Hole drilling anxiety
robl132
City/Region: Pittsburg, Calif.
Vessel Name: Poodie
PostPosted: Sat Jun 18, 2005 11:48 am    Post subject: Hole drilling anxiety Reply with quote
OK, I've got the new C-Dory. It's all good. But, now comes the time to start drilling holes in my new baby. How do you get over the hole drilling anxiety? I absolutely freeze up. Suggestions?
Shocked Rob
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sat Jun 18, 2005 12:22 pm    Post subject: Reply with quote
Hi Rob,
It is hard to drill the first hole. A good friend of mine bought a new boat about the same time last year that I bought mine. He wanted to install an hour meter. He read the directions and it said to drill a certain size hole for the meter. He drilled the hole in his dash and then tried the meter and the hole was 1/2 in oversized! Evil or Very Mad
He said he got so mad he just about through his drill across the driveway. He was able to use a cover plate and install the meter and it looks okay.
When I install things I always tell myself that if I really screw this up I can take it back to the factory and they can make it look like new again - it will just cost money. That is the benefit of fiberglass. I have made a couple of mistakes but they have not been too bad.
Good luck with your projects.
It would be fun to see your boat. I will probably try take my boat out Sunday launching from Pittsburg or Bethel Island. Let me know if you are interested in meeting up on the water sometime. Maybe a cruise up to Locke for steak at Al's place.
Steve
SeaSpray
CD22
katkt
C-Dory Model: 24 Tomcat
Vessel Name: Katie Kat
Photos: Katie Kat
PostPosted: Sat Jun 18, 2005 3:29 pm    Post subject: Reply with quote
Mask off the area your drilling, don't forget to bevel the edges of the holes. Double check everything, dimensions, size of bit, whats behind what your drilling into.
I always think of the boat as a basic package the things you add only improve it(hopefully). Its always easier to drill a hole if your improving something(its one of those glass is half full kind of things)
Start with the simple things first, and graduate to the tougher task as your skill and confidence improves.
Git-R-Done Thumbs Up
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Jun 18, 2005 3:40 pm    Post subject: Reply with quote
It took me two days of being ready, but not being able to pull the trigger on the drill, before I drilled my first hole in my new cruiser. Sad
It never hurts (if you are on your own time) to wait, double and triple check everything prior to making the holes. Wink
Larry H
A C-Brat since Nov 1, 2003
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Sat Jun 18, 2005 4:02 pm    Post subject: Reply with quote
Here's a good thread describing some techniques. In particular, proper drill bit selection is very important.
Also, scrap plywood and templates are your friends...I always "install" things off the boat first.
Tux Will, C-Brat Nerd Tux
Guts
City/Region: San Diego
PostPosted: Sat Jun 18, 2005 6:38 pm    Post subject: Reply with quote
When drilling with a hole saw run the pilot bit in first then put on the hole saw and run it in reverse till it scores the gel-coat them cut the hole. I like to use temples and cut holes with a router.
My Two Cents
Guts
robl132
Vessel Name: Poodie
PostPosted: Sat Jun 18, 2005 10:38 pm    Post subject: Reply with quote
Yahoo! I followed all your kind suggestions. Everything came out fine. Whew. Thank you all. Seabran Steve, sounds great, I'll contact you shortly.
Very Happy Rob
Page generation time: 0.0612s (PHP: 65% - SQL: 35%) - SQL queries: 24 - GZIP disabled - Debug on
