battery integrator
robl132
City/Region: Pittsburg, Calif.
Vessel Name: Poodie
PostPosted: Wed Jun 08, 2005 10:52 am    Post subject: battery integrator Reply with quote
I'm considering using this in a 2 batt/1 alt setup. Running the house on 1 battery and the starter on the other. This model advertises no voltage drop compared to a isolator. Has anyone had any experience with the integrator? This sounds better than just a switch.
http://www.newmarpower.com/bi_100/bi_100.html
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Wed Jun 08, 2005 11:56 am    Post subject: Reply with quote
This looks like a pretty nice item as far as it goes. Basically this would isolate the house batteries from the starting battery until you have the motor running or are putting a charge on the starting battery. But you would still want to have a switch to enable you to use the house battery to start the boat in situations where the starting battery is dead.
From looking at the picture this is basically just a relay with a special switch that turns the relay on at a certain voltage. They probably use the same type of circuit as is used on alternators so I would think it would be pretty reliable.
Gary Johnson
KB7NFG
robl132
Vessel Name: Poodie
PostPosted: Wed Jun 08, 2005 12:07 pm    Post subject: Reply with quote
with a quizzical look on my face, I wondered, well when would I run down the starter battery, when all the draining stuff is on the house battery? All of a sudden I pictured myself in my old car, in the rain, corroded posts, hitting the starter over and over, hoping she'll catch. Good point. I think I'll integrate a switch into the integrator.
Rob CoolSmile
PostPosted: Wed Jun 08, 2005 1:45 pm    Post subject: Reply with quote
How much is that sucker? By the way, Newmar is a good supplier>
robl132
Vessel Name: Poodie
PostPosted: Wed Jun 08, 2005 6:53 pm    Post subject: Reply with quote
Around a hundred.
Yikes!
Rob CoolSmile
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Tue Jun 28, 2005 8:41 pm    Post subject: Reply with quote
This may be on point http://thehulltruth.com/forums/thread-view.asp?tid=66028&start=1 and here http://www.bluesea.com/product.asp?Product_id=53476
Pete
Minnow
City/Region: East Amwell
State or Province: NJ
Vessel Name: Minnow
Photos: Minnow
PostPosted: Wed Jun 29, 2005 3:34 pm    Post subject: Reply with quote
This is the auto charge relay that I have installed. http://www.honda-marine.com/acc.aspx# (scroll down to Misc. parts & accesories). It's about $130 and includes the battery distribution cluster. Using it is a no-brainer as it eliminates thinking about switch positions. The only problem is with the wiring diagram. They have the emergency parallel switch connecting the batteries, not the loads as does the Blue Sea unit. Honda's way would not allow you to disconnect a dead or shorted battery, and still power the motor and house loads.
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Wed Jun 29, 2005 9:58 pm    Post subject: Reply with quote
I've used the Honda auto charge on 2 boats. Works great.
Dusty
Adeline
Photos: Adeline
PostPosted: Wed Jun 29, 2005 10:58 pm    Post subject: Reply with quote
Hey Minnow, I followed the link and saw the " Battery Distribution Cluster
Single Outboard Motor". Is it simply the left-most component in your picture or is it everything including the housing? Where did you mount it?
Minnow
Vessel Name: Minnow
Photos: Minnow
PostPosted: Thu Jun 30, 2005 7:56 am    Post subject: Reply with quote
The enclosure in the photo is made of Azek plastic lumber and mounted under the starboard aft seat just forward of the house battery. All of the wiring enters from the top left corner (in pic), so that I can pull a couple of screws and swing the whole box out of the way for battery access.
The Honda part is made by BEP Marine of New Zealand http://www.bepmarine.com/showproduct.cfm?productid=501 and I'm real happy with it.
The part is just the cluster in the lower left corner. The rest of the stuff is fusing for the panels and windlass, the negative side shunt for the Linc 10 battery monitor, (cool unit btw) , and the small always-hot fuse box for the bilge pumps, Link 10, stereo memory, battery charger back-feed, and should be Wallas, but mine was wired to the nav panel from the factory. This setup gets the individual fuse holders off the battery terminals.
At the Eastern Shore gathering, I was showing a new CD25 owner how his bilge pumps operated, and found that they didn't. Nobody at the factory or the commisioning dealer had installed fuses in the fuse holders. How's that for a potential liability?
Sawdust
Photos: C-Salt
PostPosted: Thu Jun 30, 2005 11:12 am    Post subject: Reply with quote
Beautiful work. A+ from old sparky.
Dusty
1984 22 Classic
Sea Angel
Photos: Sea Angel
PostPosted: Fri Jan 06, 2006 5:42 pm    Post subject: Reply with quote
Has anyone had any dealings with the "STEARNS", '4 Battery Gauge Panel'? At abt $44 it seems like a viable means to monitor a 3 to 4 battery system which could fit most of us with twin power.
Sea Angel
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Page generation time: 0.0487s (PHP: 49% - SQL: 51%) - SQL queries: 29 - GZIP disabled - Debug on
