Radar Question
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Sun Sep 23, 2012 11:59 am    Post subject: Radar Question Reply with quote
I have noticed that there is a drain hole on the Radar base. The drain hole hasn't been punched out..should i drill or punch it out. Thanks Tug
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sun Sep 23, 2012 4:21 pm    Post subject: Reply with quote
Are you sure that is a drain hole? I have the same unit and I do not recall a hole or anything in the instructions as to open up any hole . The radome cover should be water tight I belive. Can't remember for sure but isn't there a seal between the base and cover?
Chuck
Bootleg Hooch
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Sun Sep 23, 2012 4:25 pm    Post subject: Reply with quote
Spike i will go over it again and find out if it's a drain hole.Tug
PostPosted: Sun Sep 23, 2012 7:30 pm    Post subject: Reply with quote
The best advice I can give is to call the mfg's customer support. Don't guess, since if it's not a drain hole, and you make one, that's bad. Just call.
As an aside, on the JRC's I've had (one was labled Raymarine,) there is a relief valve for air pressure. When I lean on the dome, it bends and I can hear air going out. Since the dome rebounds, I assume there is air coming back in. No obvious drain hole. Remember there's electronics in there.
boris
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Sun Sep 23, 2012 8:39 pm    Post subject: Reply with quote
Boris..i sent Furuno that question...will post ASAP. Tug
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Tue Sep 25, 2012 4:48 pm    Post subject: Reply with quote
Furuno sent me a picture of the radar housing with the two vents circled but i can not post it? Whether the vents are air vents.( which i think they are ) . or water vents they didn't say. Tug
PostPosted: Tue Sep 25, 2012 5:10 pm    Post subject: Reply with quote
Tug-
I'll bet they are air vents for fresh air and humidity control. They are probably also placed to allow water condensation to escape out the bottom when it occurs on the inside of the dome.
Since the dome cannot reasonably be sealed, vents for pressure equalization, ventilation, and condensation escape would be necessary, IMHO.
Just my guess from a science viewpoint!
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Tue Sep 25, 2012 5:49 pm    Post subject: Reply with quote
Joe..makes sense to me..except they are sealed tight...i tried to pass a very..very small diameter needle through where the hole should be..no chance...maybe the hole is there and only allow air to pass through after enough pressure builds up..
i am about to paint the bottom motor housing section of the Radar anyway...i will put a small piece of tape there just in case it's a functioning vent.
I was going to use an expensive exterior paint but a friend told me not to waste my money.....he just paints his with TrimClad....cheaper and lasts a long time...and easy to touch up.Tug
Page generation time: 0.0377s (PHP: 56% - SQL: 44%) - SQL queries: 25 - GZIP disabled - Debug on
