Joy
Vessel Name: C-Joy
Photos: Joy
Posted: Thu Jul 21, 2005 8:49 pm Post subject: Washdown Pump |
Hi
Does anyone have a washdown pump installed on a 22'? If so, make and how you mounted it please. _________________ Randy Woodson
C-JOY
All about Family and Friends |
C-Hawk
Joined: 02 Nov 2003 Posts: 2150 City/Region: Carpinteria / Channel Islands
Vessel Name: C-Hawk
Photos: C-Hawk
Posted: Thu Jul 21, 2005 11:20 pm Post subject: |
Mine was installed at the factory. It is a thru-hull and is located just in front of the cabin bulkhead under the stove. _________________ Roger
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
God is Great, Beer is Good.... and People are Crazy |
Mighty Bite
Joined: 02 Nov 2003 Posts: 456 City/Region: Fairbanks, Alaska
Vessel Name: Mighty Bite
Photos: Mighty Bite
Posted: Fri Jul 22, 2005 3:08 am Post subject: |
EQ mounted a freshwater washdown system on 3rd Byte. The pump is mounted on the inside of the bulkhead wall roughly under the Wallas. The switch and connection for the coil hose is located in the same relative location, low, on the outside of the bulkhead. Water supply is fed off the factory fresh water tank. _________________ Mark on Mighty Bite |
Mason C. Bailey
Vessel Name: McNaughty III
Photos: McNaughty III
Posted: Fri Jul 22, 2005 10:50 am Post subject: Wash down |
Mine was also factory installed but to my specifications. I didn't want a below water line through hull fitting. So I had them place the pump in the port side battery compartment, drill and place the through hull straight through to the upper stern. Then ran the pickup tube down to the water line. The hose is coiled up in the water well and is easily accessible to hose down the stern. If I get the chance, I'll take some pictures and post them on the McNaughty album.
McNaughty III |
digger
Vessel Name: C-Sik
Photos: Snoopy-C
Posted: Fri Jul 22, 2005 11:52 am Post subject: Washdown Pump |
Snoopy-C has a washdown pump. It's intake is just forward of the cabin bulkhead, where the original Furuno fishfinder thru-hull bronze fishfinder transducer originally was. I didn't like the protrusion of the transducer, so replaced it with a transom mount, and then got a bronze thru-hull fitting that mounted right into the transducer hole. It has very little intrusion beneath the hull of the boat. I then plumbed the hose to the starboard lazerette area, when I have a filter and the washdown pump mounted. I have a garden hose bulkhead fitting plumbed out of the lazerette into side of the motor well. Works great. Probably about $200 total cost. Ron _________________ previous snoopy-c owner, previous c-miner owner, current C-Sik owner(22 angler) |
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
Posted: Wed Aug 03, 2005 4:02 am Post subject: |
Well I finally have my wash down kit ordered. Problem is I do not have a through hull fitting and am not too excited about putting a hole below the water line Has anyone tried placing the pickup tube down the transom? This would prevent having a big hole where I do not want one. With all the holes I have drilled into my boat you would think Id be comfortable, however, so far they have all been above the water line. _________________
Live to Fish
Fish to Live |
MOOSE
Joined: 07 Nov 2003 Posts: 622 City/Region: Rainy Lake - Int'l. Falls
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
Posted: Wed Aug 03, 2005 11:10 am Post subject: |
Given the quick disconnect hose fittings available on some models, why could one not simply attach an inlet hose when one wanted to use the pump and drape the other end over the transom and into the water?
Al _________________ .....and remember, if the women don't find you handsome, they should at least find you handy. |
DodgeRam
Joined: 26 Nov 2004 Posts: 199 City/Region: Vancouver Isl. CANADA
Vessel Name: SeaRam
Photos: SeaRam
Posted: Wed Aug 03, 2005 12:06 pm Post subject: |
I remember reading in this forum , about a pick up tube install outside on the transom. Was a nice install, sorry forgot where it was and who it was. There where some pictures. SEA RAM Gary |
gljjr
Joined: 27 Jan 2005 Posts: 908 City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
Posted: Wed Aug 03, 2005 6:48 pm Post subject: |
I think I would put the through hull next to where the swim step is mounted and then have a 90 deg fitting to attach the hose with and run the inlet hose down to the bottom leg of the swim step. That way it will be above the water line and the swim step will "hide" most of the installation on the exterior of the boat. I'm pretty sure this is how I'm going to install the one I have on the my boat. _________________ Gary Johnson
KB7NFG |
Joined: 23 Oct 2003 Posts: 5328 City/Region: Warrenton
Posted: Sat Aug 06, 2005 1:14 am Post subject: |
Mr. Fisherman wrote: | Has anyone tried placing the pickup tube down the transom? |
Ray - On the 22 I used a hose over the transom for a pickup. It worked well while sitting still. Then I shortened the hose and slipped it over a length of 3/4" SS tubing held to the motor mount with tyraps. I cut the water end at 45º, faced the short side of the bevel forward with the long side just at the bottom of the transom. That set up really sucked, even at speed. It will help if you mount your pump a hair lower than the highest point of the suction line, I discovered. Also, if you mount the pump any way but sitting flat, make sure the suction inlet is at the lowest point of the run. I mounted my pump horizontally on the side under the gunnel, and with the suction inlet at the bottom, she didn't work so well. I turned it over so the inlet was on top, and still lower than the high point of the hose, and it worked great.
Sometimes thru hulls under the water line are necessary, and if done right there is nothing wrong with them, but unless you are spending several hundred bucks on your pump, the little squirt you get from the hose is not worth a hole in the boat. If I ever get around to putting one on the new boat, it will be as described above. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Mr. Fisherman
Photos: Sea Lion
Posted: Sat Aug 06, 2005 7:07 am Post subject: |
Thanks Mike. I think I'll get it sorted out when it gets here.
I may pick yer brain after I get a chance to pull it from the box and look it over. |
Ted Osborne
Joined: 29 Dec 2004 Posts: 109 City/Region: Des Moines, WA
C-Dory Model: 24 Tomcat
Vessel Name: Tabbycat
Posted: Sat Aug 06, 2005 11:50 am Post subject: |
We don't have the 22, but I installed a washdown pump on our TomCat. It does not have a thru hull. I purchased the pump from Boater's World which was a Fojet washdown 3.0 GPM, their item #357400746 for $70 in March of 04. For the water inlet I bought from Home Depot some clear tubing of the proper size and cut it long enough to throw over the side with a screen on the end and a sinker attached with a stainless clamp. Also purchased one of those "curly" type hoses and used those garden quick connect fittings so everything goes together fast. I installed the pump, which comes with a filter, under the gunnel with nylon bolts which I have used before and they never rust. The on switch is right next to the pump. Carry everything in the aft outside locker. I always bleed my fish and then clean up the mess with the pump. It sure beats the old bucket method and I can't tell you how pleased we have been with it. _________________ Ted & Donna |
Mr. Fisherman
Photos: Sea Lion
Posted: Sat Aug 06, 2005 5:00 pm Post subject: |
I am getting a warm fussy feeling about this. Thanks to everyone for sharing. |
dogon dory
Vessel Name: DogOnDory
Posted: Sun Aug 07, 2005 2:06 am Post subject: |
Posted: Sun Aug 07, 2005 2:21 am Post subject: |
dogon dory wrote: | Afterwards you may figure out why Mike's nickname is Slim Pickins. |
It used to be Scoob. |
