this with a little concern, as I wanted to make sure they looked nice (since they're very visible) but most importantly wanted to fix the leak problem once, and for all.
The original starboard cover was removed first. I loosened the screws holding it down, and slid a thin putty knife under the lip, while working it around the perimeter.
It released with some "gentle persuasion". OK! The core was dry! I was on a roll.
http://www.c-brats.com/modules.php?set_albumName=Sal-Salis-Vita&id=IMG_0536&op=modload&name=gallery&file=index&include=view_photo.php
I used a scrap stick to peel away the gobs of bedding compound that was originally used when she was built.
http://www.c-brats.com/modules.php?set_albumName=Sal-Salis-Vita&id=IMG_0537&op=modload&name=gallery&file=index&include=view_photo.php
The opening was just a tad bigger than the new cover base, but by careful positioning I was able to line it up so it fit, and looked right. I marked where the new holes would have to be drilled, and made them "oversize". I then filled the oversize holes with thickened epoxy and let it set up.
Finally,, I re-drilled proper size holes for the new fasteners. The last step was to apply some 3M 4200 sealant around the underside periphery of the new hatch, and tighten the screws.
With one done, I figured this was nearly a wrap. Not so fast... The old port cover was removed in a similar fashion, but here there was some wet coring. I dug out all the wet material, and allowed it to dry.
http://www.c-brats.com/modules.php?set_albumName=Sal-Salis-Vita&id=IMG_0538&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?set_albumName=Sal-Salis-Vita&id=IMG_0539&op=modload&name=gallery&file=index&include=view_photo.php
Then I made several batches of thickened epoxy and carefully forced it into the void. It was allowed to set up, and then more was added until the area was completely filled.
http://www.c-brats.com/modules.php?full=1&set_albumName=Sal-Salis-Vita&id=IMG_0540&op=modload&name=gallery&file=index&include=view_photo.php
The new hatches look sharp, and most importantly have been "bone dry" for the past year. It was definitely a worthwhile project, and not too difficult.
http://www.c-brats.com/modules.php?set_albumName=Sal-Salis-Vita&id=IMG_0542&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?full=1&set_albumName=Sal-Salis-Vita&id=IMG_0543&op=modload&name=gallery&file=index&include=view_photo.php _________________ 2007 Cape Cruiser 26 Marinaut |
haakebecks
Vessel Name: Next Adventure
Photos: haakebecks (Name TBD)
Posted: Tue Jun 25, 2013 6:23 pm Post subject: |
So, I've gone through a number of these threads by now and have a pretty good idea of what needs to be done.
One question for the pros though. After I have removed any wet core and let everything dry back, am I supposed to almost "paint" the dry core with liquid epoxy and then after that immediately fill with my epoxy/filler mix? |
Posted: Tue Jun 25, 2013 6:26 pm Post subject: |
I would suggest that any owners who do this worthwhile project also route out the dry core, and put in epoxy to assure that there is no further water intrusion, even if the surface appeared dry. It is only a small amount of extra work.
There are a number of threads on the hatch replacement. _________________ Bob Austin
Posted: Tue Jun 25, 2013 7:19 pm Post subject: |
haakebecks wrote: | One question ... though. After I have removed any wet core and let everything dry back, am I supposed to almost "paint" the dry core with liquid epoxy and then after that immediately fill with my epoxy/filler mix? |
Essentially, yes. It's not recommended* to put the typical thickened epoxy mixture directly onto dry core. Rather, you want to "paint on" (or let soak in, depending on orientation) a coat of "neat" (un-thickened) epoxy first, and then follow that with the thickened epoxy.
You can either do them one right after the other (if you have time before curing you can start with a batch of neat and then thicken the rest of the batch), or you can let the neat stuff tack up and then go in with the thickened. As long as the neat doesn't get past the green stage (in a nutshell, still tacky) you'll get a primary bond and won't have blush to worry about.
The only time it's really an advantage to wait is if you strategically need the tackiness of the neat coat (say you are then going to apply cloth to an overhead surface and need the help to make it stick), but there is also no harm in it as long as you don't get past the green stage.
*An exception I know of: WEST System say their 610 thickened epoxy that comes in a caulking-type tube can both wet out and then fill. I don't disbelieve them (they generally do good research), but I also think there would be times I would still want to *really* let some thinner/neat epoxy soak in. The lazarette core probably wouldn't worry me that way (whereas transom/below waterline would).
Sunbeam |
haakebecks
Posted: Tue Jun 25, 2013 7:34 pm Post subject: |
I have been busy reading the epoxy thread which has been very helpful btw.
Thanks for the clarification!
