What to do with the roof
Goto page 1, 2, 3  Next
cdory25
City/Region: Flagler Beach
Vessel Name: Shoal Mates
Photos: Blues Cruiser
PostPosted: Sat Mar 10, 2012 3:53 pm    Post subject: What to do with the roof Reply with quote
I'm fairly new to CD. Curious about the roof on a 25. I've read you're not supposed to walk around up there or it might cause the windows to leak. Problem is I can't keep the girls off the roof. They claim it's the only place to sunbathe! I even see the roof depress about an inch as they walk around up there. Is there a roof rack available for these boat? Anybody have any advise?
Thanks!
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sat Mar 10, 2012 4:17 pm    Post subject: Reply with quote
I've actually stood on the roof of our 22' at 190#. Probably not the best idea but I was working on the shop door motor above the boat, but I stood lightly Rolling Eyes ....my windows don't leak and the roof looks fine. Certainly, didn't do any "jumping jacks" while I was up there. (Don't know about the 25'). Distributing their weight over a wider area than their two feet would most likely be fine. Perhaps over the years construction may have varied a bit as well. So no guarantees.
Dave S.
"Sea Shift"
C-Brat #16
PostPosted: Sat Mar 10, 2012 4:29 pm    Post subject: Reply with quote
I would guess that if they are sunbathing, you are probably on the water. Unless it's very calm, it's kinda dangerous to stand up. Falling in the water probably wouldn't hurt them but if they fell on the bow or into the cockpit they could break a bone.
If it's like the TomCat, the roof is cored and extremely strong. My roof (on a TC255) was about an inch thick, Fiberglass in and out and a thick core. I think the 22 is solid fiberglass but still ~3/8 - 1/2" thick. I'd think the 25 is thicker. They won't do any harm to the boat by being up there unless they are very large folks and jump up and down. Just be careful, "slippery when wet" or with suntan lotion on!!
Oh, and it's not a "roof". Houses have roofs, boats have cabin tops!! Laughing
PostPosted: Sat Mar 10, 2012 4:33 pm    Post subject: Reply with quote
I've walked up there and I'm 190 lbs. I've never seen an issue.
PostPosted: Sat Mar 10, 2012 10:38 pm    Post subject: Reply with quote
The roofs on different models are made differently. The roof on my C Dory 25 deflected significantly. I have seen some stress cracks on c Dory 25 roofs. If there is deflection, I would not stand on the roof, you may distribute the weight better by sitting, but be sure it is not causing deflection.
PostPosted: Sat Mar 10, 2012 11:28 pm    Post subject: Reply with quote
At 220lbs I walk on the roof of my 22 and 27 all the time. Need to to load the dinghy. Susan and I have both been up there at the same time, no issues. I even had my son and three friends up there using the top as a divlng board
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sun Mar 11, 2012 3:28 am    Post subject: Re: What to do with the roof Reply with quote
If I lived in Florida I probably couldn’t keep me son off the roof, he’d be jumping off into the water whenever we were on the hook; don’t see any safety concerns. Sunbathing on the roof in PWS Alaska, that’s a dangerous idea, jumping off the roof into the water,,, no freaking way.
Boatless for now but looking
Peter_BDA
City/Region: Bermuda
C-Dory Model: 22 Classic
Photos: Luna-Sea
PostPosted: Sun Mar 11, 2012 7:23 am    Post subject: Reply with quote
Having put a solar in vent in the top of C Dory I know exactly how thick the roof was-NOT VERY! 1/4" if that..........
I will admit to hanging out top side with a glass of wine on a full moon or a sunny day though....carefully. There was some roof flex......
P
Peter Aldrich
Bermuda
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sun Mar 11, 2012 7:54 am    Post subject: cc-23 Reply with quote
On the cc-23 we have non-skid throughout most of the roof .I don't know how thick it is but Will-c knows, look through his album I think he cut his roof to put in A/C
cdory25
PostPosted: Sun Mar 11, 2012 9:17 am    Post subject: Reply with quote
Thanks for the input. I seem to have started some sort of debate. When people are up there, I definatly have seen roof flex. Just wondered if it would/could cause permanate damage and if anybody has seen cabin top platform of some kind for the 25?? BTW the same size Rossbourogh has a second helm topsides as a $2500 option.
PostPosted: Sun Mar 11, 2012 9:29 am    Post subject: Reply with quote
http://www.c-brats.com/modules.php?set_albumName=album1192&id=C_Dory_upgrades_2010_004&op=modload&name=gallery&file=index&include=view_photo.php
Pic gives you an idea of thickness, at least on the lower portion. Cored w/ balsa.
C-Pup16 in Los Angeles
City/Region: Los Angeles
Vessel Name: C-Pup
Photos: C-Pup
PostPosted: Sun Mar 11, 2012 5:33 pm    Post subject: sun bathing on or diving from roof is dangerous! Reply with quote
~raises boat's center of gravity
~boat wakes will roll boat more and the roof will get it the worst
~falling off when sleeping or groggy risks hitting one's head ~ concussion
~hitting water when unconscious is not good
~ better to rig a hammock... install gunwale fishing rod holders on opposite sides of cockpit and slide hammock support poles into each.
~ Alternative is to construct a board that spans cockpit width and put a yoga mat on top for sun bathing. Add a trim on the edge to prevent rolling off in sleep. Use it as a buffet table in the evening. You can store the boards on the roof.
Risk management is all about thinking about what might go wrong and remembering Murphy's Law.
PostPosted: Sun Mar 11, 2012 7:54 pm    Post subject: Reply with quote
Welcome to the Brats! If more than one of us sees a post (always), there will be a debate (usually). In your case, the thickness of the cabin top is the issue. I certainly believe those that have seen the flex in a 25 but from the pictures it looks to be at LEAST 1/2" thick and cored which should be strong. That having been said, Dr. Bob is right (as usual) and it would not be good to cause flexing by concentrating any weight.
As for a "cabin top rack", you'd probably have to have one made. Have seen many cabin top things (arches, kayak racks, solar panels, etc) but nothing like what I think you are describing. The RF246 upper helm is probably constructed so as to distribute the stress load to the lower cabin sides and on to the main deck. Anything you put up there that is non porous (lets a lot of water through) and semi permanent is going to make it very difficult to keep the top clean. Anything, like a car top roof rack (like a big basket) will make it very difficult, not to mention uncomfortable to sunbathe. If my kids (and now grandkids) insisted on it I'd explain about my radar beam and how unwise it would be! Shocked It's kinda like "bowriding", probably lots of fun but not very smart. Good luck!!
cdory25
PostPosted: Sun Mar 11, 2012 8:15 pm    Post subject: Reply with quote
Interesting...Guess I'll have to invent something!
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Sun Mar 11, 2012 9:34 pm    Post subject: Reply with quote
Do you have room inside for some bows/ribs my 22's roof is not strong enough to walk on but I don't have enough headroom to put anything in.
Richard
Page 1 of 3
Page generation time: 0.0437s (PHP: 66% - SQL: 34%) - SQL queries: 32 - GZIP disabled - Debug on
