Trailering motors lifted up or in down( operating mode)
G Gallagher
Vessel Name: Reel Salty
PostPosted: Sun Sep 25, 2011 7:57 pm    Post subject: Trailering motors lifted up or in down( operating mode) Reply with quote
Had a trailer it in down position--n interesting and expensive experience last week.
Have been trailering with motors tilted up. My Suzuki manual says don't do that,-- but sometimes I don't listen well. Suzuki is OK- my story is with the 2005 Yamaha 8hp kicker.
Trailered it in tilt position for about a year, but 2 weeks ago I went over a little bump and Oh,Oh. Motor flipped up a little and came back down shearing off the little nubs on the motor bracket that holds motor to transom. Now motor works well but no longer stays tilted up. Ok, into the dealer for the new- order new transom brakets. Parts came in after a week and the bill was $ 563.00 including labor, half the cost of the motor when I bought it.
I think it is fair to say don't trailer with tilted motor!!
Oh, one more lesson.-- With 4 cycle Yamaha if you lay motor down be certain that you do it with the tiller down. If you don't the oil will drain into the cylinders causing the motor to seize up. To fix that re-hang motor, pull plugs, clean them, squirt starter fluid in multiple times until oil is washed out, replace plugs and work to start motor.
What a fun week.
Gary
hambone
PostPosted: Sun Sep 25, 2011 8:06 pm    Post subject: Reply with quote
I had a small kicker almost work itself off the transom many years ago leaving it in the tilted position. Never again. Crook
H Wink
Hawg Hunter Productions.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Sep 25, 2011 8:55 pm    Post subject: Reply with quote
I tilt my kicker up to one of the first stops, then use a strap to secure the leg tightly to the trailer. No reports of bounce, and no damage (to date, cross fingers, knock wood).
PostPosted: Mon Sep 26, 2011 10:31 am    Post subject: Reply with quote
I also have trailered with kickers tilted up, but always secured them well to a cleat, with a very tight line around the upper part of the outboard. That way they cannot bounce.
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Mon Sep 26, 2011 12:02 pm    Post subject: Reply with quote
Not trailering but towing and thats another story. Small tohatsu bounced hard enough to bend the pin that keeps it tilted. Bent pin could not be retracted to get the motor down for operation. I had to remove the bracket and hammer then file the pin straight enough to operate again.
And it was tied tightly with two separate straps at the time limiting its bouncing ability.
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Mon Sep 26, 2011 1:07 pm    Post subject: Reply with quote
I use a 2in ratchet strap between the transom tie down, across the kicker below the motor cover, to a u bolt on the forward side of the motor well that is backed up by a 6in sq pc of 1/2 in plywood underneath. I crank that puppy up snug. No way it can bounce. The previous owner used to tow from Sacramento to Bodega Bay with the main bouncing causing tiny hairline cracks on both sides of the transom.First thing I did was add a support bar to the trailer. Im glad he didnt have a kicker! Vern/C-Dog
20dauntless
Photos: Retriever
PostPosted: Mon Sep 26, 2011 1:21 pm    Post subject: Reply with quote
I cracked the aluminum mounting bracket for a Yamaha T9.9 kicker twice on a 20 foot Whaler while running the boat. The kicker needed to be tilted up to clear the water, and evidently the bouncing and pounding was too great.
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Mon Sep 26, 2011 1:49 pm    Post subject: Reply with quote
Our new (old) boat currently doesn't have a kicker (we will be getting one soon), but it has an adjustable motor bracket. With this system, it seems like you could lift the motor vertically with the bracket, or tilt the motor itself, to get it out of the water or up for trailering. Which is preferable?
PostPosted: Mon Sep 26, 2011 9:47 pm    Post subject: Reply with quote
I have tended to either trailer with the engine on one of the stops of the mount, or using a transom saver or a block under the engine (between the mount and engine) to take the load. I would not trailer with the engine just on the hydraulics of the tilt mechanism.
PostPosted: Mon Sep 26, 2011 9:58 pm    Post subject: Reply with quote
An MY Wedge is an option but I warn you, don't forget it is there and try to power tilt the engines down, it's hard rubber and will destroy the t/t cylinder in a heartbeat. Don't ask me how I know or how much it costs with twins!
Embarassed Crying or Very sad
I have one for sale for the daring and non-forgetful brats for there in the crowdl Make a $$10 donation to the tip jar, pay for shipping and it can be yours. No insurance... (for the t/t mistake)
Chester
City/Region: home
Photos: Chester
PostPosted: Tue Sep 27, 2011 1:18 am    Post subject: Reply with quote
Per Bill and Ell we used a wooden dowel between the motor and mount. This year I substituted a length of 1 1/2" (?) PVC pipe. The engine is snugged down against the pipe compressing it a bit. The stuff is pretty strong, it takes more force than one might suppose. The theory being the unit under tension gives no opportunity for slack to hammer the bits, also hopefully it could lessen any severe shock events.
Nunya
Photos: Nunya
PostPosted: Tue Sep 27, 2011 11:20 am    Post subject: Reply with quote
Used one for years and have never had a problem.
www.m-ywedge.com/
Hugh and Jennifer
City/Region: Denver
Vessel Name: Speckled Pup
Photos: Speckled Pup
PostPosted: Wed Dec 07, 2011 10:52 am    Post subject: Reply with quote
I worry about dragging my prop if I trailer with the motor tilted down.
cruiserlessvinny
City/Region: Suwanee
State or Province: GA
Photos: cruiserlessvinny (Name TBD)
PostPosted: Wed Dec 07, 2011 1:43 pm    Post subject: motor support Reply with quote
I use an oak board cut to appropriate size. The board rests atop the T-n-T rams and snugs against the mounting bracket on one side and against the motor on the other side. Was going to buy a Wedge but realized what the intent of the wedge is and made-do for the price of shop scraps.
CV
I have a classic Whaler. Now I think I want a cruiser. I'm so-o-o-o-o confused.
PostPosted: Wed Dec 07, 2011 5:50 pm    Post subject: Reply with quote
Hugh,
It depends on ground clearance--actually the skeg will hit first. But for the current C Dory 22, and single axle trailer with 15" tires, with the engine down, there is plenty of ground clearance. Other trailers I have owned, I had to secure the motor up. The Caracal came with a "transom saver"--which is a support which is secured to the trailer frame, with a quick release pin and cradles the lower unit raised up about 45 degrees.
Page generation time: 0.0826s (PHP: 48% - SQL: 52%) - SQL queries: 32 - GZIP disabled - Debug on