So one other question... I assume I can just walk into pretty much any West Marine and pick this stuff up. Is that correct or do I need to order it all up online? |
Posted: Tue Jun 25, 2013 7:45 pm Post subject: |
haakebecks wrote: | I assume I can just walk into pretty much any West Marine and pick this stuff up. Is that correct or do I need to order it all up online? |
I think most West Marine stores will have what you need, albeit you'll probably be limited to one brand, or maybe two, and things may cost a bit more (general pricing structure plus buying small packs factor). Most West stores I've been in carry WEST System (although the two are not related - just the name is similar). WEST is probably the most likely brand to come across in various "sticks and bricks" stores, although I have bought System Three in a few places as well (including woodworking type stores).
Online there is more of a selection of brands and sizes, and plus you can buy certain things in bulk (which you may not need anyway).
One thing you'll want to decide is how you want to mix/measure. WEST is a 5:1 ratio, so although you can theoretically measure by volume (i.e. with measured cups), it's a bit tricker. So for that I would probably go with their pumps or with a small digital scale and go by weight. With other brands a 2:1 ratio is common, so you can reasonably easily add in the measured cup option, or the scale or pumps way.
If you go with something pre-measured, like 610, then you just either use the supplied tips or pump it straight out and mix by hand.
PS: What I use most of: Disposable nitrile gloves - I go through them at a rate of knots and don at least three per hand before diving in (610 eases this up slightly).
PPS: Favorite easy homemade tool: Cut up plastic milk jugs to make custom spreaders/filleters/applicators/etc. |
Posted: Tue Jun 25, 2013 10:28 pm Post subject: |
Sunbeam, I realize that you don't use West Systems as much as some other products--but the ratio of hardener to resin is not always 5/1. Best to advise the neophite directly to the technical literature. For example 207 uses a 3:1. Weight and volume are not equal for mixtures of resin and hardener. West systems mixture is by volume only.
Some West System products are 1/1--such as the rapid set and G Flex.
The mini pump set does allow both 5:1 and 3:1.
Yes, you most likely can buy all that you need from a West Marine store, unless it is a very small one--even they can get the product a n day or so.
You can mix the epoxy, brush on the first coat, and then thicken it for the filler. Although it depends on the conditions, and hardener, generally you have 20 to 30 minutes of working time from the time you mix the hardener. You want to add thickening agents after the hardener has been added. |
haakebecks
Posted: Tue Jun 25, 2013 11:56 pm Post subject: |
Thanks for all of the input guys. I went ahead and ordered up the hatches today. Next up is the epoxy. I'll let you know how the project ends up going. I won't be taking it on until we have the trailer delivered and the boat moved down to Oregon, so it will be a few weeks yet.
Currently just getting all of the stuff I need to tackle these projects from the get-go.
As I was going through some of the threads, I noticed that there were some proponents of butyl tape vs. 4200. Should I use 4200 to bed the hatch and then butyl tape on the screws/through bolts?
Also, once I have gone to all of this work, should I through bolt the hatch or screw back into the epoxy filled holes? Is there a preferred method? |
Posted: Wed Jun 26, 2013 4:05 am Post subject: |
Thataway,
Thanks for clarifying the resin ratio subject. I was figuring that the OP would use the standard 105/205 for this particular job (if using the WEST mixed product at all), but it's always best to clarify, and I should have done. So.... while the "standard" WEST resin/hardener combo is mixed 5:1 by volume, they do have some other products that are different (some of the less-usual hardeners that go with the 105, plus some of the speciality resins such as G/flex, etc.). Also, WEST 610 comes pre-thickened and pre-metered in a caulking-type tube. Always good to be sure, as epoxy likes to be mixed very precisely (or failures can ensue). Another note is that if you mix by weight, the ratios are slightly different (you can look them up).
haakebecks wrote: | As I was going through some of the threads, I noticed that there were some proponents of butyl tape vs. 4200. Should I use 4200 to bed the hatch and then butyl tape on the screws/through bolts? |
I would choose one or the other and then use it for both the fasteners and the flange, as they are basically connected. Also one thing to watch: The hatch flange is not very thick/strong, and if you use too much/too thick/too stiff caulking, it can end up bowing up between the fastener areas. I used butyl tape on a cool day, and the combination of the amount (you need a fair bit to fill the grooves) and the temperature caused this very problem (I removed the hatch, cleaned it off, and started over...).
haakebecks wrote: | Also, once I have gone to all of this work, should I through bolt the hatch or screw back into the epoxy filled holes? Is there a preferred method? |
I went back in with oval-headed machine screws with nuts/washers on the underside. I'm not a big fan of "blind" screws to hold on deck hardware unless there is a really good reason to not use machine screws (and I couldn't see one in this case). |
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
Posted: Wed Jun 26, 2013 3:03 pm Post subject: |
I would not use butyl tape for the hatches. I have used it under metal parts (anchor roller, cleats) where I countersunk the screw holes. Metal parts will be strong enough to push the butyl into the countersink depression, and excess will ooze out the sides of the part you are mounting.
