GxK
Joined: 28 Oct 2007 Posts: 124 City/Region: Frenchman's Bay, Lake Ontario
State or Province: ON
C-Dory Model: 24 Tomcat
Vessel Name: At Last! ex Goose
Posted: Thu Oct 11, 2012 6:01 pm Post subject: Wallas fails to start |
Ahoy, C-Brats!
I have a Wallas 125DU on my TomCat 24. It was worked well for five years but now that cool weather has come to Lake Ontario, of course it won't start.
It appears to be starting as normal but after a few minutes the red light starts to flash. No warmth at all in the ceramic. Repeated attempts to start the thing have got me nowhere.
The manual tells me the problem might be a carbonized burner. Anyone know how to uncarbonize the burner?
The manual also says it could be overheating but doesn't provide a solution either.
I've poked around the archives but haven't hit an answer for my problem. I burn Kleen Heat and have plenty of juice.
--Georgs _________________ Georgs Kolesnikovs
TomCat 24 At Last!
Puffin Saco 12 Finally!
http://tomcat-tales.blogspot.com/ |
Posted: Thu Oct 11, 2012 7:06 pm Post subject: |
There can be several reasons a Wallas stove/heater/whatever doesn't start: low voltage, bad igniter, bad fuel pump, etc. And I'm not going to diagnose what went wrong, that stove is too tricky for me. And don't forget to try Jody Kidd's suggestion (below.)
Also after 5 years, Journey On's Wallas 95 crapped out and I finally got it fixed.
What I'm going to suggest is that you read the following for suggestions, contacts, etc.: Wallis Redux . Also here is an article on rebuilding a Wallis (for info only):Taking apart the Wallas Stove. Then call Mike at 206-285-3675 ( Scan Marine,) and discuss the problem with him.
After all that research, decide if you want to keep it. If the answer is yes, box it up, send it to San Marine and have them repair it. Don't let them sell you a model 85.
jkidd
Joined: 23 Oct 2006 Posts: 1622 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Posted: Thu Oct 11, 2012 7:10 pm Post subject: |
I would see if it is locked out first.
1 turn the switch on
2 after the light starts flashing leave the switch on and remove the fuse or disconnect the power lead.
3 with the switch still in the on position reconnect the power.
4 now turn the power switch off.
5 try to start like you normally would.
If this works it was in lockout and happens because it didn't startup or shutdown correctly
Hope it works for you. _________________ Jody Kidd
KE7WNG
Northern, Utah
ShellBack
Vessel Name: Thalassa
Photos: Thalassa
Posted: Thu Oct 11, 2012 7:56 pm Post subject: |
I had the same problem a couple of months ago and did the procedure that Jody is suggesting and it corrected the problem. No worries since. Good luck |
Joined: 02 Nov 2003 Posts: 20848 City/Region: Pensacola
Posted: Thu Oct 11, 2012 8:51 pm Post subject: |
Georgs--good you are getting back on the boat! Agree on the lock out.
Also check the fuel pump--get a small bubble of air into the bottom of the fuel line at the pickup, where you can see it in the tubing. Watch to see if this small bubble progresses up the line. Also check all of the connections. Be sure that the voltage is at least 12.6 volts. Put the battery charger on if lower--or just put it on any way....to be sure. _________________ Bob Austin
Forty Two
Joined: 16 Nov 2004 Posts: 114 City/Region: Prince William Sound
C-Dory Year: 2017
Vessel Name: Black Cat
Photos: Barrel O Monkeys
Posted: Fri Oct 12, 2012 3:48 am Post subject: |
Almost all the problems with our Wallas turned out to be voltage related.
Sometimes with the engines off, it will not start. Fire up the motors and it starts right up. 12.2 volts to 12.6 volts from the batteries. 13.4 to almost 14 from the alternator. Alternatively don't touch the water pump, don't run the depth sounder or gps, or lights when firing up the Wallas with the engine off and you may have more success. _________________ John & Susan |
Posted: Fri Oct 12, 2012 8:02 am Post subject: |
I've had the lockout thing happen several times over the years. If the Wallace has been turned on twice in a row without achieving successful ignition (for whatever reason) it locks-out subsequent start up attempts. Typically it's been caused by the switch being accidentally (or intentionally) cycled a couple of times without letting the unit get fully started. _________________ Roger on Meant to be |
GxK
Posted: Fri Oct 12, 2012 9:32 am Post subject: Re: Wallas fails to start |
Thank you, all, for the advice. I'll let you know what transpires when I'm next on the boat.
--Georgs |
seahooked
Photos: SeaHooked
Posted: Fri Oct 12, 2012 9:54 am Post subject: |
I had a similar problem with my Wallas earlier this spring. I verified I had sufficient voltage at the unit and talked through some troubleshooting steps with the local Wallas rep. He believed the glow plug was at fault consistent with the age and hours of use. I replaced it however it did not fix the problem.
When I looked closer at the unit, I found (with my voltmeter) that although I had sufficient voltage before I turned the unit on, when the Wallas tried to draw significant current, the voltage dropped down significantly. It was then obvious that the problem was not in the Wallas but in the wiring. I investigated further and found the main inline fuse (close to the house battery) was corroded. I suspect this is not an uncommon problem and people should look here first. _________________ Chris Brown
Redmond, WA
2006 CD-25 Cruiser "SeaHooked" 2006-2012 |
GxK
Posted: Fri Oct 12, 2012 7:02 pm Post subject: |
Wow, Jody is a magician! Wallas now working just fine, cabin nice and toasty despite outside temp in the 40s.
Thank you, Jody!
--Georgs
jkidd wrote: |
macmac
Posted: Tue Oct 16, 2012 10:17 am Post subject: Lockout |
Georgs, Jody:
Thank you for your input on this. I have been away from the forum for a while.
Please note: The 125DU (aka 95DU25) has no lockout feature. The 85DU270 does. The 85 series superseded the 95 series in 2006.
Either the stove is an 85DU270 or the problem was something else.
Doug at Scan |
GxK
Posted: Tue Oct 16, 2012 11:02 am Post subject: Re: Lockout |
Well, now we have a mystery on our hands--and the solution was indeed magical!
I'm not on the boat so cannot look for additional numbers but the TomCat is nine years old, so the stove would be a 2001 or 2002 model. Let me get back to you, Doug.
--Georgs
macmac wrote: | Georgs, Jody:
Doug at Scan |
Posted: Fri Oct 19, 2012 9:51 pm Post subject: |
Somewhat related Questions for the Wallas pro's.
If the Wallas starts OK, on the batteries, and runs without the engines running, is it OK to start the engines with the Wallas still running? Would it make a difference if the top was up or down during the start?
Or does the Wallas need to be shut down prior to starting the OB's?
jkidd
Posted: Fri Oct 19, 2012 11:06 pm Post subject: |
hardee wrote: | Somewhat related Questions for the Wallas pro's.
SleepyC |
My Wallas runs off of my house battery so starting there would be no effect. Is your Wallas running of of the cranking batteries? |
Posted: Fri Oct 19, 2012 11:38 pm Post subject: |
Yes, the cranking/combo house batteries. I have twin OBs and each one has their own individual group 27 battery. I do have a 1-2-B-Off switch. Don't know if I could Isolate the wallas because it runs of the Stbd battery. Maybe switch the switch to that side, and then start the other engine then go back to both, running it up a bit, so it would see the charge. If I go to the single port side It would have no power and I can see that result --- goes out ASAP.
SleepyC |
