lug crimper needed
nimrod
City/Region: Mount Vernon
Vessel Name: 'Berta's Boy
Photos: 'Berta's Boy
PostPosted: Thu Oct 27, 2011 8:33 pm    Post subject: lug crimper needed Reply with quote
my wiring project is going to require me to crimp several 2-6 AWG lugs. I'm wondering if anyone in the north Puget Sound area has a crimper they wouldn't mind lending or renting for a weekend?
jd
PostPosted: Thu Oct 27, 2011 9:41 pm    Post subject: Reply with quote
Most West Marine stores have a good crimper set, which you can use when you buy your supplies there. I find the lever type is better than the vise/hammer type. You can also use a nicopress dye, but you have to be sure of a good fit.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Fri Oct 28, 2011 9:17 am    Post subject: Reply with quote
I've used a center punch and a hammer at times. Works very good.
Jody Kidd
KE7WNG
Northern, Utah
Nunya
Photos: Nunya
PostPosted: Fri Oct 28, 2011 11:48 am    Post subject: Reply with quote
You can also get the solder on type lugs. That's what I use on #6 wire and larger.
JGrider
City/Region: Laplace
State or Province: LA
Vessel Name: Jeannie's VOO DOO
Photos: Jeannie’s VOO DOO
PostPosted: Fri Oct 28, 2011 2:50 pm    Post subject: Reply with quote
For a few large wires solder is the way to go and is by far the best connection.
John & Jeannie Grider
Jeannie's VooDoo
Home port: LaPlace, Louisiana
Chris
City/Region: Bend
Vessel Name: Rana Verde
PostPosted: Fri Oct 28, 2011 3:52 pm    Post subject: Reply with quote
Solder is an inferior method for marine connections...and is not an approved method. Crimp connections properly done are far superior. Lots of reference available from your friend Google.
Chris
Rana Verde
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Fri Oct 28, 2011 4:14 pm    Post subject: Solder bad...crimp good Reply with quote
The aviation world found out long ago that a soldered terminal on any size wire is much more subject to breaking due to the vibration factor cold working the soldered and therefore "stiffer" joint.
I bought a "double lever" lug crimper from Lowes for only about 30 bucks. It also includes a wire cutter. The thing is big and has handles about 18" long. Harbor freight may also have them. They look like a padlock cutter. They wouldn't be aviation legal, but for the boat wiring they do a very good job on those huge wires.
Testosterone Tales-Amazon.com
KG7RC
JGrider
PostPosted: Fri Oct 28, 2011 4:24 pm    Post subject: Reply with quote
I guess I have always believed solder connections made a solid metal on metal connection and had to be the best. Looks like you learn something everyday!
Just read about twenty different views on crimping vs soldering. Looks like the consensus is crimping wins out hands down. Now if I can only remember what I learn long enough to put good use.
PostPosted: Fri Oct 28, 2011 8:21 pm    Post subject: Reply with quote
I have used a combination of solder and crimp on some large cables--but the solder did not wick up to a point where it was "hard", above where the crimp is. National Standard Parts Associates, makes remeasured pellets of solder and adhesive shrink for combination (crimp and solder) connectors.
For the most part I rely mostly on just high quality crimps.
Page generation time: 0.0343s (PHP: 60% - SQL: 40%) - SQL queries: 22 - GZIP disabled - Debug on