The hatch flanges aren't that strong, and I'd be concerned that if you used butyl, when you'd tightened them down it would either crack the flange around the screw, or you'd wind up with the flange being warped since it isn't strong enough to force the butyl out.
Also, cosmetically, clear 4000/4200 will look better between the gelcoat and plastic than gray tape. |
Posted: Wed Jun 26, 2013 4:27 pm Post subject: |
ferret30 wrote: | I would not use butyl tape for the hatches. I have used it under metal parts (anchor roller, cleats) where I countersunk the screw holes. Metal parts will be strong enough to push the butyl into the countersink depression, and excess will ooze out the sides of the part you are mounting.
The hatch flanges aren't that strong, and I'd be concerned that if you used butyl, when you'd tightened them down it would either crack the flange around the screw, or you'd wind up with the flange being warped since it isn't strong enough to force the butyl out. |
One note on this: I did have a problem like what you described on my hatch flanges, but I think I could have avoided it if I'd thought about it before-hand. Because it was a cool day and the butyl was also relatively cool and stiff. And because I had to put a lot on (to fill the grooves in the flange), it ended up "humping" the hatch flange between the fasteners. At that time, I removed it all and went back in with butyl caulk (which is much "flowier" when cool). In retrospect, if I did it again I would either do it on a warm/hot day, or pre-warm the butyl tape, and use the tape. (Once I trim the tape it doesn't tend to show.) The butyl caulk works really well, but it tended to goop into the hinges, which, since the hatch lids cannot be removed was a *real* pain to try to get out (even though I taped them prodigiously prior to installation).
In a later installation I used butyl tape to bed the tops of the actuator arms on my trim tabs (they are nylon/plastic-type material), and I did it on a warm day with sun-warmed butyl and it went a lot better (but too the arms are not as weak and thin as the hatch flanges, which, if I were designing them would be a lot stronger).
So, just to say that while I don't see anything wrong with using something like 4200 (although if white it will yellow in UV), I also think the butyl tape could work well if it were not cool/stiff. I recently used 3M's 4000 caulk (on the cabin/cockpit drain fitting), which is not supposed to yellow in UV, but I haven't had it on long enough to know if that's going to hold true or not.
PS: Just don't use silicone and all will be right with the world |
Posted: Wed Jun 26, 2013 6:42 pm Post subject: |
Although some folks use butyl tape for sealing--generally it is not recommended where there will be any possiblity of water intrusion. Use marine materials. 4000 is about the same characteristics as the 4200, but is non yellowing. I have had it in areas exposed to UV light, and no yellowing over about an 18 month period of time. |
Posted: Wed Jun 26, 2013 9:08 pm Post subject: |
thataway wrote: | Although some folks use butyl tape for sealing--generally it is not recommended where there will be any possiblity of water intrusion. |
I didn't know this. I think of it as a bedding compound, which I use specifically when there might be water intrusion (around a port or window, base of a piece of hardware, etc.). I've found it to seal very well against water leaks and to stay flexible for a long, long time (i.e. it's still flexible on my camper where it was installed in the 1970's and which has been outdoors).
I have heard that it's not recommended for use beneath the water line*, and I know that it's vulnerable to solvents so, for example, I am going to use polysulfide for bedding my fuel fills. Also, it is not a very strong adhesive compared to things like 4200/5200, so I tend to use it to bed things that are also mechanically fastened.
*That said, in a thread on a boating forum where the subject was being discussed, a fellow chimed in who is a marine biologist/diver type. He told how they have some sort of submersible sphere that's made in two pieces like a globe split at the equator. These house research equipment that's left deep in the ocean for long periods of time (forget exactly how long, but ~weeks). They put the equipment in the sphere, put the two halves together, and then seal them with a bead/strip of butyl and lower them to research depth. Then when they retrieve them they remove the butyl (which apparently doesn't leak and stays intact) and re-use the sphere for the next time with new butyl. I found this pretty interesting although I would still "officially" say that I have heard that butyl is not recommended for use below the waterline (not that I'm not running a few experiments though ). |
ferret30
Photos: Lily Pad
Posted: Thu Jun 27, 2013 3:44 pm Post subject: |
Ooops, sorry, not sure how to delete. |
