Battery storage compartment leaks on new boat?
Goto page 1, 2, 3  Next
TomandPeg
City/Region: Port Orchard
C-Dory Year: 2011
Vessel Name: Hawkeye
PostPosted: Tue Mar 20, 2012 12:26 am    Post subject: Battery storage compartment leaks on new boat? Reply with quote
Hi,
New C-Dory owner (22 Cruiser). Have been breaking in the motors on the water and otherwise tinkering on land. Everything seems OK except that I notice that the battery storage compartments on both sides leak when it rains. Is this normal? And what can I do to eliminate/reduce it? Does the water that leaks in work its way down into the bilge and out the drain?
Thanks, Tom
PostPosted: Tue Mar 20, 2012 12:46 am    Post subject: Reply with quote
Tom,
The battery compartments (lazarets), have had some variation in how the work. The covers on the older ones, were not spec'd to be applied in a horizontal application. If there was water on the cover, when it was opened, it ran down into the compartment. One of the guys found a cover that worked, (where the cover actually covered the opening and when opened the water went down over the side and not into the compartment. Joel sold about 50 or 70 sets of the proper covers and many of us replaced the existing covers. We tried to get the factory to change to the proper covers, and were told they did, but ....... maybe that is what you have.
Can you tell if the water is coming from under the seal, or is it just running in from the cover at it is opened? The change is pretty easy to do, and worth the time and cost. If your water is coming from under the seal, then it is a remove and reattach with good adhesive, (Not silicone sealer). If you have to remove it anyway, ONLY put on the proper cover.
Search lazarette covers, (in the search box top of the page) or hatch covers and you will find several threads addressing the change.
SleepyC
Moon
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Tue Mar 20, 2012 9:58 am    Post subject: Reply with quote
I would call the builder, Triton Marine up in Ferndale. (360) 393-3283 Phone. Let us know how it works out.
MartyP
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Tue Mar 20, 2012 10:43 am    Post subject: Reply with quote
I gave all the part numbers to Scott when my 2011 was being built as I wanted the better covers that are designed for horizontal surfaces. I had changed my covers on the 19 with the ones Joel sold. I was assured my new 22 would have these new covers. Nope. Delivered with old style leaky Bomars. I changed them on the new boat. Get a hold of Scott or Jeff they really should swap those out it is a really well known issue. I have had my boat some time now and that is the only thing I was unhappy about. Great build otherwise. If the cover does not extend to the outside edge of the flange there is no way to keep a hatch from leaking. Period. George Very Happy
ghone
C-Dory Year: 2011
Photos: Kerri On
PostPosted: Tue Mar 20, 2012 11:55 am    Post subject: Reply with quote
Imtra 40154 dream white by So PAC. Fisheries Supply should have these or can be ordered online various suppliers. Hunter sailboats and many production boats use these. Get a pair even if you have to get them yourself. Big improvement my stuff stays dry now. George
naptime
Guest
PostPosted: Tue Mar 20, 2012 1:12 pm    Post subject: Reply with quote
I have the same problem on my 2012 22. The water runs in when the cover is closed, it is not from opening the cover. I dried the cover after a rain before opening and there is water in the battery boxes. Good to know there is a fix, I will call Triton about it.
dotnmarty
Photos: Lizzie
PostPosted: Tue Mar 20, 2012 1:38 pm    Post subject: Reply with quote
Years ago I had the same problem on a Seaswirl boat, using a vertical hatch cover on a horizontal hatch. The factory actually did a recall and fixed the problem on all affected boats.
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Tue Mar 20, 2012 3:01 pm    Post subject: Reply with quote
Did those fit the existing openings and hole patterns or did you have to adjust the cutout?
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Tue Mar 20, 2012 4:50 pm    Post subject: battery storage compartment leaks on new boat ? Reply with quote
Both mine leak too (2009 model). I'm looking forward to George's reply on fitting new ones.
Martin.
ghone
C-Dory Year: 2011
Photos: Kerri On
PostPosted: Tue Mar 20, 2012 7:00 pm    Post subject: Reply with quote
Mine were a drop in replacement. The hatch has slightly smaller cut out dimensions but was close that there was lots of meat for the flange to sit on and new screws to grab. I took the time to epoxy seal the cutout and old holes. The cutout had some gel coat on it and I added epoxy over. It is a really easy swap out as there is no standing on your head or reaching in past where you can reach or anything! George
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Tue Mar 20, 2012 7:59 pm    Post subject: battery storage compartment leaks on new boat ? Reply with quote
Thanks for the info George. If you have a minute or two, any chance of a few close-up pics from different angles. I really am a dunce at these things and a picture is worth a 1000 words etc. Cheers.
Martin.
BaseCampAnne
City/Region: San Diego/Anacortes
Vessel Name: SEA COASTER
Photos: SEA COASTER
PostPosted: Tue Mar 20, 2012 8:45 pm    Post subject: lazarette covers Reply with quote
Hi,
i have a pair of brand new lazarette covers that I purchased to put on my '22 C-Dory but never managed to do so.
I will be happy to sell them to anyone for $62.00 including postage. or $50.00 locally.
Anne Cox
425 445 8033
Kenmore, WA
ghone
C-Dory Year: 2011
Photos: Kerri On
PostPosted: Tue Mar 20, 2012 9:52 pm    Post subject: Reply with quote
Hi Martin there is A photo of the hatch in my album Kerri On layout. Along with the splash well table. The hatch is in closed position. I will see if I can get a couple more shots. Although not sure if it will show much. Hatch open....hatch closed. Grab those hatches from Anne! George
rob bauerle
City/Region: spokane
Vessel Name: Robbie's Refuge
Photos: Robbie’s Refuge
PostPosted: Tue Mar 20, 2012 11:34 pm    Post subject: Reply with quote
If Martin doesn't buy them, I sure would like to buy them
ferret30
Photos: Lily Pad
PostPosted: Wed Mar 21, 2012 12:24 am    Post subject: Reply with quote
Ok, I'll get in line (3rd). I'd buy them too.
Page 1 of 3
Page generation time: 0.0378s (PHP: 66% - SQL: 34%) - SQL queries: 31 - GZIP disabled - Debug on
