My tanks are shot. Need to replace. Any suggestions
glennmarina
City/Region: Vista, Southern California
C-Dory Year: 1982
Vessel Name: La Pesca Dory
PostPosted: Tue Sep 11, 2012 10:42 pm    Post subject: My tanks are shot. Need to replace. Any suggestions Reply with quote
1982 22' Angler. It had the split 20's in the rear. I would like to go to 80 gal. if possible (made be up the center). Has any done this type of up grade? Or should I just get the same ones re-made?
glenn
PostPosted: Wed Sep 12, 2012 12:27 am    Post subject: Reply with quote
I can't speak to 80 gallons, or specifically to your generation of Angler -- which may render this info pointless since I think the splashwell is different, but just in case -- I can tell you that the Moeller port and starboard 23-gallon tanks that fit under a post-1986 22 Cruiser are available and can be purchased through any Moeller dealer. They are in the neighborhood of $250 apiece. There are drawings of them in my album if you want to take a look at them. These are the tanks that are being put in the new 22's now, and were also used in some of the 2000's 22 Cruisers (mid- to late-2000's, I believe).
PostPosted: Wed Sep 12, 2012 1:54 am    Post subject: Reply with quote
Your best bet will be a custom Aluminum tank. The early anglers are entirely different than modern boats in the transom area--and you can rework the entire area to accumulate this size tank. However, 80 gallons is a lot of fuel--about 500 lbs vs the 36 or so gallons which were there.
I have seen several boats with a single aluminum tank of at least 50 gallons, so 80 is certainly do-able. Another option is two 20 gallons aft, and then 20 under each gunnel in saddle tanks.
PostPosted: Wed Sep 12, 2012 10:36 am    Post subject: Reply with quote
catch -22 built saddle tanks for his older angler. not sure how many gallons but more then 20 each. look in his album.
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Wed Sep 12, 2012 10:52 am    Post subject: Reply with quote
Glennmarina,
I bought saddle tanks from Overtons. Not sure of the maker. I covered them with sheet aluminum. 20 gal/side.
This was on a 1984 Angler. The original tanks were two 12 gal. steel tanks under the motorwell. This gave me a total of 64 gal. if needed. I eventually put the batteries under the motorwell and just used the saddle tanks.
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
PostPosted: Wed Sep 12, 2012 2:43 pm    Post subject: Reply with quote
Thanks for posting that photo. I can see that the tanks made for a "modern" 22 Cruiser would be totally out of place. I like the look of that access to the transom you have with that boat - nice set up.
haliman
C-Dory Model: 19 Angler
PostPosted: Wed Sep 12, 2012 5:24 pm    Post subject: Reply with quote
I just replaced my tanks in my 2008 19' Angler. Moeller 23 gallon tanks, FT2339 AND FT2340 are the model numbers. Bought them from Fisheries Supply in Seattle. $201.98 a piece.
PostPosted: Wed Sep 12, 2012 5:34 pm    Post subject: Reply with quote
Those part numbers are the same tanks I mentioned above -- turns out they're more optimized for the "modern" splashwell/cockpit set-up.
PostPosted: Sat Sep 22, 2012 8:25 pm    Post subject: Reply with quote
Moderators, please move this out of the For Sale forum. Thanks.
Page generation time: 0.0448s (PHP: 49% - SQL: 51%) - SQL queries: 26 - GZIP disabled - Debug on
