removal of boat name graphic and registration numbers
takukla
City/Region: danville
State or Province: IL
Vessel Name: anna marie
PostPosted: Sun Mar 25, 2012 8:17 pm    Post subject: removal of boat name graphic and registration numbers Reply with quote
OK, so I bought a used C-Dory and want to change the name and remove the old registration numbers. Any particularly good tricks for doing this?
A hair dryer on "hot" has been suggested. Does it work? Is there a better method.
Tom
PostPosted: Sun Mar 25, 2012 8:56 pm    Post subject: Reply with quote
The hair dryer on hot or a good heat gun (be careful with the latter) works well. Heat them up and use a straight edge razor at a shallow angle. They should come off pretty easy. Then you can clean up the remaining goo with a little isopropanol.
PostPosted: Sun Mar 25, 2012 9:20 pm    Post subject: Reply with quote
I would not use a razor blade unless you are working on real glass (not poly ester) a nice plastic scraper works as well on fiberglass gel coat, and there is no risk of damage to the gel coat. I have always used the heat gun on low (high can damage a gel coat--maybe better a hair dryer, with lower heat.)
There are also adhesive and trim removers such as from 3M which work well.
There will be a shadow, where the gel coat has not aged--usually this can be buffed out with Finesse it II, or with time it will fade to the same as surrounding areas.
PostPosted: Sun Mar 25, 2012 9:42 pm    Post subject: Reply with quote
Hi Tom,
Congrats on the new to you boat. Welcome to the C-Brats. It a really great group and there is almost everything you could possible want to know about your boat available here.
Bob is right about the heat. A hair dryer works just fine. I have a whole series in my photo album, from taking the old name off to getting the new one on. It is here are this link.
http://www.c-brats.com/modules.php?set_albumName=album598&op=modload&name=gallery&file=index&include=view_album.php
This should give you a good result, start to finish.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sun Mar 25, 2012 10:20 pm    Post subject: Reply with quote
Use your debit card instead of a razor..... Laughing
Dave S.
"Sea Shift"
C-Brat #16
PostPosted: Sun Mar 25, 2012 11:08 pm    Post subject: Reply with quote
Preferably the credit card with an RDIF chip!
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sun Mar 25, 2012 11:14 pm    Post subject: Reply with quote
And the excess glue will come off with gasoline. No, wait that's too expensive, use 12 year old Scotch.......
Marc
Wefings Marine Website
Since 1909
takukla
PostPosted: Sun Mar 25, 2012 11:24 pm    Post subject: name removal Reply with quote
Thank you for your wise advice. The "Olive" will soon become the "Anna Marie III" (I know how to please/mollify a wife.)
sportner
City/Region: Buckeye
C-Dory Model: 26 Osprey
Vessel Name: Glory Days
Photos: Traveler
PostPosted: Sun Mar 25, 2012 11:30 pm    Post subject: Reply with quote
http://decalstickerremover.com/ works well if you have a lot to remove. Zero damage.
RUSS & TONI
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Mon Mar 26, 2012 6:19 am    Post subject: Reply with quote
It's hard to beat the 3m Graphics remover wheel, it works like a giant eraser in your electric drill-will not harm paint or gelcoat.
http://www.goferauto.com/sttaresy.html
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Mar 26, 2012 12:35 pm    Post subject: Reply with quote
For painted on names, EZ Off oven cleaner works well. I used it on a Carver I had purchased. The gel coat yellowed a bit, which worried me, but the next day was back to normal. Be very careful not to get the oven cleaner on paint you want to stay on!
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
davewilke1
City/Region: Versailles / Midwest
State or Province: MO
PostPosted: Mon Mar 26, 2012 5:10 pm    Post subject: Reply with quote
Hi Tom. Congrats on your new boat. I hope to join dory owner ranks myself and hopefully soon. We are practically neighbors. Hope to see you on the water. Don't forget to consult Vigors for renaming protocols.
Page generation time: 0.0419s (PHP: 63% - SQL: 37%) - SQL queries: 29 - GZIP disabled - Debug on
