BayStar hydr. steering
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Mon Jul 11, 2005 3:15 am    Post subject: BayStar hydr. steering Reply with quote
I ordered the Teleflex BayStar hydraulic steering for my boat yesterday.
After 22 years my old cable system is getting worn and sloppy. It survived two engines and 2100 hrs. running.
I am anxious to install it but dread the removal of the engine to get the old cable system off and the BayStar installed. My 1983 22' has the narrow motorwell so the motor must be removed.
I read good reports of performance of the BayStar and I hope to have the same results.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Redƒox
Guest
PostPosted: Mon Jul 11, 2005 2:29 pm    Post subject: Reply with quote
Jack- I went that route years ago Exclamation You need-not remove engine Exclamation Exclamation just cut the old cable and pull it out that way! I cut mine with one of them 4-inch grinders (from Costco Laughing ) piece-a-cake Thumbs Up
Jack in Alaska
PostPosted: Mon Jul 11, 2005 7:52 pm    Post subject: Hyd. steering Reply with quote
Greg,
Good suggestion. on cutting the old cable. Thanks. Now if the hydr. steering will fit into the tilt tube w/o removing the engine I will be home free.
My neighbor with the 26' cabin cruiser C-Dory put hydr. on his boat when he changed engines and he loves it. Much easier to steer.
Redƒox
Guest
PostPosted: Tue Jul 12, 2005 2:27 pm    Post subject: Reply with quote
If I remember right; the bolt that fits through the tilt-tube; did not need any jimmy'n of the engine to get inserted. If it did; only loosen the bolts and pry-out one side of the engine, it certainly does not need to be removed. Don't forget to re-gorilla-snot it back on, if ya do break a sealing surface on the transom.
A big-assed yeah on the improvement Thumbs Up makes a "clunky old feeling boat" into a fine feeling baby Smile
Man... glad I saw this one. We Classic owners gotta stick together here Wink Cigar Beer Mr. Green
They don't makem like they used to Smile
jflug
City/Region: Bodega Bay
C-Dory Year: 1981
Vessel Name: Pescadory
Photos: Pescadory
PostPosted: Wed Jul 13, 2005 5:55 pm    Post subject: Reply with quote
I went through this a couple years ago when I mounted my Yamaha F80 on my '81 Angler. I thought I was home free when I cut off the old steeringf cable, but alas, I still wound up unbolting the motor to get both sides of the Baystar steering into the pivot tube. It's not that hard, but it's just un-nerving having my 400 lb F80 hanging from a come-along for any period of time.
Jim F
Jack in Alaska
PostPosted: Wed Jul 13, 2005 8:50 pm    Post subject: Reply with quote
Jim,
Been there, done that. I just today put my come-along in my truck so I had it when I changed out steering.
I used the come-along when installing the 1st motor and when I replaced it in 1997. I hung it from my son's basket ball hoop BRACING. Worked great. Smile
dogon dory
Vessel Name: DogOnDory
PostPosted: Thu Jul 14, 2005 2:34 am    Post subject: Reply with quote
Redƒox
Guest
PostPosted: Thu Jul 14, 2005 3:24 am    Post subject: Reply with quote
Garsh... thnx mon Thumbs Up Teeth
Guys it's been so many years, I don't recall exactly, but I think it was a struggle getting the long bolt into the tube (took a little poundin Neutral but nuttin got "bullied and bugger'd" really Mr. Green Hey, try it the easy way first Idea
That rack over my transom came in really handy when I upgraded from my old 140 Johnson; come-along and straps right from the top (took off the "burger-box" first of course) Smile
Jack in Alaska
PostPosted: Sun Aug 07, 2005 4:08 am    Post subject: Reply with quote
The C Dory HIGH TIDE has hydraulic steering installed, filled and air bled out.
It works great and now I wonder why I put up with that archaic, sticking, jerky cable system. I threw the whole thing in the dumpster.
I had to take the 90 hp. Honda clear off and let it dangle on an engine hoist while I removed the cable and installed the hydr. rod etc. It went back together well .......Thanks for all of the tips and suggestions. YeeeHaaa. Very Happy Smile Laughing
Page generation time: 0.0263s (PHP: 67% - SQL: 33%) - SQL queries: 23 - GZIP disabled - Debug on
