Battery switch will not switch "OFF"
PostPosted: Mon Jan 07, 2013 12:50 pm    Post subject: Battery switch will not switch "OFF" Reply with quote
Went outside to do some small stuff in the boat. Battery switch now will not switch off. Stays "ON" no matter what. Gonna take it apart; see what is within. May be time for a new Blue Sea "Add-A-Battery".
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Jan 07, 2013 2:51 pm    Post subject: Reply with quote
I plan to install a VSR
see
http://www.bepmarine.com/media/product/pro4cd73148082df.pdf
Brent Barrett
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Mon Jan 07, 2013 4:59 pm    Post subject: Reply with quote
Mark
Two years ago my switch stuck in the off postion, all I did was spray some WD40 down at the base of the switch. Worked fine ever since. Use a can with the straw
Chuck
Bootleg Hooch
PostPosted: Mon Jan 07, 2013 5:32 pm    Post subject: Reply with quote
Thanks, guys. I'm gonna look at all options.
nimrod
City/Region: Mount Vernon
Vessel Name: 'Berta's Boy
Photos: 'Berta's Boy
PostPosted: Mon Jan 07, 2013 6:44 pm    Post subject: Reply with quote
Hey Mark,
I installed a VSR last year. You're welcome to my old batt switch if you need an interim solution.
jd
C-Dawg
City/Region: Spanaway
Photos: C-Dawg
PostPosted: Mon Jan 07, 2013 7:00 pm    Post subject: Reply with quote
Don't over think it; use a bigger hammer. Cool
Rick & Shirley
Go Dawgs!
C-Dawg sold November 2018
PostPosted: Mon Jan 07, 2013 7:21 pm    Post subject: Reply with quote
Thanks, JD. I'll let you know. And I can always count on Rick for a quick fix. BFH! I've used it many times.... Laughing
PostPosted: Mon Jan 07, 2013 8:23 pm    Post subject: Reply with quote
Sorry for the following nag. But the middle daughter left after the New Year and everything's sorta quiet.
There are a lot of failure modes in a switch, all the way from a stuck knob to broken contacts. If a broken contact or corrosion is present, you can get a lot of heat from the poor connection. And, a poor connection can build up heat, melt the switch and when you're out fishing the back of the boat bursts into flame and you've got a 3 mile swim in front of you.
The point I'm trying to made, is that for C-Dory use, battery switches are cheap. 23 bucks at Defender. Just replace the thing instead of nursing it.
Yours in swimming, Boris
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Mon Jan 07, 2013 9:00 pm    Post subject: Reply with quote
Boris, I had that problem with a off/1/2/both switch. Bad contact at #1 - heat buildup,,,,,, replaced it with a new one but it still worked good between #2 and the common,,, so I used it as a on/off switch for my inverter. I got the notion that if I was ever swamped it might be a good idea to have a quick disconnect for the 12v going to the inverter. Standing in a boat full of water I would be skeptical about trusting the little on/off switch on the inverter!
Sorry for jabbering on - but like Boris, I'm bored - its winter here - waters all crunchy - not quite enough power,,,,weight or hull strength to be an ice breaker,,,, oh well they say not to wish away the seasons or you'll be wishing away your life - I'll just keep telling myself that Very Happy Very Happy
Regards, Rob
PostPosted: Fri May 23, 2014 9:51 am    Post subject: Reply with quote
Switch is doing it again. Went out to the boat and it will not turn "off". Time for a new one. Looks like a trip to Fisheries today.
BrentB
Photos: BrentB
PostPosted: Fri May 23, 2014 10:44 am    Post subject: Reply with quote
I would upgrade to BEP VSR battery switch
PostPosted: Fri May 23, 2014 11:50 am    Post subject: Reply with quote
I just ordered the Blue Sea Mini Add-A-Battery from Defender. Fisheries wanted $115 and Defender had it for $86 + frt but I needed a couple of other small things.
Jazzmanic
Photos: C-Dancer
PostPosted: Fri May 23, 2014 12:29 pm    Post subject: Reply with quote
I added the add-a-battery system a few years ago. Plus I cleaned up all the wires going to the battery terminals by installing bus bars for both batteries. Clean and easy.
Peter
C-Dancer
PostPosted: Fri May 23, 2014 2:22 pm    Post subject: Reply with quote
Peter, does it work as advertised?
Jazzmanic
Photos: C-Dancer
PostPosted: Fri May 23, 2014 3:29 pm    Post subject: Reply with quote
I believe it does but I really haven't tested the "combine" function since both batteries are fairly new and didn't need the extra juice. I just like the fact that I switch it to the "On" position and forget about it, not thinking about should it be on 1, 2 or 1+2.
Sorry I couldn't be of more help but I do like the simplicity of the system.
Peter
Page generation time: 0.1574s (PHP: 90% - SQL: 10%) - SQL queries: 33 - GZIP disabled - Debug on
